frank2678 Samba Member
Posted: Fri Dec 03, 2004 4:29 pm Post subject: adding semiphores on a 62 rag? help!!!!! |
how hard would it be to add some semiphores on a 62 rag.?& would the wiring be hard to install also? |
Kubel Nick Samba Member
Joined: August 12, 2003 Posts: 1369 Location: Fort Worth, TX
Posted: Fri Dec 03, 2004 5:57 pm Post subject: |
Get a donor Beetle with sempahores, cut off the sempahore section ('B' pillar) and weld that part onto your car. I've seen donor sections pop up once in awhile. Make sure you know how to weld as the 'B' pillar is an important part of the body structure. |
Levonbenelli Samba Member
Posted: Fri Dec 03, 2004 6:51 pm Post subject: |
Socalimports (socalautoparts.com) and probably some other places also sell aftermarket semaphores that come with cans that you weld in if you;re not looking to section out your b pillar....but they run $300 for 6v and 350 for 12v _________________ Wanted: flipseat parts: rear jump seat, folding chair, cups |
volksaddict Samba Member
Posted: Thu Dec 16, 2004 6:05 am Post subject: |
When I cut mine in I cut the hole for the semi in the outside of the pillar with a die grinder and cutting disc, then cut the inside of the pillar and stuffed the box through it and welded it in place, leaving the b pillar and window opening size intact. The wire isn't too hard to run, but if you have a headliner you want to save, good luck! You'll need to come up with the simi's, posts, and a new blinker switch, or buy the crappy (well not original) new ones mentioned above and butcher your bug. all said, it's a lot of work for outdated, expensive, 6v only blinkers.
But originals are cool! |
