gunz Samba Member
Posted: Tue Dec 20, 2011 1:06 pm Post subject: how to check generator |
is there a way to check a generator to make sure it works. |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Tue Dec 20, 2011 1:11 pm Post subject: |
When you say "Check" do you mean if its operational or the charging capacity?
For operation, a standard volt meter or a 12 or 6 volt drop light depending on your generator and spin it with your hand.
For charging capacity your better off taking to local auto parts where they can check on machine. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
pikeman48 Samba Member
Joined: May 12, 2007 Posts: 216 Location: bangor,michigan
Posted: Tue Dec 20, 2011 2:30 pm Post subject: |
disconnect generator,take belt off,ground the case, and put 12v on the field terminal. A good generator will spin just like a motor. If it does, the generator is good,if it doesn't,it ain't. _________________ if it has wheels or tits,it will make your life difficult!!
1962 type 1-gone,but not forgotten
1971 type 1 vert-sold
sand rail-stripped and scrapped
1968 Empi Sportster |
gunz Samba Member
Posted: Tue Dec 20, 2011 2:54 pm Post subject: |
ok ill try that with the ones i got thanks. Witch one is the field terminal. |
Posted: Tue Dec 20, 2011 3:36 pm Post subject: |
The terminal marked D+ is the output, the terminal marked DF is field. _________________ if it has wheels or tits,it will make your life difficult!!
Posted: Tue Dec 20, 2011 3:53 pm Post subject: |
Out of cuiosity, could you let me know which direction it spins? _________________ Jesse
71 Ghia
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Tue Dec 20, 2011 5:18 pm Post subject: |
SoCalJes wrote: |
Out of cuiosity, could you let me know which direction it spins? |
Mine spun clockwise (same as normal rotation) when I polarized it.
Paul |
Dale M. Samba Member
Posted: Tue Dec 20, 2011 5:29 pm Post subject: |
Probably most accurate test of generator AND regulator...
Generator/Regulator Test!
Disconnect all wires from Generator. (tag them so you get them back right)
Connect a test light ( 6 or 12 volt what ever is appropriate) on generator to the "D+" terminal ... Ground other side of light.
Ground "DF" or "Field" on generator.
Start engine... If light comes on and brightness increases as engine rpm comes up your REGULATOR is bad ( generator works ) Caution over revving engine to fast will cause light to burn out.
IF light stays dark ( does not light ) , check test setup again to be sure its right... If you rev engine up and light still does not light GENERATOR is bad.
People with experience using a VOLT-OHM meter could use the meter instead of light... look for VOLTAGE increase..
