First Pics on Samba My 67 Beetle, What do you think?
Ppub101
Ppub101 is offline
PostPosted: Sat Jan 01, 2005 11:19 pm    Post subject: First Pics on Samba My 67 Beetle, What do you think? Reply with quote
I just joined this forum, and i like it alot. Here is some pics of my first Beetle. It is a 1967 with a 1600cc engine. Only mods to my knowledge is a Headre with Empi Stinger exhaust. So let me know what you think.
That was before I cleaned up the engine. Someone told me to fill those wholes in the bay..... Something about recirculating hot air. How should I do that?
That was just a photoshop of my VW Golf Wheels on the bug. Thought it looked pretty cool.
So Please tell me what you think. Any questions or advice, id love to hear it. Thanks for your time.
Paul
vic70vw
vic70vw is offline
PostPosted: Sat Jan 01, 2005 11:31 pm    Post subject: Reply with quote
Nice looking! I like the color. Replace the heater tubes that go on each side of the engine (look at pictures of other engines on this site). Have lived in NC and you can use a heater in the Winter.
I like the chrome wheels on your car. Don't replace them with the other ugly wheels you have shown.
TWD
TWD is offline
PostPosted: Sun Jan 02, 2005 3:00 am    Post subject: Reply with quote
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=FSK0028&cartid=0101200586920599
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D129%2D701%2DK
Looks like you are missing intake pre-heat. You will never run well in cool weather without it.
rlarkin
rlarkin is offline
PostPosted: Sun Jan 02, 2005 10:34 am    Post subject: Reply with quote
The fresh air hoses and pre heat are not there due to the header swap.
L-jetronic
L-jetronic is offline
PostPosted: Sun Jan 02, 2005 11:15 am    Post subject: 30 bucks Reply with quote
Ppub101 wrote: "Someone told me to fill those wholes in the bay..... Something about recirculating hot air. How should I do that?"
The hot air under the engine comes up through those holes, into the engine compartment, and raises the operating temperature of your engine. The fix is to buy a new tin without holes, or if you're feeling ghetto, cut some peices of tin (wood if you're curious about engine fires) and attach using sheet metal srews with some silicone sandwiched inbetween. A new tin is the better choice.
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=ESM0026&cartid=1228200472146923
Where Have All the Horses Gone?
DER SPELLING WERDS
63 sold as a 64, November 1963
Daily driver, 29 miles/gallon!!
SD, EC, OB.
ottobahn
ottobahn is offline
PostPosted: Sun Jan 02, 2005 3:39 pm    Post subject: Reply with quote
Since you don't have a stock air cleaner,you should block off the hole on the lower right side,near the lower crank pulley,that hole is for the preheat hose that runs to the aircleaner on a stock setup,I used the top of a paint can,it fits just right,mine is glued in with RTV silicone sealer.You would be much better off with a stock oilbath aircleaner with a preheat hose,but you would have to convert back to that and get rid of the chrome aircleaner. The other two holes you have are where you need to replace your fresh air hoses that come out of the fan shroud and connect up under the back of your engine to the heater boxes. Without these,you won't have any heat in your car,and your going to fry your engine in warm weather,need to keep your engine bay cool and the hoses need to be there,they don't cost much. There is also a set of rubber seals that go around the lower tin that the fresh air hoses run though,this will also help keep hot air out of your engine bay. Get a hold of a cip1.com catalog,you will find just about everything for bugs in this catalog.Hope this helps.By the way,nice looking car,keep the stock wheels,they look great!
Racelook
Racelook is offline
PostPosted: Sun Jan 02, 2005 5:02 pm    Post subject: Reply with quote
Nice bug!! Which color is that??
And If I where you I shall go with the golf wheels.. looks much better Razz
Wiebrand
B-extreme B-tuning
Racebug is comming to get ya........ Still in full resto
1974 Supa...
70 140
70 140 is offline
PostPosted: Sun Jan 02, 2005 9:07 pm    Post subject: Reply with quote
Looks good. I would stick with porsche looking rims.
rlarkin
rlarkin is offline
PostPosted: Sun Jan 02, 2005 10:37 pm    Post subject: Reply with quote
Ottobahn, he no longer has heater boxes.
The PO appears to have cut off the pre heat pipe to the manifold also.
VW Addict Premium Member
Samba Salesman
VW Addict is offline
PostPosted: Mon Jan 03, 2005 12:02 am    Post subject: Reply with quote
I like the Porsche hubcap wheels better...
Nice color.. now, chrome up that engine. Smile
You have a nice 67.
-|_______|-
_\_\_|_/_/_
|O|_|_•_|_|O|
shane red
shane red is offline
PostPosted: Mon Jan 03, 2005 1:23 am    Post subject: Reply with quote
your distributer is sitting sideways, a lot of people will argue it doesn't matter but I've experimented with that & i believe it does. Rotate your distributer 90 clockwise & then reset your timing i think you'll find it runs better & is a bit easier to start.
shane red
shane red
PostPosted: Mon Jan 03, 2005 1:24 am    Post subject: Reply with quote
i forgot to say, also reconfigure your plug wires accordingly after the distributer is rotated.
Ppub101
Ppub101 is offline
PostPosted: Mon Jan 03, 2005 2:10 am    Post subject: Reply with quote
Thanks for all the advice. That goes for everyone. And Someone asked the color, I have no idea the code or anything. But i love the color myself. This Forum is great. I have gotten more reponses and help then any where else in just one day. Thanks again.
Paul
vwspijlbus
vwspijlbus is offline
PostPosted: Fri Jan 07, 2005 1:55 am    Post subject: Reply with quote
Nice bug!
Frank
1967 Dutch SO-42
www.vwspijlbus.blogspot.com
