DeathBus WILD MAN!
Joined: February 29, 2004 Posts: 4593 Location: Birmingham, Alabama
Posted: Wed Mar 16, 2005 5:39 am Post subject: |
Best thing I ever did was buy the cheapy $69 blast cabinet from HArbour Freight! I have a powder coating system also, just need an oven I can put outside to bake my stuff in. _________________ 65 Bus, 72 Bus, 63 bus, 98 Golf
In the shop 68 Beetle and a 62 Bus |
anglodeutsch4 Samba Member
Joined: September 02, 2003 Posts: 143 Location: Clear Lake, TX
Posted: Fri Mar 18, 2005 10:21 pm Post subject: |
Well, I discovered a friend at work has a 4 hp heavy-duty Campbell-Hausefield compressor (240 v, 15 amps!), and he let me borrow it . Man oh man, that made all the difference in the world! The sandblaster is now dissolving the old paint and rust almost instantly, and I don't have to stop and wait for my 1.5 hp compressor to catch up. I'm going through that pile of engine tin really fast now. Won't be long before I'll have all the tinwork prepped for painting, then it's waiting for the humidity to drop below 50% long enough to get it all shot . I've got both heads off and ready to lap the valves, and after the sandblasting, the jugs come off for a light glaze-breaking hone. Progress! _________________ Lane
MGVWFAN (STF)
anglodeutsch4 (Samba)
73 VW 412 (the Nomad, dropped valve seat land now, argh!)
67 MGB (Runs like a scalded dog)
76 Plymouth Duster /6 (runs like a top)
02 Intrepid 2.7L (leaks more than my MGB!)
90 Ramcharger 318 (soon to be son's car, fried A518) |
Posted: Sat Mar 19, 2005 6:16 pm Post subject: |
The jugs and heads are off! The crosshatch is still visible in the jugs, and the pistons still have the machining marks on the skirts from the factory. Yep, they're Mahle. The inside of the crankcase is squeaky clean, too. No signs of any trouble, no sealing problems, no scuffing, no scratches, just the usual amount of carbon. Good news!  _________________ Lane
MGVWFAN (STF)
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19612 Location: Samba Center for Behavioral Science
Posted: Tue Mar 22, 2005 9:24 am Post subject: |
Okay Lane, I got your messages and I will be getting with you one evening after work this week or maybe Saturday morning if that's open for you. Should be able to get the parts back to you pretty quick. I'll have to as I will be heading out of town for my job on April 2nd. _________________ my seller feedback
rebuilt carb info = for sale
"STFU Polly and go eat a cracker!" 12-21-2012.... can't wait! |
Posted: Tue Mar 22, 2005 6:22 pm Post subject: |
Much appreciated Keith! I'll be out of pocket Thursday night, but most any other time should be OK. _________________ Lane
MGVWFAN (STF)
Posted: Wed Mar 23, 2005 7:38 pm Post subject: |
When the boot (trunk) is full of parts and painted tin, it's time to put it all back together, no?
http://www.thesamba.com/vw/forum/album_search.php?search_author=anglodeutsch4 _________________ Lane
MGVWFAN (STF)
Posted: Thu Mar 31, 2005 2:04 am Post subject: |
I'm back!!!
Today I pulled the pistons, and started cleaning the carbon off them. I've got the crankcase openings stuffed with rags to keep the rods from contacting the openings, and to help keep crud out. After I got all the pistons out, I covered the engine with sheet polyethylene to keep dust out. Now it's clean slowly and carefully time, and finish painting engine tin on Friday when the dew point goes down  _________________ Lane
MGVWFAN (STF)
Posted: Sun May 22, 2005 10:54 am Post subject: |
First, the good news
The tin's all done.
The Auto transaxle's been rebuilt (by me), and is completely reassembled.
The rear of the engine's clean.
The rear crank seal's been replaced.
The fan impeller marked for TDC #2 (180 degrees out from the factory TDC mark) and 7.5 degrees (static timing for initial start-up).
The oil cooler's been cleaned out and reinstalled (thin smear of Hylomar HPF to keep the seals in place).
The oil filter bracket's been cleaned and reinstalled (thin smear of RTV on the gasket), new Mahle filter installed.
The oil filler tube's been installed (thin smear of RTV on the gasket).
The oil pump's been pulled, disassembled, cleaned, inspected, lubed, reassembled (with new O-ring), and bagged awating check of the case flange for flatness.
The distributor has been disassembled, cleaned, relubed, and reassembled with new stuff and a good vacuum can from a '71 411, new O-ring, installed on engine. Tested for vacuum can operation, and bobweight free motion.
The oil pressure relief valve's been cleaned, polished, lubed, and reinstalled (a 3/8" drive extension fits in the 12-point 3-square socket on the valve plug just fine) with a new gasket.
The oil cooler bypass valve's been cleaned, polished, lubed, and reinstalled with a new gasket.
The breather box has been reinstalled with a new gasket (Hylomar HPF on the bottom, RTV on the top so it stays with the breather box when removed), the PCV valve's been gutted to act as a hose fitting (I'll install an inline PCV valve when I get to that part of engine assembly).
Now the bad news ...
The valve guides are worn out. There is cylinder head work in my future. Oh, well. _________________ Lane
MGVWFAN (STF)
Posted: Sun May 22, 2005 1:49 pm Post subject: |
You lurking DB? _________________ Lane
MGVWFAN (STF)
DeathBus WILD MAN!
Posted: Sun May 22, 2005 2:37 pm Post subject: |
nah just came in from welding a new nose on the 72 Bus, whats up? _________________ 65 Bus, 72 Bus, 63 bus, 98 Golf
Posted: Sun May 22, 2005 6:24 pm Post subject: |
Welding a nose on the bus
Who is that avatar? _________________ Lane
MGVWFAN (STF)
DeathBus WILD MAN!
Posted: Sun May 22, 2005 6:37 pm Post subject: |
| anglodeutsch4 wrote: | Welding a nose on the bus
Who is that avatar? |
Oh yeah that poor thing has been run into 30 different things, time to reskin it.
The guy in my avatar is a rapper from the late 80's early 90's named Biz Markie _________________ 65 Bus, 72 Bus, 63 bus, 98 Golf
Posted: Sun May 22, 2005 7:48 pm Post subject: |
Looks like Chubby Checker on 'droids to me.
You're an adventurous soul DB, welding a new nose on the bus...which one, the DB or the poopie? _________________ Lane
MGVWFAN (STF)
DeathBus WILD MAN!
Posted: Sun May 22, 2005 7:55 pm Post subject: |
| anglodeutsch4 wrote: | Looks like Chubby Checker on 'droids to me.
You're an adventurous soul DB, welding a new nose on the bus...which one, the DB or the poopie? |
Oh the DB it's down for a full on Resto. _________________ 65 Bus, 72 Bus, 63 bus, 98 Golf
Posted: Mon May 23, 2005 8:03 am Post subject: |
Gonna keep the Flying Tigers shark-nose? I like it personally. _________________ Lane
MGVWFAN (STF)
DeathBus WILD MAN!
Posted: Mon May 23, 2005 8:10 am Post subject: |
| anglodeutsch4 wrote: | | Gonna keep the Flying Tigers shark-nose? I like it personally. |
Yeah but this time I am having a graphic artist do it instead of a drunk Army Ranger! _________________ 65 Bus, 72 Bus, 63 bus, 98 Golf
Posted: Mon May 23, 2005 9:04 am Post subject: |
Where's the fun in that? _________________ Lane
MGVWFAN (STF)
Posted: Wed Jun 01, 2005 7:17 pm Post subject: |
Today I installed the horns and wiring to same (my car toots now!), and pulled the left front strut assembly. I wasn't expecting damper oil in the strut tube, I got a hydraulic oil bath ! I guess I should have expected a wet strut from reading some past posts. Anyway, the KYB KC4017 struts I've had on the shelf for a good while appear to not fit correctly...the center rod is too long for the strut mount dimensions. From mining the dissertations of Dr. Greenwood, I think I know what's up. I got these struts for cheap as a Plan B, thinking I'd do the Greenwood Mod as Plan A. Well, it looks like either option is going to take some work, so I'll be doing some flavour of the Greenwood Mod, after reading the 15 pages of posts I've gathered on the topic. Progress, though slowly. _________________ Lane
MGVWFAN (STF)
Posted: Sat Jun 04, 2005 6:39 pm Post subject: |
Today I did some more front suspension prep work, and attempted installation of the rear dampers. I thought I had enough washers to act as spacers, but alas, not so. Also, the VW lower bolt is a tiny bit too small for the KG5406 bushing, and I'm not going to rip up the KYB's rubber bushing to get the steel bushing out so I can replace it with the OE VW one, so I'm going to Lowe's tomorrow to get some spacers for the KYB's on the rear, and a bigger through bolt and nut (Nylock, of course!), I'll post what I come up with later.
I put the two side by side, and it's amazing, the KG5406's are exactly the same length as the OE Sachs dampers, both extended and fully compressed. The extra stiff damping characteristics should make the rear behave itself quite well.
Oh yes, we also cleaned out the filthy garage. It's great having twin teenage sons! _________________ Lane
MGVWFAN (STF)
Posted: Sun Jun 12, 2005 12:57 pm Post subject: |
Today we bled the brakes (again). After replacing the right rear WC that had two different sized seal cups , and pulling the two front calipers to install anti-rotation plates, it needed another bleeding. All that's left to do (while awaiting various parts) is...
Grind the burr out of the RRWB bore
Hone the jugs
Check the ring gaps
Lap the oil pump sealing flange
After I get the rear wheel bearings and seals (7-30 days, depending on if Bus Depot comes through with bearings)...
Replace the RRWB's and seals
Check and repack the LRWB's, replace the seals
Once I get the heads, I can lap the heads and jugs, clean everything, assemble the engine, and get it back on the road!
It's getting closer! _________________ Lane
MGVWFAN (STF)
