DurocShark Samba Member
Joined: April 05, 2004 Posts: 5631 Location: Wishing I was at the beach
Posted: Thu Jan 20, 2005 2:01 pm Post subject: Retractable seat belts in my 73! |
Ok, seat BELT. Only one in so far...
Because the stock belts suck and are really inconvenient and uncomfortable I've been wanting retractables. But to make matters more urgent, here's what my original driver's belt looks like:
And a closeup:
So, needless to say, I needed to do this NOW.
A few weeks ago I picked up a set of belts from an early 80's BMW off eBay for next to nothing. Because mounting them would require drilling I'd been putting it off. But today I'm home from work sick (really... and what's more healthy than some relaxing time with your bus?), so decided to dive in.
I had to drill two holes in the seat panel since the unit requires a vertical mounting. One hole for the bolt and one for the set pin doohickey that keeps it from twisting.
The hanger went in the same location as the existing top hanger. The anchor also just replaced the existing one, as did the receiver.
As you can see, the only thing left to do is make a holder or something to keep the receiver up so I don't have to use two hands to put my seatbelt on.
It is much more comfortable and convenient than stock. I can lean forward to open the glovebox without unbuckling!
The steel used where I drilled the holes is very thick and heavy (possibly doubled?). I doubt I'll be able to damage the mount in even the worst crash, especially since the tension will be vertical coming from the hanger. That was my only safety concern, and I'm satisfied that it will be sufficient. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow.
The Guacamole Bus
Woodscrub's Blog
Buy My Crap |
velokid1 Samba Member
Joined: December 22, 2004 Posts: 1160 Location: N. Arizona
Posted: Thu Jan 20, 2005 2:11 pm Post subject: |
Great! Thanks for sharing. Going to be very helpful, as that project is in my future.
Greg |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 8551 Location: Syracuse, NY
Posted: Thu Jan 20, 2005 2:39 pm Post subject: |
| I'll be doing the same thing in my '79 this spring, only I'll be using a set of belts I scored out of a vanagon. I do plan to use a small steel plate on the back side of where the retractor goes though, I don't want to chance that bolt ripping through the metal in an accident, thereby making my seatbelt worthless. Nice install though!! I'm really not looking forward to taking out my sink/stove cabinet to put that in, but the convenience is definitely worth it to have a seatbelt that will actually work!! |
regalasr Samba Member
Joined: August 25, 2002 Posts: 743 Location: Los Angeles
Posted: Thu Jan 20, 2005 4:49 pm Post subject: |
| Hey that looks fine. I betcha you can find solid receivers from a German car that you can use instead of the limp ones. Trace the end of the buckle on a pece of cardboard and go to the Pick A Part on Harbor Blvd and find a buckle that matches yours and cop a suitable receiver from that vehicle. |
tristessa Samba Member
Joined: April 07, 2004 Posts: 2054 Location: Portland, OR
Posted: Thu Jan 20, 2005 7:06 pm Post subject: |
Those are Bimmer? That inertia reel looks a *lot* like the Vanagon reel I've got in my Bus.
I'd definately put a plate or a big-assed washer on the backside of the bulkhead .. otherwise looks pretty good. |
Posted: Thu Jan 20, 2005 8:13 pm Post subject: |
| regalasr wrote: | | Hey that looks fine. I betcha you can find solid receivers from a German car that you can use instead of the limp ones. Trace the end of the buckle on a pece of cardboard and go to the Pick A Part on Harbor Blvd and find a buckle that matches yours and cop a suitable receiver from that vehicle. |
There's a Pick A Part on Harbor?!?!?!? _________________ No boom today. Boom tomorrow. There's always a boom tomorrow.
The Guacamole Bus
Woodscrub's Blog
Buy My Crap |
Posted: Fri Jan 21, 2005 9:55 am Post subject: |
| Ooops, the address is actually: Pick Your Part, 1235 South Beach Boulevard, ANAHEIM, CA 92804 |
Posted: Fri Jan 21, 2005 10:43 am Post subject: |
| regalasr wrote: | | Ooops, the address is actually: Pick Your Part, 1235 South Beach Boulevard, ANAHEIM, CA 92804 |
Ok. Yeah, I'm like 2 blocks from that one. Thought there was a new one I dwasn't aware of.  _________________ No boom today. Boom tomorrow. There's always a boom tomorrow.
The Guacamole Bus
Woodscrub's Blog
Buy My Crap |
krisw Samba Member
Joined: July 22, 2004 Posts: 112 Location: Albuquerque, NM
Posted: Fri Jan 21, 2005 10:47 am Post subject: |
| VDubTech wrote: | | I do plan to use a small steel plate on the back side of where the retractor goes though, I don't want to chance that bolt ripping through the metal in an accident, thereby making my seatbelt worthless. Nice install though!! |
I did the same thing but I used some huge thick washers, about 2" wide. I would definitely think about putting at least a bigger washer or a plate back there Duroc. You might be alright though, like you said about the vertical pressure, it will be hard to pull the bolt out, it seems like it will want to slit the metal up.
Good Job! _________________ 76 Riviera
"Heaven is where the police are British, the chefs Italian, the mechanics German, the lovers French, and it is all organized by the Swiss. Hell is where the police are German, the chefs British, the mechanics French, the lovers Swiss, and it is all organized by the Italians." |
LostWater Samba Member
Posted: Mon Jan 24, 2005 9:40 am Post subject: Any chance on mounting to the floor? w/ a bracket? |
These BMW seat belts look like they would function if they were mounted to the floor with a bracket to keep them vertical. A bracket similar to the one that is on the GOWESTY seat belt sets that Ratwell posted pictures of.
What do you think? Is there enough belt to make or get a bracket made out of angle to mount the belts in the vertical position but in the stock reinforced position? I believe that if there was enough belt, then this situation would be better.
I just scored a set off ebarf, both passenger and driver side. I plan on using some of my metalworking skills to try such a bracket. The set I scored appears to have rigid cables/poles attached to the click-in portion.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?Vi...AMEWA%3AIT
if not, then I will have to figure something out here as well.
Mark
78 Auto AC Transporter, very little rust, no engine FS: $500 w/delivery 200 miles
74 Westfalia
Christiansburg, VA
[email protected] |
Posted: Mon Jan 24, 2005 9:45 am Post subject: |
Those look just like mine except for the stiff receivers. Nice!
I'm pretty close to the end of the belt with the retractor mounted where it is. I had initially considered using a bracket made from 1/4" steel until I saw that.  _________________ No boom today. Boom tomorrow. There's always a boom tomorrow.
The Guacamole Bus
Woodscrub's Blog
Buy My Crap |
Posted: Wed Feb 02, 2005 5:54 pm Post subject: Can the belts be lengthened? |
Would there be a possibility of lengethening the belts so that they can mounted in the stock location?
Maybe a piece of selt belt material can sewn at the top mounting location? I am cetain that good uphostelery shop would have the correct thread so that they can be kept strong. A piece of seat belt material can just be cut from a junk car.
Any Ideas?
Thanks,
Mark |
Posted: Wed Feb 02, 2005 5:59 pm Post subject: |
I wouldn't start messing with cutting and such...
Just get seat belts from a van. They will be long enough no problem. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow.
The Guacamole Bus
Woodscrub's Blog
Buy My Crap |
chabanais Samba Member
Joined: July 27, 2002 Posts: 3539 Location: West of the Mississippi River.
Posted: Thu Feb 03, 2005 3:24 pm Post subject: |
There's a reason VW didn't attach their belts to that seperation panel between the front and the rear seats - it's not strong enough. In an accident it'll bend right out.
I bought my belts at gowesty.com and they go in the stock - correct and safe - location. _________________ "I spud therefore I yam."
| Collie wrote: | | The silver socket is sacred and must not be disturbed |
| Serpent7 wrote: | | Keeping in-line with what VW originally had in mind; keeping the bus as close to OEM as possible with a few little changes to give it a "not forgotten look" but still maintaining the charm that made them what they are today. |
Posted: Thu Feb 03, 2005 5:22 pm Post subject: Can someone trace me the bracket on the GoWesty belts |
If someone could trace me the bracket that is attached to the GoWesty belts, it would be greatly appreciated. In this way, I would have an idea of where the two holes on the bottom are drilled (there are two to my understanding, one to mount the belts if one had regular seats, the other to mount if they had the rotating passenger seat).
Thanks!
Mark
Christiansburg, VA
78 Auto AC transporter no engine, very little rust, FS:$500 w/ 200 mile del.
74 Westy |
Posted: Thu Feb 03, 2005 6:57 pm Post subject: |
http://thesamba.com/vw/forum/viewtopic.php?t=92839&start=0
This is the last discussion.
Honestly, tracing it is too much work for me but maybe someone else can help you. _________________ "I spud therefore I yam."
Bajatacoma Samba Member
Joined: August 05, 2003 Posts: 674 Location: the Great State of Denial
Posted: Fri Feb 04, 2005 4:05 am Post subject: |
Do not buy used seatbelts out of a wrecked vehicle! The nylon stretches and they are no longer servicable. Similarly, do not buy them if they are discolored (UV light breaks down nylon) or damaged in any way.
That said, I've got Vanagon seatbelts in my bus too. I used fender washers on the back to reduce the chance of them pulling out. Do a test fit before you start drilling holes; you want to make sure that you will be able to close the doors or rotate the passenger seat in late bay Westys and that they will be long enough. _________________ '78 Westy
Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?
Hunter S Thompson |
