1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Sat Sep 17, 2022 12:46 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
kevinm wrote: |
Looks great, Vik. Congrats!
Q: is the clutch slave cylinder installed backwards? I thought it should be oriented with the hose connection facing the front of the vehicle.
- Kevin |
I'll second that thought. The fact that the bleeder isn't at the highest point kind of proves it.
Cheers,
BK _________________ 1991 tin top GL
Some BMWs. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6357 Location: Honolulu,Hawaii and France
Posted: Sat Sep 17, 2022 1:24 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
1988M5 wrote: |
kevinm wrote: |
- Kevin |
Cheers,
BK |
Yeah, well, you guys don't have a Syncro or you don't wrench on it
The Syncro slave cylinder has the banjo facing towards the rear, to clear the fuel tank. The hydraulic hose connected to it is specific in this sense.
The early 85 models (in Europe) actually had a hard pipe and a flex hose similar to the 2WD, then in 86 they switched to the clear plastic hose style, one piece, eliminating the connection at the base of the reinforcement leg.
I will add, the Topran brand slave cylinder is not threaded deep enough for the factory Syncro banjo bolt to crush the washers, so you either need to tap it deeper or cut the banjo bolt a bit . _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
vik Samba Member
Joined: January 13, 2005 Posts: 204 Location: back in Czech
Posted: Sun Sep 18, 2022 4:09 am Post subject: Re: 7 seater Caravelle Syncro to camper |
ALIKA T3 wrote: |
I will add, the Topran brand slave cylinder is not threaded deep enough for the factory Syncro banjo bolt to crush the washers, so you either need to tap it deeper or cut the banjo bolt a bit . |
Merci Alika
I got Bosch unit. Will test it before assembly to the car. _________________ T3 Syncro camper in progress |
WestiT3_1986 Samba Member
Posted: Mon Sep 19, 2022 4:21 am Post subject: Re: 7 seater Caravelle Syncro to camper |
vik wrote: |
May I ask if anyone has installed the Powerflex from Heritage Collection?
I ordered few bushes and I was expected classic yellow/purple. I'm sure they will be much better than what I do have at the moment. Just asking...
Powerflex don't provide too much info if they are more or less stiff. I quote:
The Powerflex Heritage Collection of bushes has been chosen specifically for your modern classic vehicle.
Manufactured using modern day materials with properties biased for the road, these dark grey coloured bushes will restore, compliment and improve any collector's car, whilst retaining the same standard appearance of a regular rubber bush. |
I just recently installed them on some of the bushes of my 1989 2WD Camper.
I think the material is just the same as the standard powerflex (purple for the T3/Vanagons) stuff- just coloured black, for stealth appearance. This might be of value for things like a heritage numberplates here in Germany- the guys at TUV don't like flashy colors if you want such a plate...
Greets |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Mon Sep 19, 2022 6:51 am Post subject: Re: 7 seater Caravelle Syncro to camper |
WestiT3_1986 wrote: |
Greets |
As I heard they were made not just for the H-plates. The powerflex bushes have no E markings or TUV certification while they are not exact reproduction of OE parts, so there were some difficulties on tech inspection in strict countries like Germany.
The black/grey ones are harder to notice. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
vik Samba Member
Posted: Mon Sep 19, 2022 11:52 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Hallo all
You may be right about Powerflex. I heard similar story, but they mentioned Swiss TÜV.
as much as I would like to keeping the things rolling I do feel there is some slowdown comming in.
At least the frontend is finished for now. If I will have upper and lower bushings available they will be there too. Well next time
While preparing for the nose transplant I notice a wesp nest in front of the driver
And I could not resist to test the new color for the CLK rims
It looks smart in my point of view.
Obviously not all is so great. I discovered that the front step driver side will need some wokr, oh well _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Fri Sep 23, 2022 12:31 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
So the rust fight is on:
I´m wondering if the the front cross panel is available as spare part?
It is nowhere to be find. _________________ T3 Syncro camper in progress |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4096 Location: East Kootenay, British Columbia
Posted: Fri Sep 23, 2022 1:11 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
Yikes! Just goes to show it never pays to ignore that windshield rust. I'm glad I caught mine in time to save the metal.
You're gonna have to get that from a wreaking yard, only the exterior panels are available (afaik). _________________ Currently:
vik Samba Member
Posted: Mon Oct 24, 2022 10:01 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Hi all,
Work continues in painfully slow pace. But fuel as well as water tanks are back in and hooked up.
I got a shipment of remaining Powerflex bushings for:
- upper arms
- lower arms
- rear arms
As well as some bolts. And here is why:
The upper control arm will go to powdedrcoaters as soon as the old bushings will be removed. I´m not sure if they are original or were replaced in the past as I could not find any spot welds. But they are rusted together wery well.
Lower front bushings are long time gone as well. I just feel stupid that this was not done when the radius rods were out.
For cutting trough the bolt is better to use one of those vibrating multi tools or some Reciprocating Saw?
And I got repair panels for my front
Pchill2 Samba Member
Joined: November 19, 2021 Posts: 405 Location: Georgia
Posted: Wed Oct 26, 2022 5:15 am Post subject: Re: 7 seater Caravelle Syncro to camper |
A multi-tool blade has a hard time cutting through a nail. I would recommend using a sawzall to cut your bolt.
Diablo makes the best blades for metal cutting. The carbide blades do cost a bit more but will last you for a long time. Other blades will likely show significant wear just cutting through a single bolt. _________________ 87 Syncro Westy
Honda K24 swap |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Wed Oct 26, 2022 6:06 am Post subject: Re: 7 seater Caravelle Syncro to camper |
+1 on the Diablo blades. I tried using other blades I already owned and it was taking like 10 minutes to cut through one bolt and the blade was trash by the end. The Diablo blades took about 30 seconds and are still good after multiple bolts. Get what you pay for. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Wed Oct 26, 2022 10:43 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Cut through the bushing close to the LCA on the rear portion of the bushing.
Then cut across the hexagonal part of the bolt head many times, use a chisel to break the pieces off. The LCA will then come off easily bc you gained room at the back portion already.
vik Samba Member
Posted: Thu Oct 27, 2022 5:13 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Thank you for tips.
The vibration multi tool was used. I had the saw as backup as there is really not so much space.
Cutting out the bolt was the easiest part Blade used was special one for metal from Bosch profesional range. It was roughly $27 equvivalent. Lifespan - one bolt...
Anyway getting the rest of the bolt as well as bush remains was a REAL hassle. Took me about 4h to do so.
Now new and shiny Powerflex bushes are in place.
I´m really thinking to keep the rear bushes for next time. _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Mon Oct 31, 2022 10:53 am Post subject: Re: 7 seater Caravelle Syncro to camper |
I have decided to give it a shot before the engine and gearbox goes back in.
3 out of the 4 bolts were ok. One rusted to the bushing sleve.
This time I waste no time with the big hammer and cut it out in few minutes.
Rear arms are off the car. Will be painted (no time for powder coating this time)
vik Samba Member
Posted: Thu Nov 03, 2022 10:52 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Just a quick update from the Polybushig work feed
Front upper arms are back not only from powdercoaters, but installed on the car as well
Rear arms are paint in black. While I was doing this my phone decided it would be good time to play paint in black from the Rolling Stones
Next: get the bushings in the rear arms and reinstall the engine _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Mon Nov 07, 2022 12:51 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
So it seems that I´m getting to the end of this part of the rebuild.
Obviously it took much longer and will cost much more than expected.
Quick and easy job was to install the BMW brake booster. I managed (unawared) purchased unit already modified for T3.
Next on my list was final preparation of the engine to mount it in the car. Done.
Rear arms now looks much more cleaner. I got as well new bottom ¨plastic¨ washers between spring and the arm.
Lastly rear right window is out and the rust has been dealed with. I´m lucky this time. No holes
vik Samba Member
Posted: Thu Jan 05, 2023 12:20 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
Happy New Year!
Had time in last few days to get back to my Bus. And we are getting closer to finish straight.
New braided brake lines are installed as replacement of the OE 30 years rubber once. On rear arms copper pipes were replaced for the ¨new and better¨ material too.
kevinm wrote: |
- Kevin |
I remembered this question today as clutch slave cylinder was the last thing to connect in the hydraulic department. And the syncro has it indeed connected opposite direction.
I´m missing last pipe to be connected from water circuit (had to run to catch a train)
Fill up and drain brakes and power steering
Connect vacuum pipes (I even found front locker and decoupler wiring)
Fuel pipes between fuel filter and engine + return
Oil
Charge up the battery
and fire it up.
Than the bodywork and paint BUT this year I shall put more km on the road than last >0 _________________ T3 Syncro camper in progress |
4Gears4Tires Samba Member
Posted: Fri Jan 06, 2023 8:51 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Making good progress! _________________ '87 Syncro
vik Samba Member
Posted: Thu Feb 02, 2023 9:24 am Post subject: Re: 7 seater Caravelle Syncro to camper |
4Gears4Tires wrote: |
Making good progress! |
Thank you. But it was rather slow recently. But I´m moving based on time available.
The kitchen block is finding its way back after it met different type of saws
It is bitter sweet as I paid not that small amount of money for it and seeing the fetish for thin wood screws which you can brake off easily or they are not possible to remove at all make me sad. I can do it better and do not call myself a professional. Oh well..
Metal work is one step forward too. The inner brace and ¨new¨ fresh air duct is welded in and treated with ¨corrosion proof¨ paint. A cavity wax will be sprayed there after the paint.
List is still long, but getting shorter. _________________ T3 Syncro camper in progress |
TinyPickle Samba Member
Joined: December 15, 2021 Posts: 177 Location: Slovenia, Europe
Posted: Fri Feb 03, 2023 12:22 am Post subject: Re: 7 seater Caravelle Syncro to camper |
You're making some good progress
Scrolling back through your post, i saw that you had a nice almost original bullbar mounted, you still have it?
I have a picture of an original TUV for that kind of bullbar, i heard you can make a homologation of the bullbar with this picture..
Interested? _________________ God of rust, have mercy.
WIP - Offroad Spec Syncro - 1.9 TDI AFN - Build Thread
IG: syncro_brothers |
