Sickies Garage Samba Member
Joined: August 10, 2020 Posts: 73 Location: Fort Wayne Indiana
Posted: Thu Feb 02, 2023 8:49 pm Post subject: 1970 Ghia clock |
Mine is not working… who can I send it to to get fixed? |
kent70ghia Samba Member
Joined: June 15, 2020 Posts: 176 Location: Tacoma, WA
Posted: Thu Feb 02, 2023 8:58 pm Post subject: Re: 1970 Ghia clock |
There are some good threads on here if you are inclined to look at it yourself. There is a fusible link that burns out, and can be repaired with a drop of low temp solvent. I took mine apart, cleaned it and put a couple drops of sewing machine oil in it now works pretty good. There are also a couple places mentioned that work on them. Search kenzie clock |
Posted: Fri Feb 03, 2023 4:50 am Post subject: Re: 1970 Ghia clock |
Thank you…
kent70ghia wrote: |
Marcdeb Samba Member
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 791 Location: dallas, tx
Posted: Fri Feb 03, 2023 7:41 am Post subject: Re: 1970 Ghia clock |
I've sent my '74 clock to ClockWks.com in WI _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
Posted: Fri Feb 03, 2023 7:16 pm Post subject: Re: 1970 Ghia clock |
Thank you all! I found a thread which showed the common issue with the clocks. Mine was extremely clean but the fusible link required soldering. I soldered it and it runs flawlessly! I have it hooked up on my bench with a 12v battery. I did notice that the power side of the clock in my car was switched. I’m going to find the correct wire and install a 1 amp fuse in line as suggested. |
