sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Thu Feb 02, 2023 3:18 am Post subject: Shorrock C75BV on a Ghia Cabriolet in Australia |
I usually spend my time on the Ghia forum but that has to change now that I've acquired a Shorrock for my '66 Karmann. This had been a long time coming with many dead ends and diversions but finally a complete set up became available out of the UK. John Moxon helped to get this into my hands and it arrived in Australia during the pandemic. More delays ensued because I'm working in New Zealand and access wasn't possible with closed borders.
Since it was removed from a running 1300 beetle in the UK it is quite possible for it to go right on the car, but it looks a little bit aged and could do with a freshen up. It was also damaged in transit and for that some repairs are due.
First up is to show what I have and then to go about doing a full refurbishment of it and its appendages.
My ’66 is built with a 12 volt system. Originally a 6 volt car It was reasonable to convert to the higher voltage during a full full restoration. So to make the Shorrock work it needed a new 12 volt fuel pump. John organised that to come with the shipment and the old pump he managed to sell to someone who needed it.
There were two carburettors provided. One was right off the previous install and the other is a spare. we have a CD 150 Stromberg and a CD 150 Zenith,
There is an Air filter elbow
And a period Air filter which won’t be used. Instead I propose to plumb the existing oil bath filter by extending the existing tube and revising the provided filter tube so it points vertically. I prefer an oil bath over a filter. Fewer consumables.
I have to get a spare set of belts. These look like a Mintex CUPT374 and a Rootes 9926586. I've looked for those but can't seem to find them. If anyone knows better, do let me know what they are so I can order a set.
I have 2x manifold ends with blow off valves for 1300/1500
and the original rubber manifold couplings.
The blow off valves were seized and I spent a little time with them trying to unbind them. I removed them from the manifold ends
Then I sat them in the vice to try loosen them with some force. I used the handle of a small wooden hammer to push down on the internal piston.
But they wouldn't move until I put a small amount of machine oil on them and that loosened them right up.
I wiped them up and set them aside. Maybe some of you know if that is good enough or if more work is required to get them to spec. I suppose a pressure test of some kind to validate that they open at the right pressure would be something to do.
So here are the broken bits. Poorly packed in transit would be the root cause of that.
The VW stand is broken in one corner. This isn't a difficult TIG repair. There are lots of talented TIG welders out there.
More concerning is the cast iron pulleys both of which are chipped. I have the chipped piece from the larger pulley
The chipped piece is missing from the smaller pulley. I'd like to learn if there are replacements out there. Otherwise I'll have to find someone who can rebuild them.
There are also some studs that got bent in the move. I removed those without difficulty
I also removed the name plate off the unit. I cleaned it up and set it aside. I was amused that the Specification number was stamped upside down. Perfect for life in the southern hemisphere!
And finally a comprehensive series of photos of the blower itself
I have sat it on the bench with an electric drill to rotate it and it spins freely and provides quite a bit of suction at the input and blow at the output. Possibly I only need to do a cosmetic refurbishment but that's not really going to satisfy me. It will look odd going on a motor that was totally stopped down rebuilt and looks like new.
I plan to strip it down and have the outer case water blasted to give it a fresh out-of-the-casting look. All the studs, nuts and washers will be replaced. The same will go with the manifolds and the CD150s.
This will take a while since I'm hoping back and forth across the Tasman but I'm sure it won't take as long as the car to restore.
So stay tuned for the likely infrequent updates.
Cheers for now!
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 383 Location: Minnesota
Fishynos72 Samba Member
Posted: Fri Feb 03, 2023 4:13 am Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
Wrapped to see one down under. _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2005 Caddy panel van
2006 Golf R32 |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13955 Location: Southampton U.K.
Posted: Sat Feb 04, 2023 5:43 am Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
It's going to be a fascinating watch.
I love my Shorrock and have had great service from it over the last 12 years. To say the VW 90 degree version is "rare" is a misuse of the word. I'm pretty confident in saying my Shorrock is the only one running on a Karmann Ghia in the world today...it will be great to have another one with which to compare notes.
The Shorrock back in the day was considered to be the "Rolls Royce" of small superchargers. If you follow Nick's restoration of the supercharger you'll begin to understand why "Rolls Royce" never challenged them over the use of the term in their advertising. _________________ John.
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Fri Feb 10, 2023 4:20 am Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
For those of you unfamiliar with the VW model, it was offered by EMPI for a short time in their 1967 catalog...
The collaboration between Shorrock and EMPI wasn't a great success as very few superchargers were sold. That's not to say the Shorrock Kit for the VW was no good...far from it. Shorrock, as we have seen had the reputation as the "Rolls Royce" of superchargers; far and away the best engineered of all the small superchargers. Unfortunately they were just too expensive to crack the volume VW market of which Judson held a stranglehold. In 1967 the basic EMPI Shorrock Kit sold for $395...at the same time you could buy the Judson Kit for $144. _________________ John.
D-train Samba Member
Posted: Tue Aug 15, 2023 2:47 am Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
Nice!!! Can’t wait to see it running _________________ shiny paint doesnt make it worth any more |
Posted: Wed Feb 21, 2024 12:49 am Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
How far out was your estimate?
Did you have much response for a batch of pulleys? _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Wed Feb 21, 2024 1:20 am Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
I recently bought this and i intend to fit it to my old speed oval at a later date although it will take a lot of work to adapt it to my okrasa 30hp motor. I`m missing the supercharger mount but seen as i`m fitting it to an earlier motor i will have to fabricate my own mount anyway. |
Posted: Wed Feb 21, 2024 1:32 am Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
I saw your post regarding your acquisition.
If it's anything like your Judson it'll be impressive to watch it come together _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
Posted: Thu Feb 22, 2024 12:27 pm Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
sputnick60 wrote: |
Fishynos72 wrote: |
Did you have much response for a batch of pulleys? |
$150 vs $500 for both pulleys
No interest.
Nicholas |
Ouch _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
Posted: Mon Mar 11, 2024 4:54 am Post subject: Re: Shorrock C75BV on a Ghia Cabriolet in Australia |
vwhelmot wrote: |
I marked up a photo for you showing the mounting holes on the C75B that mate to the VW stand.
Circled in red are the mounting points. One is a stud fastened with a washer and nut and the other is a countersunk slotted screw fastening to the C75B body. Only these two support the C75B. Circled in green are bolts with through holes on the face of the stand and there is no support provided at these points. I'm guessing there would be interference with the belt if a washer and nut were sitting under there.
On the other face ( towards the front of the car) are a couple of straps that probably help with the twisting moment. These use a couple of studs and you can see them in the earlier photos. As yet I haven't had a chance to work out how those go.
