t30mg Samba Member
Joined: August 10, 2015 Posts: 18 Location: Battle Ground, WA
Posted: Sat Feb 04, 2023 9:56 pm Post subject: 2110 HP and AvGas? |
I recently bought a seat sand rail and seller built the engine and runs 50% Race Gas. I'm at the airport often enough so I prefer AvGas when I need more stable fuel than pump gas can provide. Anyone else run Av in their VW's?
What he told me about the engine: 2110, 40mm Del Carbs, W130 cam, bronze lifter bores, 37.5 x 40 valves, timing approx 34 BTDC and straight cut gears.
Does this sound like a good setup and what would a realistic Horse Power be for it?
It's compression is high and it's hard to crank through it when cold. I retarded the timing a little, and then alot, and the starter still struggles to power through the compression until the engine is warmed up. Had 2 different stores test the battery and both said it's perfectly good...? |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
slalombuggy Samba Member
Posted: Sun Feb 05, 2023 6:45 am Post subject: Re: 2110 HP and AvGas? |
Check your starter bushing and all the connections for the starter including the ground.
Once I got over 10:1, my factory starters struggled, especially when hot. I bought an IMI gear reduction starter, and even at 13:1, never had cranking issues. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Feb 05, 2023 7:30 am Post subject: Re: 2110 HP and AvGas? |
Unless u can adjust the fuel mixture on the fly ? I would Not use Avgas! Planes can do this, Research & Learn I was a VP Race Fuel dealer at one time,learned about that stuff _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Wulfthang Samba Member
Posted: Sun Feb 05, 2023 9:52 am Post subject: Re: 2110 HP and AvGas? |
Aviation fuel contains deicers and other additives that "ground based" vehicles don't use. Some of them can cause problems like eating your fuel system parts. Plus, aviation fuel uses a different octane rating system than auto fuels. 110 octane aviation fuel is not the same as 110 octane auto fuel.
The worst part though, is that you may be hurting your performance by using an octane rating higher than what you need. A high octane fuel resists knocking because it's slower to ignite. The flame front is not as erratic and is smoother which produces more horsepower than if it were popping all over the place.
If your engine doesn't knock, don't use a higher octane fuel. It burns slower which means less horsepower.
I met a guy one time who insisted that his engine was built so incredibly powerful and hostile, that he had to burn jet fuel in it! He got angry when I laughed at him! |
oprn Samba Member
Joined: November 13, 2016 Posts: 12699 Location: Western Canada
Posted: Sun Feb 05, 2023 10:01 am Post subject: Re: 2110 HP and AvGas? |
Well guess what! Deicer is simply alcohol!! Funny thing is the aviation guys don’t recommend using car fuel in aircraft even though some of their engines are rated for it because the alcohol in it ruins the rubber parts in their carbs!
Yes you will get less power and mileage in an engine using an octane rating higher than it is built for. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Dusty1 Samba Member
Posted: Sun Feb 05, 2023 10:06 am Post subject: Re: 2110 HP and AvGas? |
We used to fly into a hillbilly airport Saturday afternoons. The local Modified heroes would line up to fill their race cars with 100 low lead. Same cars were consistent winners at Albany / Saratoga, Lebanon Valley and Fonda.
Same drivers, same tracks, different cars typically Bicknell modifieds, now. They're still winners.
Our airport used to have a DC-3 tied down out back, a ghost of the Congo wars. Its log book was a mess and its Pratt & Whitney radial engines were far beyond TBO. Story goes since the mid- 1960s every time a conflict lit up in Africa they would fly it across a couple borders and find someplace safe to tie it down for a few years. This went on for decades until someone re- traced the old WWII bomber transport route back to a few miles south of Pratt & Whitney.
Seems to me a Pratt & Whitney radial is just a different arrangement of VW cylinders.
Shane Tuttle Samba Member
Joined: February 02, 2011 Posts: 173 Location: Arlee, Montana
Posted: Sun Feb 05, 2023 10:14 am Post subject: Re: 2110 HP and AvGas? |
Used 100LL in my bug when I was going to A&P school in Colorado. Worked at an FBO and had access to some when we defueled aircraft and the customer didn't want it put back in. Filtered it and it ran fine. I commuted between Broomfield and Lakewood. If memory serves, about 10k miles worth of fuel was used. I cracked open the case a few years later and found no discernable lead buildup or wear beyond normal. Never ate anything in my fuel lines or carbs.
However, I wouldn't start using it in yours until you figure out what's going on with your other problems. |
94touring Samba Member
Joined: October 24, 2020 Posts: 313 Location: Oklahoma - OK
Posted: Sun Feb 05, 2023 11:14 am Post subject: Re: 2110 HP and AvGas? |
Shane Tuttle wrote: |
Did the same thing back in the day but in an Rx7. No issues whatsoever. |
DeathBySnuSnu Samba Member
Posted: Sun Feb 05, 2023 2:30 pm Post subject: Re: 2110 HP and AvGas? |
Well ...... I am old and never ran AV gas in my VW as it was fine with pump premium.
As a youngster in the later 70's to the early 80's we did a lot of street drag racing. All the winners ran a concoction of fuels. Leaded premium mixed with AV gas and a fuel booster additive from the parts store. Everyone swore by it.....I even mixed a lot of it myself for V-8's.
So when I finished high school and had some time I started racing the south eastern motocross circuit.
Side note.....I was a motorcycle guy....was a wrench at the Honda dealer from 15 untill I went to live in a dorm.
So I was at a major race event and tech was more serious than I expected. Fuel was supposed to be pump and I was sitting there with a bike 10cc over max and with the fuel concoction. Luckily they did not check displacement but did take a fuel sample.......and it easily passed tech.....I was amazed......and lost any belief in using AV gas in anything that don't need the anti-icing property it has.
After this point if I wanted certain fuel properties I bought race gas, nitro methane, alcohol, by the drum.
Bottom line.....
Big NO on the AV gas.
For a street engine....build it for today's premium.....or build it for E-85 _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Triumph Samba Member
Posted: Sun Feb 05, 2023 2:42 pm Post subject: Re: 2110 HP and AvGas? |
Years ago I had a conversation with an engineer from Union 76 regarding 100 LL AvGas in race engines. He stated that 100LL formulation is "lighter", i.e., less dense, than regular gas. This means that without adjusting your mixture, you're going to run about 7% leaner with 100LL which can lead to burned pistons etc. By richening the mixture, I was able to bring it in balance with no issues in a race engine. That said, as the engine was tuned to develop more power, it needed a higher octane. At that point I switched to race gas and re-adjusted my mixture.
As you can tell from the comments, there are a lot of factors at play; among them the fact that 100LL is low-lead, not unleaded. So if you have to be concerned with emissions and catalytic converters, that will play in.
It may help to associate octane with the point at which uncontrolled ignition (knock) occurs and BTUs as the available energy in the fuel.
100LL is 5.91 lbs/gal
91 Unleaded is 6.35 lbs/gal |
Posted: Sun Feb 05, 2023 3:21 pm Post subject: Re: 2110 HP and AvGas? |
Both 100ll and pump gas should weigh in at 6.1lbs at 15C. I never saw a difference in air fuel ratios on my wideband going from 100ll to 93 back when I'd run it. At least not that I recall. |
Agavelouis Samba Member
Posted: Sun Feb 05, 2023 3:37 pm Post subject: Re: 2110 HP and AvGas? |
madmike wrote: |
Unless u can adjust the fuel mixture on the fly ? I would Not use Avgas! Planes can do this, Research & Learn I was a VP Race Fuel dealer at one time,learned about that stuff |
Unless you are intentionally trying to be sarcastic, this info is false.
Planes (general aviation typically) do have fuel mixture screws/levers/cables/knobs. It has nothing to do with fuel concentration or type.
They have the ability to change the mixture while flying because of altitude changes along the route. If I take off at an airport that is at 1,100'MSL, I couldn't expect my airplane to work properly at 12,000MSL with the same "tune". There is physically less oxygen up there, and flooding the cylinders with so much fuel is a waste, as well as potentially very problematic. We can slowly pull the fuel mixture lever out and watch RPM drop at a certain point and then enriched a little bit / watch EGT climb, then watch it drop / watch a O2 sensor and fine tune the mixture for our altitude and throttle position. Some pilots run "lean of peak", which is running slightly lean for the throttle position / altitude. They experience good fuel economy at their cruising altitude and don't really hurt the engine with lower power settings.
There is typically only one general aviation fuel for reciprocating engines at most airports these days, which is 100LL (100 / 130 octane, Low Lead) and it is colored blue. If you come across true AVGAS, and you test it and it is clear, it has been contaminated with another fuel - possibly jet / diesel.
Some aircraft have modifications done to allow them to use other fuels, but they are typically not available from the pumps on most major fields. Green color AVGAS would probably be the most available still, and it is rare, as it is full lead 100 / 130 Octane.
I ran 100LL in my prior VW race engines with no issues. I also run 100LL in my Ecotec engines (sealed stock class), due to its properties and its ability to fight vapor locking during the hot summer heat while racing thru Nevada at higher altitudes. You should check your tune with whatever fuel you plan to run, and in a VW, it will run fine. Spending $4-5/ gallon for AVGAS was my cheap way of running race gas essentially, when 100 or 110 race gas was $8-10 / gallon.
DO NOT run it in a modern car, or any other vehicles with a CAT on it. It will ruin the system quite quickly. If you are stuck in the middle of nowhere and need to get out of there, sure a couple gallons in the tank will get you out of harms way, but try to fill the tank with regular pump gas ASAP and be prepared to replace smog equipment. |
Posted: Sun Feb 05, 2023 3:45 pm Post subject: Re: 2110 HP and AvGas? |
Agavelouis is spot on. I flew lean of peak everywhere in piston airplanes. Ideally you guys tune your Vw's at light cruise for lean of peak as well. One other benefit of 100ll is it doesn't go bad as quickly as pump gas. |
modok Samba Member
Joined: October 30, 2009 Posts: 26776 Location: Colorado Springs
Posted: Sun Feb 05, 2023 4:21 pm Post subject: Re: 2110 HP and AvGas? |
should crank easy with that cam.
Starter weak, or something is tight, compression is way higher, or the cam is much shorter than you were told. |
ccowx Samba Member
Joined: May 15, 2015 Posts: 661 Location: Whitehorse Yukon
Posted: Sun Feb 05, 2023 5:11 pm Post subject: Re: 2110 HP and AvGas? |
I have struggled with detonation in a V8 car that I also own. I have been given avgas by aviation mechanic buddies. Due to specific gravity issues mentioned here, it doesn't meter precisely the same through a carb, so I mixed it 50/50 with 94 octane non-ethanol pump premium. Never had an issue and ran great.
Chris |
Posted: Sun Feb 05, 2023 7:55 pm Post subject: Re: 2110 HP and AvGas? |
Yeah, I knew guys that swore by it back in the day but I never used it. We ran a custom mix of Sunoco 260 (From the pump!), upper cylinder lubricant and whatever octane booster was on sale. That mix also worked pretty well for Nitrous boosted systems. Course, this was on motorcycles and all of the car guys I knew, ran Alcohol. (I love the smell of Nitro!) |
oprn Samba Member
Posted: Mon Feb 06, 2023 4:25 am Post subject: Re: 2110 HP and AvGas? |
If there is any fuel surrounded by more myths, old wives' tale or just plain whoppers than avgas I am unaware of it! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Mon Feb 06, 2023 4:50 am Post subject: Re: 2110 HP and AvGas? |
Avgas is made so inconsistent, Tell me Every made batch is the same.
go ahead and use it ,, not my motor _________________ 'Black Ice'Drag Buggy 'Turbo'
Paul Jr Samba Member
Posted: Sun Feb 12, 2023 6:02 am Post subject: Re: 2110 HP and AvGas? |
My issues with hard cranking on a bigger engine went like this.
Replaced and cleaned grounds, engine cranked a little better but still hard.
Replaced starter bushing, engine cranked still slow and hard but started.
Sat and thought why? Then looked at engine run stand and saw the starter on it was from an automatic. Also looked and realized every other VW beetle based vehicle here has an automatic starter or an aftermarket high torque starter.
Went and got a rebuilt automatic starter from the local auto parts store, it fires one hit everytime now.
For comparison it’s a 2275 with 12:1 compression |
