bluebus86 Banned
Posted: Mon Mar 02, 2015 8:40 pm Post subject: 1966 1300 cc intake manifold |
Is the intake manifold for a 1966 1300cc Bug still available new? If so from what vendor(s) I cant seen to find a new one.
On mine the heat pipe is hopelessly clogged, and the pipe has developed rust thru holes (interior is rusting thru to the exterior)
thanks _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
DuaneL Samba Member
Joined: February 02, 2012 Posts: 511 Location: Spokane WA
Posted: Mon Mar 02, 2015 8:43 pm Post subject: |
it is the same manifold that the 1500-1600 single port uses, VW Intake Manifold, 1300-1600cc Single Port, 113-129-701K available from most online vendors _________________ ____________
1971 std bug, 1776, ACN Super Stock 34-3, dvda dist, 27x8.50 14 tires |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 471 Location: Illinois
Posted: Tue Mar 03, 2015 4:05 am Post subject: |
I would second asking Branston. He redid an intake for me and it came out and works perfect. The originals fit much better than an aftermarket. Casey _________________ 1966 Java Greens |
bluebus86 Banned
Posted: Tue Mar 03, 2015 6:12 pm Post subject: |
Ok, thanks for the info.
My manifold is the "K" version so maybe it was replaced at one time OR maybe the car got a "k" version at the factory???? The car was bought new in April 1966 in California and only has about 70k miles on it. (verified original miles per original owner). I doubt this car was built near the end of the 1966 model production. But maybe some "K" manifolds maybe were used back then????
On the list that is posted above I do not see a "K" manifold listed.
On the other post I see written that some "K" manifolds are made aftermarket with a vacuum port added, My "K" manifold has no such port.
So does anyone know if the "K" manifold might have been put on some 1966 Bugs at the factory? Or do the experts think that this "K" manifold was swapped out for my original "J" at one time???
I'd like to order a replacement, and I would prefer to get one with the same number that was on the car when the car was made. If the "K" type was possibly fitted at the factory on a 1966 Bug then I would likely go for a "k" replacement, else I will get a "J" replacement.
Any clues on this "J" verses "K" issue for 1966????? Was the "K" type produced by April of 1966????
thanks again!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Mar 03, 2015 7:17 pm Post subject: |
I don't think the K was ever on a 66. The above list is a 66 parts list so it is not there. After the K it goes in alphabetical order, K, L, M until the dual ports, I think. All the aftermarkets are K that I have seen and have a vacuum outlet on them. If you are looking online at pictures the J manifold has the part number cast into the front of manifold and the others are on the rear. I have a K manifold on my 66 now that I bought on the classifieds here and had shipped to Branston. It came back good as new or better. I have a J hanging in the garage. PM me if interested. It needs restored but no rust. I helped a fellow Samba member in my area last Summer who was having troubles with his 66. He had bought an aftermarket K manifold and it did not fit as well as it should. If you sprayed starting fluid at the top of head/manifold RPM's would change. Took it off, put on another set of german copper gaskets, same deal. Good luck. Casey _________________ 1966 Java Greens |
Posted: Tue Mar 03, 2015 7:44 pm Post subject: |
This one just popped up on the classifieds, In Anaheim. Not sure where you are. If you enlarge photo, it looks like part # is on the front. Maybe what you are looking for? http://www.thesamba.com/vw/classifieds/detail.php?id=1760138 Best of luck. Casey _________________ 1966 Java Greens |
Posted: Tue Mar 03, 2015 8:32 pm Post subject: |
My 66 has the original "case" it also has a "K" intake manifold and 1500/1600 SP heads. It was built in Feb 1966. I guess that it was replaced at some point due to clogging. In the parts list on OACDP.ORG there is no mention at all of the "J" intake manifold. So by 1971 (date of parts list on oacdp.org) I assume that the replacement available from VW was only the "K" version. I have also searched progressive refinements to see if there is any mention of an intake manifold change in 1966 for the F0 engine but could not find anything.
http://oacdp.org/type1part/1168.png
http://oacdp.org/progref6268/k005.jpg
If anyone has more information. I would love to see it as well. _________________ View my 66 build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=507996 |
notsnarb Samba Member
Posted: Tue Mar 03, 2015 8:42 pm Post subject: |
Thank you for the mention guys.
The 701 J is correct for the 1300 F case engine and the 701 K was specific to the 1500 H case engine.
I have a few cores available of J & K intakes I'm just bit behind with intakes due to the annual surge in inquiries and a backlog due to an injury, if the OP contacts me i can help him. A word of advise get a seller to guarantee the heat risers are clear before parting with your $$$. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Feb 05, 2023 8:16 am Post subject: Re: 1966 1300 cc intake manifold |
Eight years later I'm digging up an old thread.
Background: Early (August '65) 1966 Beetle with original engine that was upgraded with 1600 P&C and '70 heads. Original distributor (113 905 205K)
and fresh 30 PICT-1 with power circuit. I understand that the original intake manifold would have been 113 129 701 J but 113 129 701 K is a valid replacement in this situation.
When I bought the car 18 years ago (before the 1600 upgrade) it had, and still has, a 113 129 701 AA manifold that has evidence of heat riser
cleaning (looks like it was drilled and welded shut). I suspect that it might be clogged again.
So my question is------what is the 701 AA manifold actually off of?
Should I get a "J"? Or a "K"? or leave well enough alone ?
By the way, the car runs great in warm weather and is seldom driven when
cold.
EDIT: This might be part of my problem:
https://www.youtube.com/watch?v=5XcKBmdfpWs
mukluk Samba Member
Posted: Sun Feb 05, 2023 10:49 pm Post subject: Re: 1966 1300 cc intake manifold |
iowegian wrote: |
cold. |
I'm pretty sure 113-129-701AA is a replacement single port manifold for either an H5 series 1500 or B6 series 1600 with a standard transmission. Either way, it would be a good pairing with your 1500/1600SP heads.
You should be able to use a 113-129-701K or M as well, or in a pinch the 113-129-701N if you block of the large Autostick port. The only "J" manifold I can find information for is 111-129-701J, which is a 40hp Saxomat manifold. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Feb 06, 2023 3:07 am Post subject: Re: 1966 1300 cc intake manifold |
Thanks for the info, Mukluk. I'll just leave well enough alone (and maybe someday investigate whether or not the heat riser is actually restricted). |
67conv Samba Member
Joined: July 10, 2005 Posts: 386 Location: Simi Valley, California
Posted: Mon Feb 06, 2023 7:39 am Post subject: Re: 1966 1300 cc intake manifold |
Just one more log to toss onto the '66 1300 manifold discussion campfire....
In addition to the casting numbers facing front (out of sight) on the '66 "J" 1300 manifold, the actual DIAMETER of the "J" manifold is slightly smaller than the later 1500 "K" series manifolds - although fitment on the engine is the same. Probably not noticeable, unless comparing the two different manifolds side by side. _________________ 1967 VW Convertible, owned /driven /pampered for 34 years.
1957 DKW 3=6, owned /driven /risen from the dead for 20 years.
Previously owned: 72 "Baja Champion SE" Spec. Edition Super Beetle bought NEW; 79 Convertible bought NEW; 67 type 1 savanna beige; 67 2.0 911S; 73 2.4 911T; 63 356 T6 B Cabriolet; 64 356 SC sunroof coupe; 72 Type-3 Squareback; 68 + 69 Type-3 Fastbacks; 87 Vanagon GL Wasserboxer |
