Semper Gumby Samba Member
Joined: November 30, 2022 Posts: 99 Location: Southwest Florida
Posted: Mon Feb 06, 2023 9:39 am Post subject: Re: 1968 Beetle (farm find) restomod build |
While 1968 lacked the defroster window option (PO added the defroster window), VW had the wiring holes present in my September 1967 build
I figure these will need to be welded close _________________ "If you don’t have time to do it right, when will you have time to do it over?" - John Wooten |
Posted: Mon Feb 06, 2023 9:45 am Post subject: Re: 1968 Beetle (farm find) restomod build |
All great plans of mice, men, and that my wife doesn't bury under the garage floor are hanging on the contents in this box -
And, I finally received the two (2) air filter canisters to help battle the SWFL humidity when we go to use the plasma cutter and later paint the body
Posted: Mon Feb 06, 2023 9:52 am Post subject: Re: 1968 Beetle (farm find) restomod build |
After removing a fair amount of rust / sludge / 6V solenoid cut off valve, I thought best to let a pro handle the carb rebuild.
SOLEX 30 PICT-3 packaged and sent off to Tim for rebuild.
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4419 Location: Stuck in Ohio
Posted: Wed Feb 08, 2023 11:26 am Post subject: Re: 1968 Beetle (farm find) restomod build |
Buggeee wrote: |
I have that Motorguard toilet paper filter on my air compressor and it works great. |
For southwest Florida - it's nearly impossible to keep the air dry - just short of buying a refrigerator system - which seems a bit overkill for my garage.
I have two (2) MotorGuards in parallel with the 60 ahead of the 30. I added a smaller filter system to the plasma cutter just for kicks. _________________ "If you don’t have time to do it right, when will you have time to do it over?" - John Wooten |
Posted: Wed Feb 08, 2023 11:33 am Post subject: Re: 1968 Beetle (farm find) restomod build |
Gantry crane is done and up. Waiting on 2x3 angle from my old company so I can drill it and then attach the Harbour Freight electric hoist to the I-beam.
When the hoist is operable, lift & mount the engine to Kevin Kraum's 4-arm yoke and then drill out the slots for the engine stand.
Funny I "restored" the 1965 VW Beetle in a garage 1/2 the size of my current garage AND had my second FJ40 project on going too.
Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Wed Feb 08, 2023 12:12 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
Be careful with that crane, it doesn’t look very sturdy, much less have a large enough base should the body get a bit of sway when raised a bit.
And if those casters are steel, they will give that epoxy floor hell. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Feb 08, 2023 12:47 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
TDCTDI wrote: |
Be careful with that crane, it doesn’t look very sturdy, much less have a large enough base should the body get a bit of sway when raised a bit. |
I thought as much on stability. That said, I hung off of the Titan and it’s surprisingly sturdy.
But I hear you on the sway factor, I’ll raise the body and immediately place it on a cart for storage. My wife can easily manage spotting.
As for the epoxy floors, any suggestions on managing that one? I also have the engine stand with similar wheels. _________________ "If you don’t have time to do it right, when will you have time to do it over?" - John Wooten |
toxicavenger70 Samba Member
Posted: Wed Feb 08, 2023 1:29 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
Semper Gumby wrote: |
As for the epoxy floors, any suggestions on managing that one? I also have the engine stand with similar wheels. |
I use sheets of MDF on top of the floor to keep it from getting damaged. |
Posted: Wed Feb 08, 2023 1:33 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
toxicavenger70 wrote: |
Never thought to use fiberboard - are you using 1/4", 1/2" or 3/4"? _________________ "If you don’t have time to do it right, when will you have time to do it over?" - John Wooten |
Posted: Wed Feb 08, 2023 1:56 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
Cover it with several sheets of plywood, at least until the heavy shit is done. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Feb 08, 2023 1:57 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
TDCTDI wrote: |
Cover it with several sheets of plywood, at least until the heavy shit is done. |
"For the want of a nail" - my wife thought it would be cheaper for me to hire the day labor guys that sit outside of the Home Depot
it is starting to seem so. _________________ "If you don’t have time to do it right, when will you have time to do it over?" - John Wooten |
Posted: Wed Feb 08, 2023 2:01 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
Definitely, except the part that you would be inviting the unknown into your space. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Feb 08, 2023 2:03 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
TDCTDI wrote: |
Definitely, except the part that you would be inviting the unknown into your space. |
The supervisors are up to the task
Posted: Wed Feb 08, 2023 2:14 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
You must have defective chocolate labs, most of them are only dangerous if you were a ham sandwich. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Feb 08, 2023 2:21 pm Post subject: Re: 1968 Beetle (farm find) restomod build |
Just need to mount the hoist and then we can get to the next phase with this Bug
Posted: Wed Feb 15, 2023 7:49 am Post subject: Re: 1968 Beetle (farm find) restomod build |
The boss lady wanted to take the FJ40 out for Valentine's Day date. So, I burned a weekend performing an excorcism on my FJ40's electrical system, I never anticipated it would take as long. I paid for my mistake of leaving the original wiring harness in tact during the rebuild.
Back to the less complicated VW -
Best laid plans of mice and men at it again, prior to removing the fuel tank - I tripled checked the fuel line's viability to hold these fuel line clamps. Seemed good and flexible (cleared clamps of brake line before lifting)
But Murphy's law struck me
The line break resulted in a 1/2 gallon of gas on the floor (kept in tank to keep rust off the bottom) which forced the garage supervisor to call it a day
Earlier in my vehicle search, a forum member posted to look for a mouse nest - well found parts of it
And more wasps
And rust where water collected during the Bug's long sleep
And the PO must have had a special wrench for this one
Posted: Wed Feb 15, 2023 9:58 am Post subject: Re: 1968 Beetle (farm find) restomod build |
That’s pretty common. 7mm removes the bleeder valve, then you can get a 14mm flare wrench on the hose. It does help to tighten the hose a bit further so that the flat provides a bit more clearance. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Feb 21, 2023 10:30 am Post subject: Re: 1968 Beetle (farm find) restomod build |
I can only imagine what the shop supervisor is thinking besides my wife is the one that drilled the holes
The gantry crane & electric hoist is a game changer for this aging Marine
Not much more the shop supervisor could give today -
He seemed peeved that the first mate forgot his IPAs for the trip
