nize Samba Member
Joined: June 21, 2004 Posts: 531 Location: Sweden - Cheesy town
Posted: Tue Dec 25, 2012 2:30 am Post subject: Wiring loom routing... |
I am about to do the nose and headlight bulb support on my 54 but since my bus were so bad I have no reference in how the loom travels from the fuse box to the front right chassis frame rail? (I have got a LHD bus).
Is it routed behind the headlight bulb support inisde the bus or does it go inside the front valance? _________________ ----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Tue Dec 25, 2012 5:05 pm Post subject: |
Nize
the main loom piece travels down in front of the headlight support panel
held in place by double prong clip (A)
then through a hole (B) in the forward area of the passenger front cab floor panel, behind the front valence
then travels backwards on to the inner edge of rhs main chassis rail
RS
headlight support panel has 2 shaped recesses where the loom passes through the forward cab floor area _________________ -StockRocks- |
nize Samba Member
Posted: Wed Dec 26, 2012 12:15 am Post subject: |
That was really helpfull pics! Thank you! _________________ ----------(VW)----------
1954 Kombi
marius71 Samba Member
Joined: July 22, 2012 Posts: 22 Location: Switzerland
Posted: Wed Apr 18, 2018 1:40 pm Post subject: Re: Wiring loom routing... |
Sorry, I know it's an old thread.
I urgently need the position from middle and the diameter of the two (three) holes discussed here.
1. hole for main wiring loom
2. hole for ?? small cable (brake pressure switch?)
3. speedo wire
If anyone could help out... and yes, only 28 days to go until leaving home.
And no, I can't use the pattern of the sheet metals. Someone welded a later floor in |
Posted: Thu Apr 26, 2018 5:10 am Post subject: Re: Wiring loom routing... |
Anyone?
Thanks
marius71 wrote: |
3. speedo wire
_________________ --------- VW ---------
52 BD Type 221
and some others |
Merlin Samba Member
Joined: August 19, 2004 Posts: 2103 Location: South Africa
Posted: Mon Mar 13, 2023 10:06 am Post subject: Re: Wiring loom routing... |
Hi everyone,
I'm sifting through years of forum posts trying to find answers to a myriad of questions.
I am unfortunately a very isolated barndoor owner in my part of the world, so I am heavily reliant upon the Internet community...
After [far too] many years, my RHD '54 Kombi has arrived home, following extensive metal work. It was largely stripped and left for dead several decades ago, so I had precious little to reference and salvage as investigative material.
We've replaced the cab floors and I've only now discovered that there appears to be a dearth of holes for the wiring harness. This is the current setup:
Which holes am I missing?
Critically, does anyone have measurements and dimensions for any missing holes, please?
Thank you. _________________ the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote: |
People who are allowed to have signature lines annoy me. |
myklsmyth Samba Member
Posted: Mon Mar 13, 2023 12:01 pm Post subject: Re: Wiring loom routing... |
Hoping that this might help you a bit. If you need dimensions, I could get them for you. I will say that I don't know if they are different between LHD and RHD but here are a few pics of my 52, LHD front floor. Unfortunately the pass side is rusted and I'm not sure what may or may not have been there. Mike
Merlin Samba Member
Posted: Tue Mar 14, 2023 2:00 am Post subject: Re: Wiring loom routing... |
Thank you very much, myklsmyth.
I have asked the question on a FB group too, in the hopes of finding a RHD bus as a reference.
I want to make 100% certain that there are no differences between LHD and RHD in this respect, before we start drilling...
I will update you ASAP and take up your kind offer if they are the same. _________________ the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote: |
BeaterBarndoor Samba Member
Joined: December 15, 2000 Posts: 824 Location: North Carolina
Merlin Samba Member
Posted: Tue Mar 14, 2023 5:25 am Post subject: Re: Wiring loom routing... |
Thanks, Beater.
Looking from underneath my bus, I cannot see those holes. I definitely think I have a problem on my hands... _________________ the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote: |
