vanderjw Samba Member
Joined: July 12, 2014 Posts: 107 Location: Wayland, Michigan
Posted: Sun Mar 19, 2023 5:03 am Post subject: Brake Switch |
Quick questions about the brake lights:
-The master cylinder has 3 ports on the front. I assume one for each front brake line and one for the switch. If that's right, then I plan to put the switch in a port on the left side facing down at a 45 degree angle.
-The wire to and out of the switch is 12v or ground. Seems like it should be 12v.
Thanks and I did search, did not feel like going through 356 results |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Mar 19, 2023 7:03 am Post subject: Re: Brake Switch |
Typically (most that I have seen) has brake light switch in the end port....
_________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Sun Mar 19, 2023 7:08 am Post subject: Re: Brake Switch |
Mine does not look like that. It is for a dual master cyl reservoir and has 5 ports. A quick search shows I probably have one for a super beetle with 4 wheel disc brakes, 20.6 mm. EMPI 2-2808. |
DeathBySnuSnu Samba Member
Posted: Sun Mar 19, 2023 8:22 am Post subject: Re: Brake Switch |
I also have that master.
Yes the TWO downward angled holes are for the two brake light switches. _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Posted: Sun Mar 19, 2023 9:28 am Post subject: Re: Brake Switch |
Do you think I could just use 1 and plug the other? |
Posted: Sun Mar 19, 2023 9:30 am Post subject: Re: Brake Switch |
Do you mean this one...
IF so it takes dual switches if used in standard application...
Posted: Sun Mar 19, 2023 9:33 am Post subject: Re: Brake Switch |
Dale M. wrote: |
Do you meaqn this one...
Yes! |
Posted: Sun Mar 19, 2023 12:17 pm Post subject: Re: Brake Switch |
Yes you can plug one. Empi does have a 10 x 1 plug for that.
That being said.....I have not had much luck with the plug.. ..I had a two pack and neither seated and sealed right (leaked).
I wound up putting the second switch in the hole and bam.....no problems.
All depending on your electrical needs....warning lights ect.....you can choose a two pole or three pole.
I did not make an alarm light.....so two of the two poles to wire in parallel, so that either one can make the brake light circuit. _________________
modok wrote: |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sun Mar 19, 2023 6:55 pm Post subject: Re: Brake Switch |
I only use one switch on my buggy. I took one of the brake light switches to a good old-fashioned hardware store and got a brass plug to match the threads. It's been leak free for about 10 years now.
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
EVfun Samba Member
Posted: Mon Mar 20, 2023 8:39 pm Post subject: Re: Brake Switch |
This is the plug I used. I actually used 3 of them, one on each brake switch plug and one on the top outlet of the dual circuit master cylinder. The brake switch ones because I installed a mechanical switch on the pedal arm. The upper one so I could mount the Volvo master cylinder reservoir "backwards" with the side flat toward the firewall, because it's a bit shapely forward.
I see that number is out of stock now, you might be able to use BQ19, it is in stock and 3/8-24, that size *almost* interchanges with M10, but you cannot torque it too much or it strips. _________________
Wildthings wrote: |
jspbtown Samba Member
Posted: Tue Mar 21, 2023 9:44 am Post subject: Re: Brake Switch |
Or you could install both switches, use just one, and have one in place for one fails...which they always seem to. |
Posted: Wed Mar 22, 2023 12:22 pm Post subject: Re: Brake Switch |
Great Ideas...
I am looking for a double male adapter that is like a brake line on both ends. M10x1.0 by M10x1.0 Male/Male. Seems simple to find but for some reason I cant. If I have to use a short brake line, I will. Its to install the EMPI residual pressure valves I have. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
y2kbaja Samba Member
Joined: March 07, 2016 Posts: 93 Location: Sacramento
Posted: Thu Mar 23, 2023 12:37 pm Post subject: Re: Brake Switch |
vanderjw wrote: |
Great Ideas...
I needed a male-male brake line adapter and just made a brake line 3" long. |
