slave1pilot Samba Member
Joined: February 22, 2010 Posts: 943 Location: Tehachapi CA
Posted: Tue Sep 13, 2022 5:20 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
bought a pressure washer powered sand blaster to get to hard to reach areas
It was like $35US on Amazon
I used it to hit the area under the fuel tank
It made it look like this
Not perfect t but much better
I also hit in between all the rear vents (That’s why I bought it )
I dont have any good pics of it before
Just this one
Here’s he after
Unfortunately , the sand is now waterborne
So my car has a nice patina now
Time to get the DA sander back out _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Tue Sep 13, 2022 5:35 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
So my car has a nice patina now |
Why not just spray Ospho on the rusted bits and convert them to iron oxide?
Spray it, and roll the body into the garage for the night. Problem solved. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Sep 13, 2022 7:34 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
I dont Mind sanding the body again
I wanted To get the paint and rust from in the areas I showed
I was Considering OSPHO on the areas with surface rust that I cant get to _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
Busstom Samba Member
Joined: November 23, 2014 Posts: 3849 Location: San Jose, CA
Posted: Tue Sep 13, 2022 9:09 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
slave1pilot wrote: |
Not for the satin finish...I use a DA sander with grits up to 180 to get the satin look |
Ahhh, got it. Thanks. |
Posted: Wed Sep 14, 2022 6:57 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
OSPHO ordered
Be here by my next days off
I hope |
You can buy Ospho from Home Depot. It's in the paint department.
I can imaging Home Depot is quite a drive from Tehachapi.
Ospho is as thin as water. So you can put it in a spray bottle and hit all the area's that you can't with a brush.
Just make sure to wear gloves and a long sleeve shirt you hate, when you spray it.
Safety glasses and avoid breathing the mist too! _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Thu Sep 15, 2022 3:08 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
We actually have a Home Depot here in town
It doesn’t carry OSPHO
We are a smaller community and we don’t have a gigantic Depot, so we can’t get everything locally
It’s fair trade off for lower crime and quiet living , so I’ll take it lol _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Wed Oct 12, 2022 11:25 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
I used the Ospho in the hard to reach areas
It worked really well
I didnt take pics, sorry
But I did take the DA sander to the the surface rust I created when I sand blasted
I’m getting really close to priming the body _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Thu Mar 16, 2023 2:11 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Ol’ Herb emerged from hibernation today
I pushed everything could out of the garage so I could clean up a little
That gave me a little room to work , even if it’s all shoved out to the walls
I took a look at the engine sitting in the sun
I was sick of it being on the stand and decided to take it off
Mrs.slave1pilot wasn’t as enthusiastic as I was to pull it off the stand and on to the Jack
But it was no problem
Since it’s off, I decided it was time to mate it to the trans
Probably be harder to work on it that low to the ground but it’s progress
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Thu Mar 16, 2023 8:38 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Those almost look like old-school copper exhaust nuts holding the case halves together. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
Dusty1 Samba Member
Posted: Fri Mar 17, 2023 3:54 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
That's what we call an "open motor". I see numerous openings for critters and debris to get inside. I could tell the story of Zeke the Freak's Gene Berg motor eating itself alive on break- in. An 8mm nut down the intake will do that. Then there was the one I built that squealed like there was a tiny fiddler inside. Turns out my brother stuck a 3/8" bolt in a vice, hacked it off and couldn't find the cutoff. He couldn't find the cutoff because it went down the intake of my motor in the other bay. Fortunately that debris couldn't get past the valve stem. It made an unusual squeak when the motor was running.
Posted: Fri Mar 17, 2023 2:36 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
It’s possible those are exhaust nuts, they are the same thread and pitch
The engine is covered all of the time
I only take the cover off to work on it or do pics
I understand your concern though _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 348 Location: Noblesville, IN
Posted: Tue Mar 21, 2023 7:44 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
Dusty1 wrote: |
That's what we call an "open motor". I see numerous openings for critters and debris to get inside. I could tell the story of Zeke the Freak's Gene Berg motor eating itself alive on break- in. An 8mm nut down the intake will do that. Then there was the one I built that squealed like there was a tiny fiddler inside. Turns out my brother stuck a 3/8" bolt in a vice, hacked it off and couldn't find the cutoff. He couldn't find the cutoff because it went down the intake of my motor in the other bay. Fortunately that debris couldn't get past the valve stem. It made an unusual squeak when the motor was running |
Agree. I put masking or duct tape over all engine 'holes', even if I'm simply removing/reinstalling something and regardless of how long it's going to sit. I've seen and heard of too many cases of nuts/washers, rocks and other debris (even mice) finding their way into an engine. _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
Posted: Mon Apr 17, 2023 6:19 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Stripping the under hood area the past couple of days
So much work to get it down to bare metal
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Mon May 22, 2023 9:33 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
took a little break to freshen up the sandrail to sell it off
I repainted it, added new seat covers, and replaced the shift knob
Before
And after
You can see the new shift knob here (I added a new steering wheel too)
And the seat covers
I also forgot new plug wires
I’m pretty happy with it
I’m only selling because I didn’t take it out last summer, and only once the summer before _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Tue May 23, 2023 7:03 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
Nice looking sandrail! When I lived in California, my parents had a cabin near California City (actually a town called Cantil, near a spot called Jawbone Canyon which was very popular for off-roaders), not far from Tehachapi. Damn I miss those days... _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Tue May 23, 2023 7:35 am Post subject: Re: My 63 body on a 59 pan Herbie project car |
That’s exactly where I used to take it.
We would go to Jawbone and the surrounding areas
There’s lots of trails out there.
Small world _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Wed Aug 09, 2023 4:24 pm Post subject: Re: My 63 body on a 59 pan Herbie project car |
Sold the sandrail last week to one of my employees for $3500
He’s very happy with it
I finally got moving on Ol’ Herb again
New tires mounted to the 15x6 wheels
I went with 205/60R15 all the way around
Let me know what you guys think _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
