ohiovw Samba Member
Posted: Mon Mar 20, 2023 2:07 pm Post subject: seatbelts |
My seat belts are all ratty in the front and dont exist in the back. Can anyone recommend any good options? _________________ -Will
1969 bay window |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Sven F Samba Member
Joined: July 24, 2009 Posts: 92 Location: Croatia / Denmark
Posted: Mon Mar 20, 2023 4:45 pm Post subject: Re: seatbelts |
I would just go to a junkyard and get something off a newer car or van. Most of that stuff is similar and if not a direct replacement, it should be easily adapted. |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1196 Location: Vancouver, BC
Posted: Mon Mar 20, 2023 5:20 pm Post subject: Re: seatbelts |
I found a free set on Craigslist from a Delica for my 76 Westy and used a set from a Honda Civic for my 73 Panel in the past. _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Mar 20, 2023 5:27 pm Post subject: Re: seatbelts |
Seatbeltsplus in oceanside
https://www.seatbeltsplus.com/shop.html _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
KTPhil Samba Member
Posted: Mon Mar 20, 2023 11:22 pm Post subject: Re: seatbelts |
Nice kit, but the B-pillar shoulder mounting needs longer bolts and spacers to hang right. |
Posted: Tue Mar 21, 2023 6:06 am Post subject: Re: seatbelts |
Its important to get extra long front belts _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
KTPhil Samba Member
Posted: Tue Mar 21, 2023 8:35 am Post subject: Re: seatbelts |
The longer bolt at the top/shoulder mount will let the eyelet swivel, which it must do to fit correctly. Mine hangs at an odd angle, so I'll be checking for longer, sleeved/stepped bolts. I may have some lying around, I just haven't bothered yet. The belts and latched seem well made, and they fit the Bus. |
metahacker Samba Member
Posted: Tue Mar 21, 2023 3:03 pm Post subject: Re: seatbelts |
for the front, these are very nice
https://bus-ok.nl/Type2-Bay-Automatic-Safety-Belt-...45m-lenght
listen to gary - you want to make sure they are extra long - for example, the linked ones are 136" ..
the length is needed ... you know, if you want to ever roll your passenger side window up and down .. or properly do your "bus-driver lean" on the steering wheel when you're hanging out in traffic .. if you are not rocking a dad bod, and can still wear clothes from H&M in normal sizes, then maybe you can get by with the 3.2m belt ... YMMV, but i would go with the 3.45m every time .. i've tried shorter
you will also want the receiver to be rigid or semi rigid, and a minimum of about 12" long (just a tad longer is ok too)
you may need some hardware (particularly, the angle metal used mounting the reel)
similar to these https://bus-ok.nl/Type2-bay-cab-seat-belt-brackets-pair-VW-bay-867-779-OEM-partnr211809257
this is a nice, standard style manual adjustable rear belt ..
Securon brand, very nice quality
https://bus-ok.nl/Rear-Lap-Seatbelt-for-All-T2-and-T3
if you want to go 3 point or retractable in the rear, things get a little a bit more complicated
there are reproductions of the Swedish market rear 3 pt brackets, if you want to fit retractable 3 pt belts in the back. they are relatively straightforward on a full width bench in a non-camper, for the outer 2 seating positions. anything other than that gets more complicated. the center seating position will still get a lap belt with the rear 3 pts.
you can get the 3pt brackets here
https://www.heritagepartscentre.com/us/catalogsearch/result/?q=belt%20bracket
ReproWesty also makes a 3 pt bracket for the closet side of the Berlin interior (e.g. 76-79 US Westie), if that's something that might tickle your fancy |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Mon Apr 03, 2023 1:54 am Post subject: Re: seatbelts |
This is one of a pair of Kangol "Reflex" inertia-reel seat belts, retro-fitted to my British specification, 1973 VW "1600" Type 2 Westfalia Continental motor-caravan, which I salvaged at the local car breaker's yard during the mid-1990s, from a 1970s vintage BLMC Triumph Toledo or Dolomite, of the same type as fitted to my British specification, 1974 BLMC Triumph Toledo 1300 "HL Special".
The female belt buckles from the Toledo or Dolomite would have been much too short, so I salvaged some longer compatible ones on steel-wire stalks, that were fitted in the front cab of a Ford Transit van, which had Kangol static seat belts.
For a neater installation, I had supplementary seat-belt mounting points, welded onto the back of the bulkheads and front wheel-arches, bridging the seat pedestals forming the tops of the front wheel-arches.
metahacker wrote: |
If you want to go 3 point or retractable in the rear, things get a little a bit more complicated
There are reproductions of the Swedish market rear 3 pt brackets, if you want to fit retractable 3 pt belts in the back. they are relatively straightforward on a full width bench in a non-camper, for the outer 2 seating positions. anything other than that gets more complicated. the center seating position will still get a lap belt with the rear 3 pts.
https://www.heritagepartscentre.com/us/catalogsearch/result/?q=belt%20bracket |
I am not sure how these rear seat-belt mountings from VW Parts Heritage in England would be used, but the prices of $153.95 each are horrendous!
https://www.heritagepartscentre.com/us/catalogsearch/result/?q=rear%20seat%20belt%20mounting
https://www.heritagepartscentre.com/us/211857693l-seat-belt-mounting-bracket-rear-left.html
https://www.heritagepartscentre.com/us/211857693r-seat-belt-mounting-bracket-rear-right.html
I am not sure whether these are exact reproductions of the supplementary rear seat-belt mountings, factory-fitted to Swedish specification, 1968~79 VW Type 2s!
_________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
