Kubelwagen steering wheel options
titan
titan is offline
PostPosted: Tue Feb 07, 2023 7:08 pm    Post subject: Kubelwagen steering wheel options Reply with quote
Hi guys, I have a 1974 thing that has been sort of converted into a look alike WW2 kubelwagen. I'm looking for a simple style steering wheel that would fit along with this concept. I'm hoping for a steering wheel option that will bolt on without any significant welding or fabrication. Any recommendations?
Thank you
waterdawg2004
waterdawg2004 is offline
PostPosted: Sun Feb 12, 2023 11:36 am    Post subject: Re: Kubelwagen steering wheel options Reply with quote
Tractor supply has simple and cheap steering wheels. I do not know yet if they work or not. Might be something to check out.
1976 Bus Westphalia Yellow, with 914 engine, single carb
1974 Thing, converted to look like kubelwagen
1979 Orange Bus Transporter, stock, FI
BNMike
BNMike is offline
PostPosted: Mon Feb 13, 2023 7:59 am    Post subject: Re: Kubelwagen steering wheel options Reply with quote
I'm interested too. Right now 'Hermann' has a stripped stock wheel. I'd like to find a reasonably priced 3-spoke wheel that fits a '73.
Mike
waterdawg2004
PostPosted: Mon Feb 13, 2023 7:26 pm    Post subject: Re: Kubelwagen steering wheel options Reply with quote
Might work?
Or this
https://www.griggslawnandtractor.net/steering-whee...321ea46258
Joe 20
Joe 20 is offline
PostPosted: Mon Feb 13, 2023 8:46 pm    Post subject: Re: Kubelwagen steering wheel options Reply with quote
As far as I know a 73 wheel and a 74 wheel have different splines. With that being said, I've wondered if a 71/72 two spoke Beetle or bus wheel would fit a 73.
"Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy
BNMike
BNMike is offline
PostPosted: Mon Feb 13, 2023 10:30 pm    Post subject: Re: Kubelwagen steering wheel options Reply with quote
I've got a '73 on the car now, but I've also got a '74 column in case I have to switch.
Mike
Semper_Dad
Semper_Dad is offline
PostPosted: Tue Feb 14, 2023 9:40 am    Post subject: Re: Kubelwagen steering wheel options Reply with quote
A larger diameter wheel may prove a tight fit for us "horizontally challenged" individuals. Anybody consider a leather wrap on the OEM wheel? Maybe even a paracord.
I believe Kames adapted a bus steering wheel although I think it involved the whole bus steering column.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
wbailey2112
wbailey2112 is offline
PostPosted: Tue Feb 14, 2023 11:59 am    Post subject: Re: Kubelwagen steering wheel options Reply with quote
Check out this older thread for information on two spoke wheels...
https://www.thesamba.com/vw/forum/viewtopic.php?t=692253&highlight=early+steering+wheel
'74 Thing
'83 Westfalia
volkybus
volkybus is offline
PostPosted: Wed Mar 22, 2023 8:24 pm    Post subject: Re: Kubelwagen steering wheel options Reply with quote
Well here's my two cents at a show in Puerto Rico a couple weeks ago I saw a thing converted to a fake kobel and for the steering wheel they took the cover off and exposed the collapsing panel and painted it to match and it looked pretty genuine look pretty cool you know the whole cover and all that stuff was left off made it look pretty primitive actually looking good that's a cheap way of doing it using its own wheel I mean it just making a re creation anyway so good luck bill Vermont and Puerto Rico
BNMike
BNMike is offline
PostPosted: Wed Mar 22, 2023 9:04 pm    Post subject: Re: Kubelwagen steering wheel options Reply with quote
That's how 'Hermann' is currently. The wheel has the plastic stripped off, and it's painted the same color as the car. I need to fit it with a horn button of some description.
Mike
