2Dokas Samba Member
Joined: October 09, 2004 Posts: 752 Location: Santa Cruz, CA
Posted: Thu Mar 23, 2023 10:55 am Post subject: Door and window spring plate |
questionable name, cant find them on wolfs drawings.
I only had 2 when taking the car apart.
I was missing the passenger side door panel but had the other 3.
so, any ideas if there should be 6 of them?
_________________ 87 Doka 2WD Ej22,
56 Convertible |
adaysnight Samba Member
Joined: October 13, 2021 Posts: 88 Location: Los Angeles
Posted: Thu Mar 23, 2023 5:21 pm Post subject: Re: door and window spring plate |
from my '55 April built, there are two per door, one for the window crank and one for the lock/unlock handle. if anyone knows, did originals come with the "back plate" as pictured here, or just the spring?
here's the link on WW...
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111837229 |
lardawge Samba Member
Joined: October 05, 2020 Posts: 355 Location: California
Posted: Thu Mar 23, 2023 9:10 pm Post subject: Re: door and window spring plate |
The backing plate didn’t start until late 56. _________________ 11/2/54 L227 Strato Silver Ragtop - Soon to be L41 Black - Build Thread
1/7/55 L275 Light Beige |
markendee Samba Member
Joined: April 30, 2009 Posts: 248 Location: Kyabram, Australia
Posted: Thu Mar 23, 2023 11:59 pm Post subject: Re: Door and window spring plate |
Now that I've seen them I want them on my 54.
If I had of known about them I would have at least covered the large end that contacts my new door upholstery with duct tape to protect the material. I did feel that the end of the spring was potentially a hole poker.
Next time the door cards are off I will be adding some protection. _________________ Member # 145244 |
piet&som Samba Member
Joined: February 18, 2009 Posts: 250 Location: Toxandria
Posted: Fri Mar 24, 2023 2:02 am Post subject: Re: Door and window spring plate |
This is a spring backing plate on my 54.
_________________ Oval 54 Light Beige, Oval 53 Metalblue. |
Posted: Fri Mar 24, 2023 6:54 am Post subject: Re: Door and window spring plate |
markendee wrote: |
Next time the door cards are off I will be adding some protection. |
They go against the door, not against the door card. Wouldn’t help with not poking holes in the door cards. It’s purpose is to make it easier to center the springs and install the door cards.
Picture from my 57 door. This door had never been apart.
Posted: Fri Mar 24, 2023 6:59 am Post subject: Re: Door and window spring plate |
piet&som wrote: |
This is a spring backing plate on my 54. |
It looks like someone made those. They are not factory as far as I can tell. I have pulled apart original early doors and never seen anything like that. Usually they would glue a piece of material against the door to lay the spring on. Likely all you are trying to do is stop the metal on metal. _________________ 11/2/54 L227 Strato Silver Ragtop - Soon to be L41 Black - Build Thread
Bub Samba Member
Joined: June 10, 2004 Posts: 1151 Location: Central Washington
Posted: Fri Mar 24, 2023 10:28 am Post subject: Re: Door and window spring plate |
lardawge wrote: |
markendee wrote: |
I can't say for sure on early cars, but on later cars the you're way better off putting the spring he other way. The small diameter end of the spring can poke through the door panel/ handle hole if they're assembled that way.
I've disassembled dozens of cars, and don't think I've ever come across those backing plates on anything. Just took a 63' Apart last night- 100% guarantee it had never been apart, no backing plates. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
2Dokas Samba Member
Posted: Sat Mar 25, 2023 1:11 pm Post subject: Re: Door and window spring plate |
This is most likely original.
I have 9 pieces with a hole and 1 without a hole. I recall the holed papers were stacked together.
NOPE (The paper without the hole was up against the door panel.)
Sorry, my dog was typing...
56 Convertible
Posted: Sat Mar 25, 2023 2:50 pm Post subject: Re: Door and window spring plate |
2Dokas wrote: |
Howdy,
Door panel being the door or the door card?
Mark. _________________ Member # 145244 |
2Dokas Samba Member
Posted: Sat Mar 25, 2023 7:03 pm Post subject: Re: Door and window spring plate |
markendee wrote: |
2Dokas wrote: |
Howdy,
Mark. |
Door card everywhere but the US _________________ 87 Doka 2WD Ej22,
56 Convertible |
