MenaVanburen Samba Member
Joined: March 22, 2016 Posts: 20 Location: San Francisco
Posted: Thu Mar 23, 2023 11:40 am Post subject: HELP!! Engine options for a 78vw bus type 2?! |
Hey guys! I’ve done a few searches on here for engine option in California as well as some google searches but couldn’t find what I was looking for. Pretty much my bus lost oil on the highway and engine seized. This bus has been in the family for 40yrs and we’ve done our fair share of rebuilds but now I’m looking to do a major engine overhaul. I’ve been thinking about a suburu conversion but I don’t wanna go that route as I wanna stick with air cooled.
I’m looking to do this job right and I have a decent budget so with that said what performance engine options do you guys recommend. I’m currently in the Bay Area but also looking at engines in socal.
Thanks you guys for your help! 🤙🏽 _________________ @menashootz
Full Restoration!
https://www.thesamba.com/vw/forum/viewtopic.php?t=762809&highlight= |
Zed999 Samba Member
Posted: Thu Mar 23, 2023 12:21 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
Performance/a bus.
In my experience a few more cc's are your friend. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Mar 23, 2023 12:46 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
I’m open to extra cc’s
anyone have experience with Power Haus vw parts in Torrence?
Looks like they have some 2110cc long blocks
Zed999 wrote: |
Performance/a bus.
Full Restoration!
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7210 Location: Videbaek Denmark
Posted: Thu Mar 23, 2023 1:08 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
I wasnt aware that Powerhaus worked with type 4 engines. I may be wrong though.
That said, an increase in displacement is always nice, but the real catch with these engines is to increase the efficiency. With the stock F.I. and the cat, visual inspection etc. its not that easy, but doable. If you want succes you need to build the engine very specific and to the Z or it will not work. But if you do that you can release about 30 hp more over stock. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Thu Mar 23, 2023 1:25 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
I see, I’m not too experienced with the process so I was looking to take it to kombi haus in sacramnto as they rebuilt my head 5yrs ago. As for the powerhouse I’m not sure what type it is.
Thanks for all the reply’s! _________________ @menashootz
Full Restoration!
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3285 Location: Rapid City, SD
MenaVanburen wrote: |
I doubt they do type 4's.
Call Annibal Chico in Arcadia. Keeping smog legal is the shitty part. They can run so good when you don't need to do all the smog BS.
Brian _________________ www.type-emotorsports.com |
Posted: Thu Mar 23, 2023 1:27 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
IMine is a type 2 not type 4. Thanks for all the reply’s! |
The engines are either a T1 (bug based), or a T4 (late bay bus based).
Posted: Thu Mar 23, 2023 1:32 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
Easy way to straighten that out is an engine code or a picture. But I don´t think the type 2´s even came into the US in ´78 with type 1 based engines. So it is 99% certain a 2 liter type 2 engine, which is type 4 based. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Thu Mar 23, 2023 1:47 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
You guys are correct. It’s a type 4 motor
Alstrup wrote: |
Easy way to straighten that out is an engine code or a picture. But I don´t think the type 2´s even came into the US in ´78 with type 1 based engines. So it is 99% certain a 2 liter type 2 engine, which is type 4 based. |
Full Restoration!
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3559 Location: viroqua wi.
Posted: Thu Mar 23, 2023 1:49 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
Do an electric conversion, then take it in to get smogged |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Fri Mar 24, 2023 2:31 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
How would an electric converted vehicle fail a smog test? |
Posted: Sat Mar 25, 2023 6:41 am Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
Lingwendil wrote: |
Because it's not the original engine configuration. |
The website says electric powered vehicles are exempt. I see no exception for conversions. |
Posted: Sat Mar 25, 2023 8:55 am Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
It was kind of a snarky comment about the absurdity of CA smog regulations…
Having a smog tech look at an L-Jet bus can be very amusing. _________________ Bus Motor Build
What’s That Noise?!? |
b-man Samba Member
Posted: Sat Mar 25, 2023 3:40 pm Post subject: Re: HELP!! Engine options for a 78vw bus type 2?! |
Back in 1979 I had to smog my ‘69 Squareback that had a bone stock 1964 Buick 155 hp 225 V6 installed using a Kennedy adapter kit.
I had to go to a CA state referee station and have them approve it, I’m sure with the Buick engine being unmodified from air cleaner to exhaust manifolds that definitely helped.
I’m not sure how it works nowadays but I would think a CA state referee station if they still exist would approve an electric conversion no problem.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
