gbrady28 Samba Member
Joined: February 05, 2006 Posts: 82 Location: Bend, OR
Posted: Sat Mar 18, 2023 1:24 pm Post subject: Duralast Oil Pressure Switch |
I have an 85 Westy with the 1.9 and I'm having issues with my oil pressure warning light going on so to start, I decided to try replacing the oil pressure switch. I found a Duralast switch at Autozone with the correct part number 028919081D so I tried that and it seems to have only made the problem worse. Has anyone used one of these switches? Initially my light was coming on along with the buzzer very sporadically and when I turned the van off and then restarted it would stop. Since replacing the switch I took about a 30 mile drive and now the light starts flickering and then blinking after about 15 minutes but there's no buzzer. At first it comes on when I'm running in higher gears at lower rpm's and then if I downshift it will turn off until my rpm's start to go down again. I know I need to check the oil pressure and am considering installing a gauge but any thoughts on the switch before I do? Thanks! _________________ 85 Vanagon Westfalia 1.9L |
jlrftype7 Samba Member
Posted: Sat Mar 18, 2023 2:06 pm Post subject: Re: Duralast Oil Pressure Switch |
Make sure the wire isn’t chaffed and grounding on the engine as it comes up the left side of the engine. I had one instance of grounding, and one of burned off until I got the routing nailed correctly on our 1.9 with the single stock switch for oil pressure.
I looked up oil pressure switches for a ‘85 Vanagon at Autozone. That number didn’t come up. What color is the main body of the switch, and what pressure rating is your switch listed for opening the contact. I’m wondering if they sold you a higher rated pressure switch for a 2.1 with its dual switch system .
But, you say you have a buzzer and a 1.9 engine? I’m confused, I thought the buzzer system was only on 2.1s. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sat Mar 18, 2023 2:24 pm Post subject: Re: Duralast Oil Pressure Switch |
Generally speaking you don't wanna source your parts for these things from AutoZone unless it's an emergency. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sat Mar 18, 2023 8:43 pm Post subject: Re: Duralast Oil Pressure Switch |
The wire looks good but I can check it to confirm. I don't generally get Autozone parts but they had it in stock and I needed the van so I went with it. I thought when I had originally looked that the pressure rating was correct but looking now it may not be. Their site says pressure limit open 3-8.3 and but the one on GoWesty says it's 2-5. _________________ 85 Vanagon Westfalia 1.9L |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Mar 18, 2023 9:02 pm Post subject: Re: Duralast Oil Pressure Switch |
Good idea to install a gauge, especially if you find yourself doubting what sensors are telling you. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Sun Mar 19, 2023 6:55 am Post subject: Re: Duralast Oil Pressure Switch |
Disconnecting the pressure switch should disable the indicator light on a 1.9 with a single oil pressure switch.
That said, a good pilot always trusts his instruments. In a case like this you must verify the engine oil pressure with a quality mechanical gauge.
If after disconnecting the switch you still have an indicator problem, you have a circuit problem. _________________ ☮️ |
Posted: Sun Mar 19, 2023 8:15 am Post subject: Re: Duralast Oil Pressure Switch |
I just purchased a new switch from GoWesty and will be returning the one from AutoZone. Regardless of whether or not that is the issue, for an inexpensive part I want to make sure I’ve got the right one. Next up is adding a gauge so I don’t need to guess if I’m about to destroy my engine. _________________ 85 Vanagon Westfalia 1.9L |
erdonline Samba Member
Posted: Sun Mar 19, 2023 7:47 pm Post subject: Re: Duralast Oil Pressure Switch |
The '85 with a 1.9 doesn't have the dynamic oil pressure warning system, so there should be no buzzer, and only one sender (I believe 0.3 bar). Do you have a modified system? There should be no buzzer. I didn't see you answer this question from another member. And what color collar did the sender have that you installed?
Ed _________________ '85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle |
Posted: Sun Mar 19, 2023 8:47 pm Post subject: Re: Duralast Oil Pressure Switch |
The collar is blue and looks identical to the one at GoWesty. It’s also listed with the same part number. There has always been a buzzer accompanying the light until I installed the new switch and as far as I know there have been no modifications. This is the first time I’ve had only the light go off with no buzzer. _________________ 85 Vanagon Westfalia 1.9L |
Posted: Sun Mar 19, 2023 9:30 pm Post subject: Re: Duralast Oil Pressure Switch |
I never considered it odd that the buzzer went off and was unaware that it wasn’t typically found on the 1.9. Does anyone have any possible explanation for this? _________________ 85 Vanagon Westfalia 1.9L |
Posted: Mon Mar 20, 2023 6:41 am Post subject: Re: Duralast Oil Pressure Switch |
What is the manufacture date of the van? Its possible a cluster from a later van was installed. The member that would know for sure is crazyvwvanman. For a dynamic oil pressure warning system to work, you need two oil pressure switches. Otherwise you need to disable the warning system. I have a cluster from a later van in our 82. I grounded it at the cluster connector. I’ve read where others have bent the pin. _________________ ☮️ |
Posted: Fri Mar 24, 2023 10:41 pm Post subject: Re: Duralast Oil Pressure Switch |
I installed the new switch and the first thing I noticed is that it has a metal gasket which the one from AutoZone didn’t not. I’ve only driven about 20 miles but so far no issues at all. _________________ 85 Vanagon Westfalia 1.9L |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4798 Location: Bemidji, MN
Posted: Sat Mar 25, 2023 6:24 am Post subject: Re: Duralast Oil Pressure Switch |
gbrady28 wrote: |
I installed the new switch and the first thing I noticed is that it has a metal gasket which the one from AutoZone didn’t not. I’ve only driven about 20 miles but so far no issues at all. |
the switch with the gasket is likely a true M10 x 1.0 thread, requiring a gasket to seal. the non-gasket switch might've been a 1/8"-27 NPT taper thread, meant to lock itself in a tapered NPT hole. they work, usually without harm, but it ain't right. _________________ -dan
www.thefixitworkshop.com
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Sat Mar 25, 2023 11:15 am Post subject: Re: Duralast Oil Pressure Switch |
DanHoug wrote: |
gbrady28 wrote: |
the switch with the gasket is likely a true M10 x 1.5 thread, requiring a gasket to seal. the non-gasket switch might've been a 1/8"-27 NPT taper thread, meant to lock itself in a tapered NPT hole. they work, usually without harm, but it ain't right. |
M10X1, not 1.5 _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
zerotofifty Samba Member
Posted: Sat Mar 25, 2023 7:08 pm Post subject: Re: Duralast Oil Pressure Switch |
Id be getting a known good gage on that thing to make sure you aint got no real oil pressure problem. That is my first concern. |
Posted: Sat Mar 25, 2023 7:47 pm Post subject: Re: Duralast Oil Pressure Switch |
3 psi is not enough oil pressure, get a gauge on there and see what you oil pressure actually is. |
Posted: Sun Mar 26, 2023 6:35 am Post subject: Re: Duralast Oil Pressure Switch |
ALIKA T3 wrote: |
M10X1, not 1.5 |
right. i corrected my original post in case someone stumbles across it and stops reading. thanks for catching that.
as an aside, NAPAonline had some pressure switches, mebbe Altrom, that showed "Made in Germany" on the box so i ordered two on the off chance they were what the photo showed. when they came, they were China switches but worst part is the open/closed logic was reversed. back they went. _________________ -dan
www.thefixitworkshop.com |
Posted: Sun Mar 26, 2023 10:13 am Post subject: Re: Duralast Oil Pressure Switch |
DanHoug wrote: |
ALIKA T3 wrote: |
M10X1, not 1.5 |
as an aside, NAPAonline had some pressure switches, mebbe Altrom, that showed "Made in Germany" on the box so i ordered two on the off chance they were what the photo showed. when they came, they were China switches but worst part is the open/closed logic was reversed. back they went. |
Yes all the switches from the local parts sellers are whack, you can even see some in picture showing the tapered threads.
You can still find made in Germany switches for fairly cheap. The high pressure switch sold by GoWesty was Febi made in Germany last I ordered.
There's other brands like Hella and Swag, Facet that are good quality but available mostly in Europe. Stay clear from Meyle, JP Group and Topran., they'll leak faster at the spade, when they work _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
