EVCFOREVER11 Samba Member
Posted: Tue Feb 07, 2023 9:08 pm Post subject: How many water pumps are in a 95 Eurovan |
Its not a trick question .Im remembering something from a long time ago. Can water pumps get clogged??? |
TheOneTrueQuux Samba Member
Posted: Wed Feb 08, 2023 8:03 am Post subject: Re: How many water pumps are in a 95 Eurovan |
EVCFOREVER11 wrote: |
If we're talking the engine pump, there are two. The main one driven off the timing belt, and a secondary afterrun pump that's electrically powered, and runs after shutdown to dissipate engine heat and prevent heat soak related problems.
Clogging would be very unlikely. Sometimes the impellers fall off though, which would cause no flow. |
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
Posted: Wed Feb 08, 2023 12:02 pm Post subject: Re: How many water pumps are in a 95 Eurovan |
Isn't the main pump impellers made of plastic and break. There are metal replacements. _________________ 2002 EVC |
Posted: Wed Feb 08, 2023 4:46 pm Post subject: Re: How many water pumps are in a 95 Eurovan |
Very interesting I have a problem that I can not resolve after I did a flush. I fill the coolant system and the water/coolant as it starts to warm up you see the water/coolant start to rise and when its hot it shoots out the reservoir like a volcano ! Ive tried just about everything nothing has resolved it so far , Im at my wits end. |
subdewd Samba Member
Posted: Thu Feb 09, 2023 7:21 am Post subject: Re: How many water pumps are in a 95 Eurovan |
Possible head gasket |
Posted: Thu Feb 09, 2023 8:09 am Post subject: Re: How many water pumps are in a 95 Eurovan |
subdewd wrote: |
It's also possible that the thermostat is just stuck. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Thu Feb 09, 2023 5:14 pm Post subject: Re: How many water pumps are in a 95 Eurovan |
Head gasket test kits are cheap, easy to use with internet instructions, and available at any FLAPS.
Any other recent work done to van? _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
wannabecamper Samba Member
Joined: May 09, 2019 Posts: 211 Location: Sunnyside, US
Posted: Fri Feb 10, 2023 1:55 pm Post subject: Re: How many water pumps are in a 95 Eurovan |
It started to happen after you flushed and not before? What did you do to flush? |
Posted: Fri Feb 10, 2023 3:46 pm Post subject: Re: How many water pumps are in a 95 Eurovan |
Not the thermostat , not head the gasket. Head dye test came out neg. , thermostat been changed three times and now its just out. |
Posted: Sat Feb 11, 2023 9:03 pm Post subject: Re: How many water pumps are in a 95 Eurovan |
If the thermostat is out, then the only thing that I can think of is that there is a blockage. (no shit you may say ) The return hose at the bottom of the reservoir connects to the metal pipe that returns to the block at driver side front. Check the pipe/hose and see if there is a blockage. Here is a 5 cylinder coolant diagram with my chicken scratch of the coolant flow.
Posted: Mon Feb 13, 2023 9:02 am Post subject: Re: How many water pumps are in a 95 Eurovan |
I found this I have watched his videos before but never saw this one till a buyer showed it to me . Thomas EXOVCDS https://www.youtube.com/watch?v=mlzDtTSHV6w&t=14s How could I attempt to do this vacuum thing from home sitting under a car port ? |
Tvättbjörn Samba Member
Posted: Mon Mar 27, 2023 12:14 am Post subject: Re: How many water pumps are in a 95 Eurovan |
any updates? Check the upper outlet connection #26 in the picture. They like to plug up. |
