JK73Super Samba Member
Joined: July 26, 2013 Posts: 78 Location: Ontario, Canada
Posted: Sun Mar 26, 2023 11:08 am Post subject: Wheel Center Cap Options |
I’ve got a set of rims with 80 mm (3.15”), actually it appears to be between 79 and 80 mm. The axle shafts stick out 60 mm (2.36")
Non of the wheels had a cap when I got this bug.
Looking for wheel center cap options to make things look a little better, but aside from one possible cap type form CIP1, which does not look right with my wheels, I’m having difficulty finding any others large enough for proper fit.
Would be interested in finding out what others have found and/or fabricated for this type of wheel.
Thanks, Jim
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 953 Location: Sacramento, CA
Posted: Sun Mar 26, 2023 11:49 am Post subject: Re: Wheel Center Cap Options |
JK73Super wrote: |
Thanks, Jim
https://www.amazon.com/gp/product/B00AX4KMRO/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
I bought these for my wheels and they work great. Just slide them in from the inside. |
Posted: Sun Mar 26, 2023 11:51 am Post subject: Re: Wheel Center Cap Options |
Sorry, I just noticed they are sold out. You can look around to see if someone else on Amazon has them. |
TornadoRed06 Samba Member
Joined: August 30, 2020 Posts: 198 Location: Porto - Portugal
Posted: Sun Mar 26, 2023 1:58 pm Post subject: Re: Wheel Center Cap Options |
For the part I mention here, VW themselfs quote 80mm but I am unsure if this one is really appropriate for your Marathon wheels.
It is a lead, so on the cautious side maybe get one or two and then you can decide:
# 321 601 171 A 01C
01C is for denoting Black Finishing |
Gerb Samba Member
Joined: June 21, 2012 Posts: 79 Location: Southwest MI
Posted: Sun Mar 26, 2023 2:00 pm Post subject: Re: Wheel Center Cap Options |
Look for Marathon or Baja wheel center caps for those wheels. They can be pricey, but they're out there.
https://www.thesamba.com/vw/classifieds/detail.php?id=2211339
Todd _________________ ~gerb (Todd G)
'73 Super Beetle Sport Bug
'72 Super Beetle Baja Champion SE
'64 Ruby Red Deluxe Beetle |
Posted: Sun Mar 26, 2023 6:14 pm Post subject: Re: Wheel Center Cap Options |
Thanks for the feedback.
There are a few 80 mm diameter caps available, but most are not deep enough to accommodate the 60 mm axle shaft protrusion.
Those pricey marathon wheel caps available in the classifieds for 400 euros, seem Not to be well secured to the wheel and could easily be lost. |
Gerb Samba Member
Posted: Sun Mar 26, 2023 6:19 pm Post subject: Re: Wheel Center Cap Options |
The Marathon caps lock on pretty tightly to the wheel as long as the tabs are all there. Haven't had a problem with mine coming off. Last set I bought cost me $150 for a decent set of four. _________________ ~gerb (Todd G)
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Mon Mar 27, 2023 3:46 am Post subject: Re: Wheel Center Cap Options |
Styrofoam Solo cups, paint to match or contrast.
Or, I found these Brazilian VW center caps.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Mon Mar 27, 2023 9:36 am Post subject: Re: Wheel Center Cap Options |
Quote: |
Styrofoam Solo cups, paint to match or contrast. |
Continuing with this idea, take a measuring tape along to the grocery store or dollar store. Try to find some white plastic plastic drinking cups that have the correct diameter. Likely they will already have sufficient depth. The formed lip on the wider end will be your fitment method on the inside edge of the wheel hole. If you find some, glue two of them together with epoxy, pressing them tightly together. This will give them better rigidity. Assemble 6 of them, then paint them satin black with spray paint that adheres to plastic. Then you have 2 spares immediately available in case any are knocked off. You can even glue a "VW" logo sticker onto the end of each one.
I have a set of the same wheels but never mounted them; though I'd try the above method. I bought a set of generic aftermarket accessory plastic chromed 6-sided caps 20 years ago at a large VW meet in Germany; paying only about $30 for them which were in the NOS blister-pack.
Summit Racing has this aluminum cap. Description caption lists 3.175" diameter, but the specs list it as 3.16" dia. which is just over 80 mm. Might not have the depth you need, and unfortunately that measurement is not given. https://www.summitracing.com/parts/wld-p605-5083 |
