RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Sun Mar 26, 2023 2:02 pm Post subject: Overheating, maybe... - '90 Westy 2.1L |
Looking at the temp gauge on the dash, the needle comes up to the usual place and stays put. The radiator fan doesn't come on (it works - I jumpered the switches).
Sitting in front of the garage, idling, the T2 temp comes up to about 204F (95.5C) using ScanGauge (I verified it reads T2). I've seen 207F (97.2C) at a traffic light. Reading the water pump housing with an IR gun, I get about 198F (92.2C).
The gun showed about 150F (65.5C) at the inlet side of the radiator, at the top.
So... is T2 telling me tales? What a reasonable temp range from T2? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Sun Mar 26, 2023 2:28 pm Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
i dont know about t2, but the temperature that steam happens at is 212º id say youre doing ok for temps. plus youre taking all those readings from differnet points no? the average seems ok. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Sun Mar 26, 2023 6:45 pm Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
Very true - one of the point of points of pressurized cooling systems is to hold off the boiling point.
I'm inclined to think the cooling system isn't in big trouble, but the T2 numbers aren't comforting. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Sun Mar 26, 2023 7:40 pm Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
dobryan wrote: |
outcaststudios wrote: |
i dont know about t2, but the temperature that steam happens at is 212º id say youre doing ok for temps. plus youre taking all those readings from differnet points no? the average seems ok. |
With coolant and under pressure steam happens way higher… |
interesting, i did not know that,what temp does it happen at in motors? i guess i always assumed the water still boiled as normal. thanks for pointing that out! _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun Mar 26, 2023 7:58 pm Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
...what temp does it happen at in motors? |
A 50/50 mix of water and antifreeze raises boiling to 223⁰.
Pressure in the cooling system raises it further... about 3⁰ for each psi. So with a 15# cap the boiling point may be about 268⁰. |
Posted: Mon Mar 27, 2023 6:38 am Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
that makes total sense,really glad to know that now. seems like OP's temps are really good then? _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
Posted: Mon Mar 27, 2023 7:01 am Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
50/50 anti-freeze and water both raises the boiling point, and lowers the freeze point. It's all in the chemistry of the mix.
Folks who live well above sea level are aware that water boils sooner than at sea lever - reduced air pressure. The pressure cap stands things on their head and lets the pressure inside the coolant system go above sea level pressure - 13-15 PSI being typical.
My concern is the T2 sensor is hot, hot, hot - mostly just below 200F (93.3C), but sometimes above it. At the moment, ambient temps are still cool (nominally 30 - 60F / -1 - 15C). What happens when we start hitting 70 - 80F (21 - 26.6C)?
Or is everything OK, and I should stop looking at the T2 readout? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Mon Mar 27, 2023 7:28 am Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
If you look in the full Bentley it shows the 3 different watercooled engine cooling systems.
Each describes the thermostat test opening range.
Each says thermostat BEGINS to open at 185f.
Each says thermostat FULLY open at 221f.
Mark |
Posted: Mon Mar 27, 2023 7:44 am Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
Do you recall where you saw that in Bentley? I expected to find what you're talking about, but no luck so far.
One consolation is apparently temperature regulation is going on. T2 stays in a range (nominally 193-203F - 89.4-95C), instead of "goes up and stays there".
I replaced the full thermostat housing and thermostat a while back. The housing looked ...meh... ratty? Rather than have it surprise me on the road, I replaced it. Get that far, might as well do the thermostat, too. ;D _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Mon Mar 27, 2023 8:01 am Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
Later Bentley cooling system info, thermostat temps
1.6 diesel page 19.4
1.9 wbx page 19.8
2.1 wx page 19.11
page 19.12 has additional important info |
Posted: Mon Mar 27, 2023 9:05 am Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
Thanks! _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Mon Mar 27, 2023 12:15 pm Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
I don't understand the cooling system's sensors' function(s).
T2 and T1 don't report the same values (ScanGauge, and instruments, respectively). Why is that, and why does (I'm assuming) the ECU care about T2 v. T1? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
kamzcab86 Samba Moderator
Posted: Mon Mar 27, 2023 1:25 pm Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
RBEmerson wrote: |
T2 and T1 don't report the same values (ScanGauge, and instruments, respectively). Why is that, and why does (I'm assuming) the ECU care about T2 v. T1? |
From the Digifant ProTraining Manual:
The coolant temperature sensor is a negative temperature coefficient resistor (NTC). The resistance signal it produces is used by the control unit to determine:
- The amount of cold start and warm-up enrichment
- Ignition timing and idle stabilization during warm-
up
- When the oxygen sensor, idle stabilization, and full
throttle enrichment functions are activated
The other temperature sender (black one) is for the instrument cluster gauge. _________________ ~Kamz
2016 Golf GTI S
Posted: Mon Mar 27, 2023 1:39 pm Post subject: Re: Overheating, maybe... - '90 Westy 2.1L |
OK, the fog slowly dissipates...
Recently I did a 100 mile round trip to collect wood shakes for a roof I'm replacing.
On the way out, in the rain and ambient temps in the 50's. and on the way back, ambient temps still in the 50's but no rain, and 3 squares (or ~300 sq ft) of shakes (ain't light!) in the back, T2 stayed about the same, and the temp gauge stayed in the usual place (bottom of the operating range markings).
Way back when, T2, as best I can recall, stayed much lower than it currently does. Maybe that was a problem (engine temp too low), and all's well now.
All of this makes for a strong argument to ignore the darn ScanGauge, believe what I see next to the tach, and got on with life. Except just maybe all isn't as it should be. Hence the thread title. ;D _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
