Btfsplk Samba Member
Posted: Sat Mar 25, 2023 12:38 pm Post subject: '93 Cabrio Wolfsburg Digifant Codes Help |
Greetings. I pulled my floor console surrounding my A/T shifter in order to reach the three ports supposedly located there to try to get codes out of the Digifant II system. I thought I'd find 3 there (1 for the airbag (red) and 2 for the Digifant II (1 black, 1 white)). There were only 2. Not 3. A red one and a black one.
Is it possible that one of you could explain this and instruct me on how to get codes out of this Digifant II system? I attached a light bulb to two leads and stuck 1 lead in the brown (ground) terminal on the black port, and the other lead in the red terminal on the black port or plug, but the bulb just lit up, never flashed. I waited the usual 5 seconds, etc.
Car will start, idles very rough, shuts back down after maybe 10 seconds of running.
Engine was doing the same thing before mothballing it some years ago. Just finished installing new fuel tank, sending unit, 2 fuel pumps, fuel filter, all new hoses to the engine. Having the fuel system replaced, I now want to tackle analyzing the engine rough running problem. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sun Mar 26, 2023 8:44 am Post subject: Re: '93 Cabrio Wolfsburg Digifant Codes Help |
I believe the only Cabriolet's [if it is a 93, it's not a Cabrio] that could set codes, were California versions and they are Digi 1. Digi 2 were not capable of setting/storing codes.
Do not rely on me, there are more knowledgeable people here to set you straight. |
Posted: Sun Mar 26, 2023 8:57 am Post subject: Re: '93 Cabrio Wolfsburg Digifant Codes Help |
Thanks for your reply Butcher. I'm interested in your comment about what it is -- wondering why if it's a '93 it's not a Cabrio. It is a '93, it's badged and identified everywhere as a Cabriolet (as well as "Wolfsburg," "Karmann," and "Collector's Edition") and even the owner's manual refers to it as a Cabriolet.
The VIN contains the "B" code for Digifant II, which is proper for this year non-California Cabriolet.
Anyway, if you have more details on why I should not refer to this '93 version as a Cabriolet, enlighten me. Thanks! |
kamzcab86 Samba Moderator
Posted: Mon Mar 27, 2023 7:26 am Post subject: Re: '93 Cabrio Wolfsburg Digifant Codes Help |
The topic says '93 Cabrio. It's misleading. I know I stand alone on this. A Cabriolet looks like a Golf 1/Rabbit and a Cabrio looks like a Mk3 Golf.
In the end, you can call it anything you want to call it but when you ask for help, facts help. It's not a Cabrio. |
Posted: Mon Mar 27, 2023 10:26 am Post subject: Re: '93 Cabrio Wolfsburg Digifant Codes Help |
Butcher wrote: |
The topic says '93 Cabrio. It's misleading. |
No, it isn't.
1993 + Digifant are your immediate clues as to what era the car is.
This is pointless, narcissistic drivel rooted in ignorance. This BS does not occur when it's a hatchback being discussed: "It's a Rabbit." "No, it's a Golf!" GMAFB _________________ ~Kamz
2016 Golf GTI S
Tvättbjörn Samba Member
Posted: Fri Mar 31, 2023 12:35 am Post subject: Re: '93 Cabrio Wolfsburg Digifant Codes Help |
Check your PM |
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Tue Apr 04, 2023 3:43 pm Post subject: Re: '93 Cabrio Wolfsburg Digifant Codes Help |
Wow..potato,patata..I call my 95 golf convertible a golf. How about solving the problem......PLEASE....my 95 jetta has a similar problem which is intermittent. I checked the fuel pressure,changed the coil(swapped from my Eurovan) tighten lines but still often when it starts it runs on one cyl for aacouple of minutes, finally reves and runs normally for a day or more..also checked for vacuum leaks ,changes the vacuum assist cannisters..any help will be appreciated..Bill VT & Pr |
