CapeBuggy Samba Member
Posted: Tue Mar 28, 2023 2:53 am Post subject: Is this what I think it is? |
Doing a complete tune up on my week old 68 buggy. Have no maintenance history on it, so doing everything. FYI, not much VW experience, but plenty on many other types of engines.
Dropped the screen to clean and this was sitting as you see it. Engine runs fine, no noticeable noises. Find it odd that this would be able to pop out. When assembled, does the wrist pin drop below the bottom of jug?
oprn Samba Member
Joined: November 13, 2016 Posts: 12632 Location: Western Canada
Posted: Tue Mar 28, 2023 5:13 am Post subject: Re: Is this what I think it is? |
No they do not! If you do not have severe compression loss on one cylinder then that is left over from someone's wrenching efforts. And now that I think about it, that thing is in pristine condition so it is definitely not out of one of your existing pistons. If it were it would be beat beyond recognition by the time it got that far.
P.S. Watch for a 10mm socket too I'm always one short at the end of the day! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2173 Location: HdG, MD & NJ
Posted: Tue Mar 28, 2023 7:02 am Post subject: Re: Is this what I think it is? |
Could have been dropped and lost during assembly. Hopefully.
I took apart a stock Buick 350 that had a connecting rod nut in the oil pan. And it wasn’t missing any. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Tue Mar 28, 2023 7:08 am Post subject: Re: Is this what I think it is? |
Bad joke, but i suspect you're cam and lifters are going south. Sure is a lot of thick goo on the plate. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Mar 28, 2023 1:22 pm Post subject: Re: Is this what I think it is? |
Glenn wrote: |
Bad joke, but i suspect you're cam and lifters are going south. Sure is a lot of thick goo on the plate. |
Glenn, thanks for responding. Curious why you zero in on cam/lifters? Can you elaborate? I too was concerned about the color/consistency of the oil. For the 3 qts it takes, I will be monitoring it very closely moving forward. |
Posted: Tue Mar 28, 2023 1:24 pm Post subject: Re: Is this what I think it is? |
oprn wrote: |
P.S. Watch for a 10mm socket too I'm always one short at the end of the day! |
OPRN, Thanks for the response! Good point on it not being beat up!! I feel a little better! I also have a few missing 10's!! Will put you on the list if one shows up in the spline or??? |
Posted: Tue Mar 28, 2023 1:26 pm Post subject: Re: Is this what I think it is? |
I do have an odd "miss" on the 3/4 side that seems more evident when cold. To be honest, still havn't even driven on the road yet. GOing to do a compression and if needed a leak down on that side. I did adjust the valves, they weren't bad. Time will tell... |
oprn Samba Member
Posted: Tue Mar 28, 2023 2:00 pm Post subject: Re: Is this what I think it is? |
PICTURES! WE NEED PICTURES!!
Ooops! I found one... worth it's weight in... gold?
Posted: Tue Mar 28, 2023 4:28 pm Post subject: Re: Is this what I think it is? |
oprn wrote: |
Yep, that's it! Clearcoat needs to be redone, but it is unique and will be my summer toy! |
slalombuggy Samba Member
Posted: Wed Mar 29, 2023 4:54 am Post subject: Re: Is this what I think it is? |
Do you have an external oil cooler or aftermarket shroud with no flaps? Did tge car make a lot of short trips? Looks like your oil is not getting near hot enough (or changed enough) and it is sludging up. |
oprn Samba Member
Posted: Wed Mar 29, 2023 5:23 am Post subject: Re: Is this what I think it is? |
^^^This!^^^ _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
YDBD Samba Member
Joined: February 25, 2017 Posts: 890 Location: Bavaria, Germany
Posted: Sat Apr 01, 2023 10:02 pm Post subject: Re: Is this what I think it is? |
I'm going to think the previous owner did the quick drain plug oil change most of the time so the goo could be from long term build up.
When my dad and I finished working on my mom's '67 we would always have a can of parts we didn't put back on-not sure why, but that retainer clip would go into the can and we'd show mom at the end...saying "it's running, but we got all these extra parts we didn't need"... _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Posted: Tue Apr 04, 2023 5:56 pm Post subject: Re: Is this what I think it is? |
YDBD wrote: |
The problem with that thinking is that while it may be true, few is any other engine on the planet has a plate you pull off the bottom to clean the pick up screen and they don't suffer from sludge build up because of it. I would still look at your cooling system and take some temperatures after it's been run for a while and gotten "up to temp" |
