Navydave73 Samba Member
Joined: March 09, 2017 Posts: 414 Location: Alta Loma/Los Angeles
Posted: Fri Jul 01, 2022 11:27 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
we pulled in the wiring harness before paint and just had it bagged on each end for overspray.
so far, i really like the WW harness over the Wiring Works. However, the aftermarket fuse block does not have the double-sized terminal for the two large red wires like the original, so i wont be using the new block. Last night, i had enough and started soaking the OG block in Kroil. should be fine.
i searched the gallery and couldnt find a good pic of the flasher relay on a 6 fuse block. the two screw holes for the block are different sized. I had the two original screws, one worked on the right side but the left sized hole is too large. Is there a relay bracket that goes behind the fuse block that has a smaller hole for the sheet metal screw to grab? or does the flasher just hang in space on the wires?
thank you,
Navydave
Posted: Fri Jul 01, 2022 6:14 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
From the Bentley Manual for 1959
It’s got one of those brown Bakelite flashers. Is there a bracket for it that the fuse block screw bites into? |
Posted: Sun Jul 03, 2022 9:46 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Before:
After:
Posted: Sun Jul 03, 2022 9:49 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Finalizing the wiring harness. The WW fuse block wire terminals are all the same size OG Bus has a few of the terminals larger to accommodate the multiple big wires. Cleaned up the OG and reinstalled. I found a blinker bracket in my pile of parts but the hole is larger too. I may go with a door panel clip like what comes with door speakers. I’ll see what Ace Hardware has and post pics |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Sun Jul 03, 2022 10:18 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Thanks Everett. I was wondering where they went. I have the pockets underneath for the felt pads also. Is it both or rubber for late 59 on and felt for early? |
Posted: Sat Aug 27, 2022 9:37 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
The sun shinning on the new WW chrome handle looked cool to me? I could not get the OG one off the old hatch
Vent trim installation. Glad I drilled these holes before paint
Posted: Sat Aug 27, 2022 9:42 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
My wife wants to keep the hippie door, so I used orange paint remover Crome Home Depot that my son good luck with on his Mango. After seeing how the door buffed out, I really regret not keeping the OG paint as much as possible and trying to blend where I replaced metal. Oh well.
I was feeling good about the dove blue until I buffed out this door. You can see how off my color match is. I should have polished the door then had my paint shop match off of that. It’s cool that my wife is providing input and being involved. Definitely a strange partial resto?
The details are dragging on of course, that’s how these things go. Hopefully headliner next weekend.
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5501 Location: 1st Coast
Posted: Mon Aug 29, 2022 7:54 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Interesting color difference. Nice that your wife is involved with the original door staying original. Great thread.
Navydave73 wrote: |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Sun Sep 25, 2022 10:51 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
That’s a link to the headliner thread I made. It came out OK.
But I’m really struggling with glass. I ended up breaking a corner window. Damn it. The skylights just won’t go no matter what we try. It seems like the profile of the rubber is too thick. I ordered one from WCM, we will see if they fit better. I had 1 original glass with a rubber on it, don’t know where it came from but it popped right in. |
Posted: Tue Mar 28, 2023 10:41 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Update.
Posted: Tue Mar 28, 2023 10:44 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Nice pics of engine installed.
Posted: Tue Mar 28, 2023 10:47 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
I could not get aftermarket glass to install no matter what I tried. I got ahold of an OG and compared the difference, you can see by the outline marker how much larger they are.
The ragtop was one of the easiest things to make so far, more simple than a bug ragtop. I used German fabric canvas, it supposed to be vinyl but I love the look of cloth.
Posted: Tue Mar 28, 2023 10:59 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
The ragtop may have been simple but the seat upholstery is a royal pain in the ass. I never would have thought that the seats were tuck and roll. I was going to sew a visible seam similar to heat seams until my son bought his walk thru seats for his Mango. One of the seats came with original upholstery so I could see how it was put together. They used the drier lint looking jute padding for the panels sewn between each pleat. I went with foam, looks a little over stuffed but it’s comfortable.
Following some of the threads on here, burlap over springs. Then stiff jute pad followed by new WW coconut seat pad for front only. Then 1 layer of 1/2” cotton batting I Got from Amazon. For rear and middle, burlap…jute…2 layers of cotton batting.
I’m doing the middle seat last so I can have my system down on the other seats. Lots of complicated pieces to sew and fit. This is the first project I’ve ever used poster board to make templates. It’s working out but I’m still struggling to get it right. For the rear, I made the shapes from the bare seat with no padding, then added to the measurements to allow for padding. We will see how it turns out later today |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2814 Location: West Palm Beach, FL
Posted: Tue Mar 28, 2023 5:05 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
paint look delicious
So clean and shiny.
Speedo pic was great _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
@Buswerx Samba Member
Joined: October 26, 2021 Posts: 14 Location: San Luis Obispo
Posted: Thu Mar 30, 2023 7:30 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
you did an amazing job on this build, thx for sharing |
oakman Samba Member
Joined: February 05, 2014 Posts: 1711 Location: Edge of the Desert, Ca
Posted: Thu Mar 30, 2023 11:50 am Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Tons of hard work paid off. Bus looks killer!! _________________ Brandon |
oakman Samba Member
Posted: Thu Mar 30, 2023 12:08 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
Edit _________________ Brandon
Posted: Wed Apr 05, 2023 9:03 pm Post subject: Re: 1959 Kombi/Deluxe Rebuild Thread |
I think that’s too early for me. My build date is November 11. So according to Progressive refinements and the original lower valence, Im pretty sure it’s steel bumpers.
It is a high tailight though. Pretty cool. |
