Red Ryder Samba Member
Joined: June 26, 2021 Posts: 952 Location: Northern California
Posted: Sun Mar 26, 2023 8:41 pm Post subject: Vacuum pod for Cruise Control |
Looking to replace the vacuum pod (not the vacuum pump) for the cruise control in the engine bay. I think the diaphragm is leaking. Can’t seem to find one online. Yes, I saw the used one offered in the classifieds. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Sun Mar 26, 2023 8:52 pm Post subject: Re: Vacuum pod for Cruise Control |
Red Ryder wrote: |
I think the diaphragm is leaking. |
You can test that by applying vacuum and see if it holds. have you tried to test it?
what doesn't work about the used ones in the classifieds?
I may have some form pulled conversions but they too would be used. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sun Mar 26, 2023 9:31 pm Post subject: Re: Vacuum pod for Cruise Control |
077 133 185M put this number into Google, I found it on E bay.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
bheins Samba Member
Joined: January 14, 2006 Posts: 16 Location: Toronto Ontario
Posted: Mon Mar 27, 2023 5:37 am Post subject: Re: Vacuum pod for Cruise Control |
I think that's that part number is for the manifold. Try 077198327A
Stacey, have you used one of these in the vanagon?
Bernie |
16CVs Samba Member
Posted: Mon Mar 27, 2023 8:45 am Post subject: Re: Vacuum pod for Cruise Control |
I have not used one. It looked the right part number. The Audis use them fir their VVT. Same part, you just change the connector to what you need.
Posted: Mon Mar 27, 2023 8:46 am Post subject: Re: Vacuum pod for Cruise Control |
Saw those on eBay. Wasn’t sure if it was the correct part. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
satchmo Samba Member
Joined: November 23, 2003 Posts: 285 Location: Crosby, MN
Posted: Mon Mar 27, 2023 10:01 am Post subject: Re: Vacuum pod for Cruise Control |
Older Range Rovers also use the same vacuum pod, and I think you can find them new/unused if you look around.
Satchmo |
DLJ Samba Member
Joined: August 05, 2008 Posts: 555 Location: North California
Posted: Mon Mar 27, 2023 10:06 am Post subject: Re: Vacuum pod for Cruise Control |
I have used the part mentioned by Stacy. It needs a slight modification. Works perfect. I bought it from one of the Samba members. |
Posted: Mon Mar 27, 2023 12:12 pm Post subject: Re: Vacuum pod for Cruise Control |
vanis13 wrote: |
Red Ryder wrote: |
You can test that by applying vacuum and see if it holds. have you tried to test it? |
I did test the pod with vacuum and it does seem to hold. However, it only moves the throttle body lever a very short distance. Is this normal? _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Mon Mar 27, 2023 12:56 pm Post subject: Re: Vacuum pod for Cruise Control |
If the vacuum actuator "holds" a vacuum, then it is good. When you say that the actuator only opens the throttle a bit, how much vacuum are you applying?
The reason I ask those questions and make those comments is that the typical problems with the Vanagon cruise control (which is essentially the same system used across all VW and Audi cars in the same years), is that the most common problems are:
1. The vacuum/electric switches at the brake pedal and the clutch pedal can develop vacuum leaks which will result in the throttle only opening a bit while the vacuum pump keeps pumping away;
2. The vacuum hoses can be damaged by light, ozone, etc and develop leaks;
The vacuum/electric switches can be restored quite nicely by disassembling and replacing the o-ring and applying oil in the cylinder in which the o-ring slides. See this excellent youtube video from Van-Again:
https://www.youtube.com/watch?v=KcIL_K9H8zQ
Don't bother buying the new replacement vacuum/electric switches. Restoring your OEM ones is dead simple.
The other frequent headache with these CC systems is the tendency for the turn signal stalk CC switch to get coated with schmutz on the electrical contacts. That is repairable also. Those stalk switches are NLA, so you will have no choice but to repair if that problem crops up. Here is a thread that shows you how to do that job:
https://www.thesamba.com/vw/forum/viewtopic.php?t=677602
One final comment: The CC computer is designed to tell the vacuum pump to "give up" after a few seconds if the CC is attempting to increase throttle opening, but the vehicle does not speed up. This is designed to anticipate a vacuum leak and keep the vacuum pump from burning itself up. _________________ '86 Syncro Westy SVX |
Posted: Mon Mar 27, 2023 1:41 pm Post subject: Re: Vacuum pod for Cruise Control |
Howesight wrote: |
1. The vacuum/electric switches at the brake pedal and the clutch pedal can develop vacuum leaks which will result in the throttle only opening a bit while the vacuum pump keeps pumping away; |
Yep, all that in the full post and specifically on this - remove the front hoses connection on the gizmo in the engine bay and plug the nipple and run only on electric switches. if that works, you know its the switches/hoses.
If that works, then fix the redundant vacuum switches/lines or DON'T and go on with life with just electric switches like all other systems do. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Diy2k Samba Member
Posted: Mon Mar 27, 2023 9:55 pm Post subject: Re: Vacuum pod for Cruise Control |
Did I sell you the pod?
It held air when you close the ports. Tested it with wd40 on the rubber as welts check for cracks.
I would inspect the hoses as well. They become brittle anywhere they bend. _________________ 1987 VW Vanagon Wolfsburg Weekender
2012 Ford Transit Connect Xlt |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Tue Mar 28, 2023 6:30 am Post subject: Re: Vacuum pod for Cruise Control |
Howesight wrote: |
One final comment: The CC computer is designed to tell the vacuum pump to "give up" after a few seconds if the CC is attempting to increase throttle opening, but the vehicle does not speed up. This is designed to anticipate a vacuum leak and keep the vacuum pump from burning itself up. |
hmmm.... the OE system i installed on my 87 from an 89 donor doesn't do that. it'll keep the throttle mashed on a long uphill or headwind indefinitely.
i've improved the vacuum on two VW/Audi CC by sucking a mild soap water solution thru the intake port. LOTS of dirt came out and the vacuum inches improved. can't remember what those pumps produce in terms of vacuum but i DO remember the cleaning resulted in a several inches improvement. _________________ -dan
www.thefixitworkshop.com |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1002 Location: Oakland CA
Posted: Tue Mar 28, 2023 10:50 am Post subject: Re: Vacuum pod for Cruise Control |
The instructions in the "how to" thread sited by Howesite can be a bit distructive, breaking the part of the plastic that keeps the switch from sliding out. The thread "Cruise Control Switch Secret - Revealed - Video" shows a safer method to disassemble and some simple tests to determine if you need to take it apart at all. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
Posted: Tue Mar 28, 2023 1:52 pm Post subject: Re: Vacuum pod for Cruise Control |
OK. I think I'll have another look at the brake vacuum switch. I have cleaned and serviced it, but perhaps I did not adjust it properly when reinstalling it. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
Posted: Tue Mar 28, 2023 2:51 pm Post subject: Re: Vacuum pod for Cruise Control |
I should have mentioned there is an excellent troubleshooting guide for the cruise control in the Bentley manual. _________________ 1987 Syncro Westfalia, stock (bought 1994)
Posted: Tue Mar 28, 2023 3:44 pm Post subject: Re: Vacuum pod for Cruise Control |
Red Ryder wrote: |
OK. I think I'll have another look at the brake vacuum switch. I have cleaned and serviced it, but perhaps I did not adjust it properly when reinstalling it. |
i find it somewhat amusing that VW felt the need for a "belt and suspenders" approach to cancelling the the cruise by having both a vacuum break and an electrical switch. this is a vehicle with the lowest power to weight ratio VW ever made with factory cruise, excepting Bays if they ever had it. on a VR6 Jetta, i can see it. a Vanagon in 4th is in little danger of uncontrolled acceleration.
anyway, the vac system switches are one of THREE ways the cruise is cancelled... 1) vac, 2) pedal electrical switch, 3) brake light circuit. well, 4 counting the key.
my point in all this is that you can increase your cruise reliability multi-fold by eliminating the pedal vac lines, not to mention reducing the volume of air that must be evacuated to actuate. of course, have your attorney sign off that this is a proper thing to do but some of us live on the ragged edge.
the OE VW cruise has really good physics on the Vanagon... smooth actuation, full use of throttle travel, good speed control to +- 0.5mph. _________________ -dan
Posted: Tue Mar 28, 2023 6:28 pm Post subject: Re: Vacuum pod for Cruise Control |
Hey Dan:
I totally agree on the failsafe overkill that VW (and Audi) employed on their cruise control. I made my own cheap cruise control from junkyard VW and Audi parts, more as a lark than to save money. I did not use the vacuum valve aspect, although I did use the electric part of those switches.
The CC control computer also receives an input from the brake pressure switch on the brake master cylinder. Double redundancy is good enough for me.
I suspect that the whole VAG group was so spooked by the Audi 5000 "unintended acceleration" myth/debacle/hype that they went overboard on their CC systems in the '80's. _________________ '86 Syncro Westy SVX |
Posted: Fri Aug 18, 2023 4:09 pm Post subject: Re: Vacuum pod for Cruise Control |
Red Ryder wrote: |
OK, I pulled the vacuum switch above the brake pedal again (AT version has only one). I had inverted the copper contacts on the internal shaft when I reassembled it previously. Corrected my mistake and “voila” we have cruise control again!
Mods — please add “SOLVED” to topic title _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
