bruceo98 Samba Member
Posted: Mon Mar 13, 2023 2:15 pm Post subject: Re: So it begins |
Wiring harness from the Subaru needs to go on a diet. rear and front harness.
_________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Tue Mar 14, 2023 3:03 pm Post subject: Re: So it begins |
Today we eliminated all the unnecessary wiring like the air bag wiring,ABS wiring,and door wiring .What a job. Hope it runs after this.lol
Left everything else cause I'd like to use this harness with as much as the subaru accessories as possible. A/C unit, instrument cluster , radio, steering column with all the controls on it and of course the engine management. _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Wed Mar 15, 2023 7:58 pm Post subject: Re: So it begins |
Put the rear Suspension together today and got it back on the tires . I’ll adjust the height after I put the car together
Posted: Fri Mar 17, 2023 3:54 pm Post subject: Re: So it begins |
M
Mock up with the motor and trans . Got my Subarugears motor and trans mount and subanose _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Wed Mar 22, 2023 10:00 am Post subject: Re: So it begins |
Need to get a shifter. any recommendations?
I installed the shifter linkage and from what I've been reading the way they hook it up won't work. It will probably work with the motor on the upper engine mount on a Subarugears mount but that puts the motor too high and it will need all kind of cutting into the body. So they said to lower the motor on the lower holes. only problem with that is, it moves the transmission linkage way high and the shift rod doesn't line up right. so i had to fab up a different setup for it to work,
Posted: Thu Mar 23, 2023 3:26 pm Post subject: Re: So it begins |
Ordered a Gene Berg 6710 shifter today. No reverse lock out and ball instead of the T handle. Subaru shift pattern on the ball.They are currently out of bases so it might take 2 weeks before they can even start building it. I can wait for a good shifter. _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Tue Mar 28, 2023 2:58 pm Post subject: Re: So it begins |
Brake lines run. Was a PITA getting the rear bent and installed but this is all it gets.
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4390 Location: Stuck in Ohio
Posted: Tue Mar 28, 2023 5:44 pm Post subject: Re: So it begins |
Thanks . I’m kinda a braided and AN nut as you can see from my last car build . Costly , but worth it to me .
Posted: Fri Mar 31, 2023 9:32 am Post subject: Re: So it begins |
Got the Hydraulic clutch setup from Subiworks. you have to modify the clutch arm to get a straight shot at the master cylinder. I welded it solid on both sides and then put a lil weld on each corner , No biggie. I learned long ago when you start customizing something you may have to modify things. Other than that it fits good.
Posted: Fri Mar 31, 2023 2:51 pm Post subject: Re: So it begins |
We have brakes and clutch. Gas pedal is drive by wire and i have to mount that on the body since it sits too high to mount on the chassis.Just need to deburr the hole I had to cut .So now the chassis is done for now. On to the body next.
Posted: Fri Apr 07, 2023 2:44 pm Post subject: Re: So it begins |
Cuttin up. now the rear section with motor is mocked up to start cutting the rear panels to fit.
sb001 Samba Member
Joined: May 19, 2011 Posts: 10399 Location: NW Arkansas
Posted: Fri Apr 07, 2023 3:53 pm Post subject: Re: So it begins |
Crazy cool. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Sat Apr 08, 2023 8:42 am Post subject: Re: So it begins |
Trying to put 10 lbs of you know what in a 5 lb bag..lol. but it'll work out i think.still have to clean up the edges.
Posted: Sat Apr 08, 2023 9:49 am Post subject: Re: So it begins |
muffler is going to fit in there nicely.
agramer1966 Samba Member
Joined: October 17, 2010 Posts: 143 Location: Northern Poland
Posted: Sat Apr 08, 2023 12:12 pm Post subject: Re: So it begins |
That is one impressive build 👍. _________________ 1966 VW1300
1973 VW1302
1974 VW Trike
1984 924
Bunch of old Jap motorbikes
Instagram & YT: #agrameroldoctane |
Posted: Sat Apr 08, 2023 12:17 pm Post subject: Re: So it begins |
Thanks everyone for the kind words . Does anyone know where I can find some fatty rear fenders? I’m not liking the way the rear wheels are close to the fender lip. I see some that are fiberglass but I’d like steel. If I can’t find any I guess I’ll have to make them myself _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
RLFD213 Samba Member
Posted: Sat Apr 08, 2023 4:54 pm Post subject: Re: So it begins |
Bruce creative car craft has widen fenders if you’re ok with fiberglass. The quality is top notch. |
Posted: Sat Apr 08, 2023 7:26 pm Post subject: Re: So it begins |
RLFD213 wrote: |
Thanks . I found glass fenders . No steel fenders . I only need about an inch or and a half to bring the fender out over the tire without worrying about it rubbing . Guess I’ll have to do it myself . Another unplanned project . But no hill for a mountain climber . _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
