Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1872 Location: S>E>Alabama
Posted: Mon Mar 20, 2023 4:01 pm Post subject: Aftermarket tank |
Std tank was full of junk so we got a Dansk.Fits good however the fuel vent bung is much larger 15mm/vs 9 mm of stocker Any suggestions without a Frankenstien solution
? _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Joined: December 28, 2016 Posts: 310 Location: atlanta ga
Posted: Wed Mar 22, 2023 9:06 am Post subject: Re: aftermarket tank |
show us a picture of to what you are referring, there is a late and an early tank |
allaircooled Samba Member
Joined: March 09, 2006 Posts: 5 Location: Lakeland, FL
Posted: Sat Mar 25, 2023 6:52 pm Post subject: Re: aftermarket tank |
I had the same issue with my replacement tank. I just found a plastic reducer, so a short piece of house that is the larger diameter, to the reducer, than the smaller diameter hose to the expansion tank. |
Posted: Mon Mar 27, 2023 5:12 pm Post subject: Re: aftermarket tank |
any chance of the source for the reducer? _________________ 71 westfalia
Starbucket Samba Member
Posted: Tue Mar 28, 2023 4:56 pm Post subject: Re: aftermarket tank |
Ace Hardware. |
Posted: Sun Apr 02, 2023 5:38 pm Post subject: Re: Aftermarket tank |
plastic or cpvc or neoprene? Def need this to move foward _________________ 71 westfalia
Posted: Sun Apr 02, 2023 6:30 pm Post subject: Re: Aftermarket tank |
Ace has plastic or brass. |
Posted: Tue Apr 11, 2023 8:11 pm Post subject: Re: Aftermarket tank |
Sorry it took so long for me to get back to you. I'm away from home for up to 6 weeks at a time and I have a lot of family time to catch up with.
Anyways all I did was use a brass hose reducer. If you google brass hose reducer you will see what I am talking about. Just need the size of the hoses you are using. _________________ '75 Porsche 911 |
Posted: Wed Apr 12, 2023 3:42 am Post subject: Re: Aftermarket tank |
thank you _________________ 71 westfalia
