Anyone ever use these trailer wheel chocks for towing a bug?
sportin-wood
sportin-wood is offline
PostPosted: Mon Mar 27, 2023 8:13 pm    Post subject: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
https://www.amazon.com/Autofonder-Vehicle-1986lb-U...B09X17XTGF
So I have a tandem axle utility trailer that's not equipped with tie down rings and wondered if these trailer chocks might be ok for towing my '66 bug? I realize the ratchets require room under the fenders but I won't be lowering mine and thought the weight would be safe for a car as small as a bug? Your thoughts?
Paused 66 project bug
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Mon Mar 27, 2023 8:38 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
Not these particular tie downs, but similar.
I used to help a race team in Iowa. The race car was inside a trailer that had this type of tie down setup.
They held the car inplace week after week inside the trailer.
Maybe consider longer tracks for the tie downs to clip into, for extra strength to hold your car on your utility trailer.
I'll be looking for the same setup soon. Wink
EDIT: With the car wheel strapped down. Even without the chock. The car will stay in place.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
sportin-wood
PostPosted: Mon Mar 27, 2023 8:57 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
Thanks for your input. Also, I had read that the car should not be in park and E-brake off? That sounds contrary to what I thought it should be....
esde
esde is offline
PostPosted: Mon Mar 27, 2023 9:09 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
I tow a bunch of different things, cars, construction equip, etc. Those straps are great for trucks and stuff with open wheel wells. But on a beetle or bus, the ratchet handle will end up in the fender, where you don't have room to move it.
Best bet for me has always been using these straps
https://www.amazon.com/Big-Autopart-Straps-Strengt...mp;sr=8-27
Two on the front beam, and one around each axle tube, and then use standard dot rated ratchet straps.
I always set the hand brake.
PostPosted: Mon Mar 27, 2023 9:10 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
Maybe load the car and leave it in neutral. But I'd set the parking brake.
As an after thought, You can use the same type tie down setup. But, instead wrap the straps around the rear axle tubes and the front lower torsion bars to hold the car in place.
Buy Once, Cry Once!
PostPosted: Mon Mar 27, 2023 9:12 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
Your Amazon link is broker esde.
Buy Once, Cry Once!
sportin-wood
PostPosted: Tue Mar 28, 2023 1:10 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
With this method, are you supposed to crisscross the straps to either side of the trailer? Or not?
FritzCP
FritzCP is offline
PostPosted: Tue Mar 28, 2023 1:29 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
I do Esde Method and have learned to Cris Cross both front and rear strap sets. Ive found this stops the car from shifting to the side of the trailer whilst going down the road. Wet wood planks or bouncy conditions make the suspension bounce and tires hop and the will car shift a lot if not criss crossed. the rear especially since its farthest from the hitch/ pivot point. Junkers that tires lose air on the trip also cause sliding over headaches.
So, Criss Cross Apple Sauce every time.
Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller
esde
esde is offline
PostPosted: Tue Mar 28, 2023 7:27 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
I do criss cross the straps, and usually run a safety chain. Hauling heavy equipment you cannot be too careful, and I let that thinking carry over.
Most importantly, always tighten your straps after a few miles. They ALWAYS will stretch and loosen, especially new ones. And tie your loose ends, so they don't get caught in the wheels.
I saw a guy come into a show last summer, with one strap front and one strap rear, on a beautiful oval. No safety margin, crazy.
modok wrote:
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue Mar 28, 2023 7:45 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
I have a 16 foot utility trailer that I have used a few times, when the tow bar does not work out. But when I do utilize the BIG trailer, I run a chain with 2 hooks. 1st hook anchors to the front corner of the trailer. I then run the chain in through the front of the beam. Over the tunnel, under the gas tank and back out the axle beam, between the tubes. Run it over to a come a long at the other front corner and attach it. Now go to the back.
Another chain with hooks! From the back corner the chain gets attached. Then I run it over to the between the transmission and the frame horns, under the trans to the other side and back over the other frame horn. Then to the opposite corner with another come a long. Tighten that up so there is slight tension at both. Done!
Agree with the above advice. Pull over a few miles down the road and tension those chains or stripes one more time. They always settle into place and lose their initial set!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
zerotofifty
zerotofifty is offline
PostPosted: Tue Mar 28, 2023 9:38 pm    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
Looks chincy. little screws pictured. made for ATVs and lawn mowers I certainly would not depend on them alone. strap the Bug down from front beam and rear torsion tubes to a solid part of the trailer I suggest.
Small galvanized bolts, no mention of the strength, are the bolts even graded? ( made in china!) if you push your bug onto the trailer it will not be fun to push all four tires over the chocks which are bolted in place. maybe ok if you drive the bug onto the trailer, but pushing it may be a problem.
I say not, but if you do use them, use quality graded bolts and nuts and be prepared to drive the Bug on and off the trailer, AND strap the front and rear torsion tubes down too.
sportin-wood
PostPosted: Wed Mar 29, 2023 2:35 am    Post subject: Re: Anyone ever use these trailer wheel chocks for towing a bug? Reply with quote
All good points and suggestions. Thanks guys!
