Kdj Samba Member
Joined: January 28, 2017 Posts: 139 Location: Naptown
Posted: Tue Mar 28, 2023 4:56 pm Post subject: Cape Lookout National Seashore |
Does anyone have experience taking your vanagon out there? I’m lifted 2WD with good AT tires and some off road experience in sand. I do have recovery gear also. Really looking for sand conditions, is it super soft or reasonably firm? I’ve seen a a lot of different kinds of vehicles out there in online pictures, but I don’t want to be the guy who got stuck coming off the ferry!
Any feed back accepted! |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1390 Location: Taos NM
Posted: Tue Mar 28, 2023 5:57 pm Post subject: Re: Cape lookout national seashore |
Best defense against sand is the stock 14 inch rim with a large AT tire
Air down to 15 psi and you will float over most sand
I keep a compressor with me for beaches in mexico so that I can air back up once on the solid dirt roads |
nesurfer99 Samba Member
Joined: December 15, 2013 Posts: 67 Location: Jacksonville, Florida
Posted: Tue Mar 28, 2023 8:07 pm Post subject: Re: Cape Lookout National Seashore |
I was there in a syncro last fall and did not have any issues. I personally would not attempt it in a 2wd but I travel alone mostly and don't enjoy getting stuck. FWIW I believe the park service requires you to have 4wd. There is a mandatory check in when you get off the ferry but they are obviously not crawling under your vehicle and counting differentials.
There is lots of traffic on the beach and road so if you do get stuck I'm sure someone will pull you out.
As long as you have momentum you should be able to power through the deeper sections.
Here are a couple of pics from that trip.
Good luck!
_________________ 89 Carat on the road and collecting (s)miles |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Wed Mar 29, 2023 5:20 am Post subject: Re: Cape Lookout National Seashore |
nesurfer99 wrote: |
FWIW I believe the park service requires you to have 4wd. There is a mandatory check in when you get off the ferry but they are obviously not crawling under your vehicle and counting differentials.] |
From NPS site
“Types of Vehicles Allowed
Four-wheel drive is highly recommended for the islands as two-wheeled drive and all-wheel drive (AWD) vehicles are more easily stuck in the soft sand areas of the beach and sand trails. Even with a four-wheel drive vehicle, it is also advisable to lower the tire pressure to 20 psi or lower. See our tips on beach driving for more information.
All-terrain vehicles (ATVs) and small utility vehicles (UTVs) can also be driven in the areas designated for vehicles. To ensure a safe and enjoyable visit to our beaches, check out the ATV riding rules before you come. These are enforced.” _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
R0Batt Samba Member
Joined: April 05, 2021 Posts: 57 Location: Charlotte, NC
Posted: Yesterday 7:14 am Post subject: Re: Cape Lookout National Seashore |
Bump.
Has anyone done it yet in a 2wd vanagon?
I think im going to try it in the next month or two.
Going out there with my buddy that has a lifted duramax on 35s
My van is lifted with some bigger tires and the General Grabber A/Ts
I plan on going out there with a shovel, max tracks, and a tow rope. _________________ 85 Westy
Charlotte, NC |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Yesterday 6:22 pm Post subject: Re: Cape Lookout National Seashore |
^^^ Sounds fun, good start.
If you plan to air down to 10-15 psi & pack a ~$100 12v air compressor, you probably
won’t even need the max tracks, rope <or> ever have to bother your friend.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
E1 Samba Member
Joined: January 21, 2013 Posts: 6542 Location: Westfalia, Earth
Posted: Yesterday 7:30 pm Post subject: Re: Cape Lookout National Seashore |
There’s a whole lotta factors in sand driving and especially with 2WD.
We drove out Pismo Beach once on 14s with 27x8.5 tires. In my opinion, that combination was the best start in profile over and above any other factors. We were on BFG ATs (previous to KO2s) and talked to some way more-seasoned sand runners with similar tires and pressured down to 8.
Not sure I’d go that low again, and especially not on C-rateds, but at one point there was a line of trailers right above the high tide line, we had to go a few hundred yards “out back” through the deep, and did not get stuck. Total round-trip was 7 miles of sand.
We run 215/65-16 KO2s now, and the D-rating is the Bomb — on pavement but not so much on sand. The Peloquin helps a lot unless throttle input gets excessive, as does a revvier ring & pinion to bump to 2nd at slow speeds, but the sidewalls are lower and stiffer and it’s a small cut below the 14s. But still very usable.
Traction ramps have bailed us out maybe 10 or so times over 11 years. Invaluable, we have two and may buy two more. When things go really wrong, I’d say they’re far more valuable than any tires.
No matter all that, the secret if digging in is such a low rpm that the thing wants to stall — similar to driving in snow, really. Staying calm and being fully committed when it’s sketchy is a huge part of not getting stuck, hesitation is the enemy nearly every time.
The road photo above is way easier than what a 2WD can do, standard stuff really, if the above considerations are fully in play. The beach photo is a little trickier and needing momentum, but that sand looks damp and firm which is a big help. Dry is the worst. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
R0Batt Samba Member
Posted: Today 12:15 pm Post subject: Re: Cape Lookout National Seashore |
Finally some optimism!!!
I will definitely air my tires down the general grabbers are load range SL so they should be pretty soft and good for the sand
Yeah ive offroaded a good bit and plan on scouting my line before driving on to the beach to make sure I dont stop in the soft stuff _________________ 85 Westy
Charlotte, NC |
