mhag3112 Samba Member
Posted: Thu Mar 30, 2023 11:10 am Post subject: Front bump stop 1970 |
Is there a bump stop for the front beam on a 1970 KG?
I have dropped spindles with 15*5 sprinstar 4 lug 165 60 tyres.
On full lock it’s almost possible to rub a fender even though I have over 2cm clearance stationary. Is it possible to modify the bump stop to limit extreme ROM on full lock? Or should I just go back to 155 60s?
Many thanks |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Thu Mar 30, 2023 1:26 pm Post subject: Re: Front bump stop 1970 |
those adjustments are bolts. screw them in for more turning, out for less _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Thu Mar 30, 2023 2:25 pm Post subject: Re: Front bump stop 1970 |
Thank you for the reply, I don’t think I explained quite right. It’s not the steering lock I want to limit.
I want to know if I can limit the maximum suspension travel, & if that’s ok. I understand older beams have a bump stop but I’m not sure about 1970. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Thu Mar 30, 2023 2:28 pm Post subject: Re: Front bump stop 1970 |
Correct. There are no stops for vertical travel like there is in the rear.
I believe that there is on a link pin beam but not ball joint.
The steering stops can be adjusted so you don’t rub the inside of the wheel against the control arm or the sway bar but that’s about it.
I went through several different sets of wheels to combat my rubbing issues with dropped spindles. I have landed on 15X5.5 with a 5” backspace.
Using 195/45/15 tires there is no rubbing on the fender but between stock spindles and dropped spindles I have lost some turning radius.
I guess there is always a trade off.
I’m thinking of picking up a used lowered beam to see if I can get the same stance and get my turning radius back. It’s fine on the street driving around but can be annoying in tight parking lots. _________________ Volkswagen!
(Compression 8.7:1) |
Starbucket Samba Member
Posted: Thu Mar 30, 2023 2:38 pm Post subject: Re: Front bump stop 1970 |
Put on some coil over shocks in the front it fixed my lowered 70. |
Posted: Thu Mar 30, 2023 2:53 pm Post subject: Re: Front bump stop 1970 |
I tried those. Sort of worked but made the ride too stiff for me.
Lots of dancing over man hole covers and on rough roads. _________________ Volkswagen!
Joined: August 31, 2013 Posts: 12860 Location: North Carolina
Posted: Mon Apr 03, 2023 9:15 am Post subject: Re: Front bump stop 1970 |
There are bump stops on a VW with a ball joint beam, that is the additional part that is sold with original design style shocks. Some aftermarket shocks eliminate this extra part.
If you want to limit the suspension travel on a ball joint beam, you can install “hook & rod limiters”.
Steering stops are different, this is adjusted by the two bolts on the vertical piece that is welded to the beam next to the steering box. Many narrowed, aftermarket beams do not have this. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
