c21darrel Samba Member
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4419 Location: Stuck in Ohio
FeveredMind Samba Member
Joined: December 28, 2016 Posts: 147 Location: Riverside, CA
Posted: Fri Mar 11, 2022 8:14 pm Post subject: Re: 67 Kombi Custom |
So I went back and looked at the nose skin and the door. I would say that the nose skin does set in a bit further than the door does. The door is not hitting the door seal metal but it’s very close. I would say the door sits about 1/8” away from it.
I decided to take the door back off and noticed this.
The adjuster plate won’t slide any further to the center of the bus. I’m holding it as far back as possible in the picture. It almost looks like something dented the inside of that A pillar. Should I maybe relief cut the inside of the A pillar to allow the adjuster plate to slide inwards a bit more? That extra 1/8” is about what I need for everything to line up. _________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing. |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Posted: Sun Mar 20, 2022 7:57 pm Post subject: Re: 67 Kombi Custom |
I decided to take a run at the parcel tray today. Here are the results.
Tried to tack weld these holes, but it just burned through. Time to make a patch.
Treatment for the rust
I also had some rust in the rear roof and and drip rail. I knew it was through to the center, but it was a bit worse than I thought. I’ll get it sorted out.
Posted: Thu Mar 24, 2022 10:24 pm Post subject: Re: 67 Kombi Custom |
Got a bit more work done tonight.
Cut out a dent that I knew I would have a hard time fixing and welded in a new piece.
Also, my dad helped me flip my spindles. We shimmed them up and remounted them on the beam!
Marching on! _________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing. |
Posted: Sat Mar 26, 2022 7:09 pm Post subject: Re: 67 Kombi Custom |
Fixed up a small hole in the rear window. Little steps are still steps.
Posted: Sun Mar 27, 2022 6:38 pm Post subject: Re: 67 Kombi Custom |
Was trying to repair some pin holes in the side panel with weld, but kept blowing through. Decided to open it up and see what we were working with. I’m so glad we did. Lots of hidden rust in there. Got it all cut out, treated and rewelded. Ran out of welding gas though so that put an end to my day. :/
Aw well, Onward!
Posted: Sun Apr 03, 2022 9:07 pm Post subject: Re: 67 Kombi Custom |
Another piece stripped, straightened and primed.
Posted: Sat Jun 25, 2022 9:09 pm Post subject: Re: 67 Kombi Custom |
After a long break I made some more progress today.
Posted: Mon Aug 01, 2022 11:51 am Post subject: Re: 67 Kombi Custom |
Finished another area on the bus this weekend that needed repair. The roof, drip rail and support beam were all rusted through. Cut them out and welded new pieces in. On to the next one.
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Mon Aug 01, 2022 3:56 pm Post subject: Re: 67 Kombi Custom |
Imadesignerd wrote: |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Sun Aug 07, 2022 7:19 pm Post subject: Re: 67 Kombi Custom |
Crawled under the bus this weekend to scale off all of the old undercoating and crud. Man, that was a super dirty job. Here are some before and afters.
Posted: Fri Mar 10, 2023 4:43 pm Post subject: Re: 67 Kombi Custom |
More progress
Forgot to take a picture of the piece I welded in. whoops
Posted: Sat Mar 11, 2023 10:35 pm Post subject: Re: 67 Kombi Custom |
PO left me a bullet hole to fix. Hope they still have their foot.
The recesses in the floor under the seat mounts were rusted out in several places so I fabbed some new ones up and welded them in.
Posted: Wed Mar 15, 2023 11:51 am Post subject: Re: 67 Kombi Custom |
Posted: Fri Mar 31, 2023 3:49 pm Post subject: Re: 67 Kombi Custom |
Can anyone tell me if this seam in the frame is supposed to be there or not?
Also, the PO had safaris in this bus but it didn’t come with them. If I plan on purchasing a set, should I weld up the current holes and drill new ones for the new set of safaris or should they line up perfectly with what I already have there? _________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Fri Mar 31, 2023 6:32 pm Post subject: Re: 67 Kombi Custom |
FeveredMind wrote: |
Factory seam weld. That seam fooled me ever since I first looked under a bus. |
Posted: Fri Mar 31, 2023 6:49 pm Post subject: Re: 67 Kombi Custom |
BarryL wrote: |
Thanks for the response. Any reason to believe it might fail and should be reinforced? _________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing. |
