BMFBMF Samba Member
Joined: November 13, 2020 Posts: 356 Location: Swtzerland
Posted: Fri Mar 31, 2023 10:40 pm Post subject: Electrical precautions when welding? |
I'm preparing to weld on my beetle,
What electrical precautions should I take, Ill remove the battery and completely disconnect the alarm control module, put the ground right next to where we are welding , any other risks, relays, regulator, started motor? etc., I should think about?
THANKS.
Bmf _________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
anthax Samba Member
Joined: October 21, 2016 Posts: 283 Location: Hälsingland, Sweden
Posted: Sat Apr 01, 2023 1:32 am Post subject: Re: Electrical precautions when welding? |
Disconnecting or removing the battery is fine on old stuff. |
Schatzievw Samba Member
Posted: Sat Apr 01, 2023 5:33 am Post subject: Re: Electrical precautions when welding? |
Not much to fry on old bugs. That is why after a nuclear EMP attack you will see plenty of beetles running around! |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Sat Apr 01, 2023 8:20 am Post subject: Re: Electrical precautions when welding? |
be more worried about starting a fire than messing up any electrical stuff _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
