Clementine79 Samba Member
Posted: Tue Apr 25, 2023 8:50 am Post subject: Re: What did you do for your Bay recently? |
That looks great, we are looking for an upgrade to ours. Is the sisal easier to keep clean? _________________ 1979 VW BUS
Riviera Penthouse Model |
creative native Samba Member
Posted: Tue Apr 25, 2023 8:54 am Post subject: Re: What did you do for your Bay recently? |
Clementine79 wrote: |
That looks great, we are looking for an upgrade to ours. Is the sisal easier to keep clean? |
Yes indeed. It is rubber-backed and a more durable material than the carpet. The sisal is the same coco-fiber that the optional floormats were made of in the 60's & 70's in VWs.
Thank you, Clementine79, I really like the way it looks too. _________________ "The holy land is everywhere." ~ Black Elk
1979 Westfalia P27, California FI emissions spec. 100% VW fleet: '79 Westfalia, 2013 Touareg Lux (Toffee Brown/Cornsilk Beige), 2005 Passat GLX. |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1197 Location: Vancouver, BC
Posted: Wed Apr 26, 2023 12:07 pm Post subject: Re: What did you do for your Bay recently? |
Crawled under my Bus to check the transaxle oil and noticed that the inside CV rubber boot had split so spent a couple hours on Sunday taking it off and replacing the boot with an off-road kit.
Messy job but skimmed off the existing grease and repacked it with new grease and re-installed the axle. Everything went smoothly except for the last bolt as it kept getting caught up on the pull tie that came with the kit. What a pain in the ass as the tolerances are tight so I think I'll order a set of the boots off a Tiguan as many others have recommended but I've had no problems with the off-road boots that I installed on the outside about 2 years ago.
Re-checked my toe-in front and back as well and all looked good. Ready for a road trip this weekend as we are finally forecast to have some sunny, Spring weather this weekend. _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
Beef_Wallington Samba Member
Joined: April 28, 2015 Posts: 30 Location: Prince George, British Columbia, Canada
Posted: Mon May 15, 2023 8:53 am Post subject: Re: What did you do for your Bay recently? |
Just recently replaced the light wiring in my engine bay in its entirety with a donor section.
After some scrubbing I have pretty much all working lights for the first time since I got it.
All that's left is one front turn signal not flashing, current suspect is my relay. Once that's done I'll be able to drive without resorting to throwing gang signs _________________ 1976 Westfalia 2000cc EFI (Twinkie) |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1272 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Tue May 23, 2023 2:18 pm Post subject: Re: What did you do for your Bay recently? |
finally got to a project i’ve been wanting to do for decades.
the usb plug on my pioneer head unit broke after only 2-3 years (piece of crap!) soes, while i could still connect my phone via bluetooth, i couldn't charge it. using my battery pack was a pain. after looking for a male plug for my silver socket many times, i finally bought one.
but, when i tried to insert it, i found it way too tight. so, being an american male, i pushed harder. bent two of the brass tabs back. so, being an american male, i broke them off.
but, no power.
upon investigation i discerned that the wire i’d been hooking to the socket for years was the return wire from the rear-window defogger, which i never use cause my rear curtains are perpetually closed. i’ve no idea what happened to the power to the socket, as it is nowhere to be seen under the dash. so, i ran a new wire from the hazard-light switch (always powered) to the silver socket, and voila, power to my usb adapter.
_________________ 1978 Champaign Edition 2 Westfalia
Posted: Tue May 23, 2023 3:31 pm Post subject: Re: What did you do for your Bay recently? |
Isn't it so satisfying to get something like this working again, Tom? Congratulations! _________________ "The holy land is everywhere." ~ Black Elk
vwbusride Samba Member
Joined: January 26, 2004 Posts: 120 Location: Where the city thinks we are a bus chop shop
Posted: Sat Jun 03, 2023 6:11 pm Post subject: Re: What did you do for your Bay recently? |
I just completed my first maiden voyage after doing a steering box upgrade in my 1971 bus. This upgrade was worth the hassle.
I made a little video of the adventure.
Posted: Mon Jun 12, 2023 4:27 pm Post subject: Re: What did you do for your Bay recently? |
Posted in my thread but just replaced my Pop top screen this past weekend. Did it the old fashioned way, sewing it in by hand.
Mid job pic with the bottom section still to go.
gutshot2 Samba Member
Joined: March 18, 2016 Posts: 2 Location: Simi Valley, CA
Posted: Wed Jun 14, 2023 7:14 am Post subject: Re: What did you do for your Bay recently? |
I have a 1969 VW Bus
Last night adjusted my newly installed Solex H30 carb!
Tonight gonna work on horn connections see if I can get that going! _________________ 1963 Type 3 Notchback
1969 T2 Campmobile Westfalia
1971 Karman Ghia Convertible
1975 Datsun 280Z
2007 997.1 Porsche Targa 4s |
airschooled Air-Schooled
Posted: Wed Jun 14, 2023 9:06 am Post subject: Re: What did you do for your Bay recently? |
gutshot2 wrote: |
Tonight gonna work on horn connections see if I can get that going! |
Nice. Way to go from elementary school to college right away!
www.airschooled.com |
vwbusride wrote: |
https://youtu.be/8Y1lncrztrU |
congrats on your bus steering properly down the road.
no way you r-n-r’ed that box while keeping that shirt (and your hands) so clean.
insert smiley-face here. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
Posted: Fri Jun 16, 2023 9:03 am Post subject: Re: What did you do for your Bay recently? |
dodger tom wrote: |
vwbusride wrote: |
insert smiley-face here. |
Haha! That steering box upgrade was a complete mess. I saved securing the pitman arm for last after a couple little test drives around town. Thanks for checking out the video. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Tue Jun 27, 2023 11:04 am Post subject: Re: What did you do for your Bay recently? |
Resprayed the black details on the Plump Truck!
Also, installed euro tail lights!
_________________ Some people are so busy being clever they don't have time enough to be wise. |
Sven F Samba Member
Joined: July 24, 2009 Posts: 92 Location: Croatia / Denmark
Posted: Mon Jul 03, 2023 3:01 pm Post subject: Re: What did you do for your Bay recently? |
I made a replacement DIY gas pedal out of scrap aluminum plate and added the buddy's bits linkage.
These buses are pretty robust, but when it comes to hand and foot controls, everything tends to be a bit sloppy.
Here's a video ➡️ https://www.instagram.com/reel/CuP2f1vMxpw/?igshid=MzRlODBiNWFlZA==
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Wed Jul 19, 2023 8:52 am Post subject: Re: What did you do for your Bay recently? |
Gave Moana her first overnight trial in a park in Simi Valley; she came through with flying colors!
She's the red one on the right.
Next up... adding power brake booster and rework the center link pin/bushing (which I am outsourcing this time).
Then electrical, then window regulators, seals, locks, curtains, ... well, you know. |
Posted: Thu Aug 03, 2023 2:27 pm Post subject: Re: What did you do for your Bay recently? |
Helping another VW Bus enthusiast with a 69 Camper do some major repairs.
Grinding the tube smooth and then plan to put a 3.5" ID pipe over and weld in place then cut out the rusted frame rail and replace it with a new fabbed piece, add new jack and support points and reassemble.
The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 704 Location: Arizona
Posted: Thu Aug 03, 2023 5:47 pm Post subject: Re: What did you do for your Bay recently? |
Now that’s a good deed! This world needs more guys like you! Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Thu Aug 03, 2023 5:51 pm Post subject: Re: What did you do for your Bay recently? |
Shonandb wrote: |
Helping another VW Bus enthusiast…
is that air suspension? _________________ 1978 Champaign Edition 2 Westfalia
Posted: Fri Aug 04, 2023 9:40 am Post subject: Re: What did you do for your Bay recently? |
The Volkswagen Ranch wrote: |
Now that’s a good deed! This world needs more guys like you! Bob |
Thanks Bob. I always believe that what you do for others comes back around in a positive way. _________________ *******************************
Posted: Fri Aug 04, 2023 10:01 am Post subject: Re: What did you do for your Bay recently? |
dodger tom wrote: |
Shonandb wrote: |
is that air suspension? |
Yes, kind of, but soon to be all metal again. Can't believe how thin the frame rail metal is on Early Bays. Feels like paper so I'll have to sandwich it with heavier gauge metal to be able to weld it. _________________ *******************************
