OZZBug Samba Member
Joined: December 17, 2022 Posts: 8 Location: Australia
Posted: Mon May 22, 2023 5:56 am Post subject: Super Beetle Steering Box Disassembly |
I'm Stripping a Super Beetle steering box for a rebuild. Im not sure how to remove the worm spindle. Am I supposed to tap the end of the worm spindle with a soft mallet on the splined end and push it out the other side? The other side is capped with a plastic/rubber cap. I don't want to damage this as I have yet to see a replacement available.
I did come across this image where the first picture shows that I'm on the right track
Is it a matter of tapping the whole worm spindle assembly bearings and all out one side? I cant see any circlips or any thing like that holding the assembly in place.
I have read this thread a few times but its more orientated around earlier beetle beam end steering box's
https://www.thesamba.com/vw/forum/viewtopic.php?t=...f9a33a90b0 |
Starbucket Samba Member
Posted: Mon May 22, 2023 11:28 am Post subject: Re: Super Beetle Steering Box Disassembly |
This may help,
From the bentley manual |
OZZBug Samba Member
Posted: Tue May 23, 2023 12:25 am Post subject: Re: Super Beetle Steering Box Disassembly |
Thanks Starbucket. I probably should have mentioned that I have the Bentley manual. It refers to checking and adjusting the steering box but not really disassembly. Diagrams show that the only way out for the spindle is out the rear end. I just don't want to whack the thing with a hammer without really knowing if it's the right way then risk damaging the rubber plug on the rear side or destroy the steering box altogether. |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Tue May 23, 2023 8:32 am Post subject: Re: Super Beetle Steering Box Disassembly |
I’m surprised you have a rubber plug and not a worm adjuster and locknut. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
OZZBug Samba Member
Posted: Wed May 24, 2023 5:46 am Post subject: Re: Super Beetle Steering Box Disassembly |
Sooo this arrived in the mail today!
It has shed a little more light on my situation. I was looking at new seals for my steering box the other day and the website specified that the seals we're from either a German or non-German built steering box. My super is an Australian built bug so I'm guessing its a German super beetle steering box but I could be completely wrong here?
bnam I do have a worm adjuster and lock nut but its on the splined end of the worm spindle. You can see the thread in the housing in the first pic I posted. There is a seal there and the worm spindle passes through it. Maybe this is the difference between the German and non-German steering boxes.
Unlike the steering box in the book I just received. Hence the rubber bung in the back end.
Different but the same I guess
At the end of the day the worm spindle looks like it needs to come out the rubber bung end. I'll procrastinate a few more days, do some more reading and hopefully come up with the courage to start trying to work it out with some gentle blows. |
Blue69Baja Samba Member
Joined: September 04, 2008 Posts: 1065 Location: Fair Oaks
Posted: Wed May 24, 2023 8:38 am Post subject: Re: Super Beetle Steering Box Disassembly |
Here is a great videos on rebuilding the SB steering box.
JIm.
_________________ 69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original.. |
OZZBug Samba Member
Posted: Thu May 25, 2023 5:00 am Post subject: Re: Super Beetle Steering Box Disassembly |
Thanks Blue69Baja. Ive already watch that video. It didn't include removal of the worm spindle unfortunately. |
Bug Curious Samba Member
Joined: September 30, 2018 Posts: 58 Location: Georgia
Posted: Wed May 31, 2023 3:58 am Post subject: Re: Super Beetle Steering Box Disassembly |
I’m having the same problem now on my 71 super. |
bnam Samba Member
Posted: Wed May 31, 2023 4:38 am Post subject: Re: Super Beetle Steering Box Disassembly |
OZZBug wrote: |
The difference is because you have a RHD steering box. The RHD steering box uses the same case as the LHD (part number 113 415 111A) - but since it is mounted on the opposite inner fender, it is reversed and the adjuster/locknut faces the steering wheel side. My car is probably the same. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
