sb001 Samba Member
Posted: Thu May 18, 2023 7:38 am Post subject: Re: 1969 Autostick expert needed |
bobalowbill wrote: |
I pulled the engine yesterday had metal shavings in torque converter going to pull transmission pan today to see if there is metal shavings there |
Did you happen to find a lot of excess ATF fluid in or around the bell housing? Wonder if one of those ATF hoses or banjo fittings came loose from circuit in the bell housing to carry ATF to the torque converter, loss of ATF in the torque converter would explain too much slippage between engine and tranny (i.e. wheels not turning) and metal shavings. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Fri May 26, 2023 7:06 am Post subject: Re: 1969 Autostick expert needed |
I agree on the longevity, I've been driving my '69 Autostick with the modified wiring harness for 33 years, last I checked 16 years ago I could still read the part number ink samped on the friction surface of the clutch face when I repacked my original throwout bearing _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
bobalowbill Samba Member
Posted: Sat Jun 10, 2023 3:46 pm Post subject: Re: 1969 Autostick expert needed |
I FOUND OUT THE VW I HAVE IS A 1974 AUTOSTICK. PULLED ENGINE AND PULLED THE BELLHOUSING APART CLUTCH IS GONE JUST DUST. NOW I NEED HELP TAKING THE CLUTCH APART, HOW DO I REMOVE THE RELEASE BEARING? |
