ArthurMcKenzie Samba Member
Posted: Mon Aug 23, 2021 6:12 pm Post subject: 71 standard rear seatback too low/ latch trouble |
Howdy I am restoring the interior of my 71 beetle and encountered a problem with the rear seat back. I believe I have attempted to install it correctly. The bottom I think is in the right position.
From what I can tell functional, it just seems that the entire seat is too low, the seat will not fit into the latch like it is supposed to and it also seams like the bumpers are misaligned too low as well.
I also have great difficulty installing the bottom of the rear seat once the back is installed. Its as if there is some hidden bolt hole that I cant see a few inches above the one that I use. from what I remember when I originally got the car it functioned fine, so I am looking to if anyone has had a similar experience or has a solution.
[/url] |
ptavian Samba Member
Joined: September 20, 2016 Posts: 89 Location: SAN FRANCISCO
Posted: Wed Nov 03, 2021 2:22 pm Post subject: Re: 71 standard rear seatback too low/ latch trouble |
Hello- I have a '70 standard with the exact same problem!! I see no one has posted a solution for this. Any pointers anyone could give would be greatly appreciated- thanks all |
regordracis Samba Member
Joined: June 16, 2019 Posts: 148 Location: Hamilton Ontario Canada
Posted: Thu Nov 04, 2021 9:28 am Post subject: Re: 71 standard rear seatback too low/ latch trouble |
me three ... 72 SB ... will be following .... _________________ Roger ... "Lost in the haze of alcohol-soft middle age" |
sb001 Samba Member
Posted: Thu Nov 04, 2021 10:46 am Post subject: Re: 71 standard rear seatback too low/ latch trouble |
That catch is adjustable. Loosen the two bolts holding it on and slide it downward toward the bottom of the car then tighten the bolts.
The new thicker padding you put in your seat back or seat bottom (or both) causes it to be more difficult to install the rear seat bottom now. Same exact issue with mine, I really have to force it but everything is correct. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Thu Nov 04, 2021 2:59 pm Post subject: Re: 71 standard rear seatback too low/ latch trouble |
Yeah- I was messing around with mine last night and discovered that the catch is adjustable but I’m still over an inch too low! What the heck? I’ll post pictures soon |
Cjschriver Samba Member
Joined: July 31, 2022 Posts: 358 Location: Spokane, WA
Posted: Sat May 27, 2023 11:47 am Post subject: Re: 71 standard rear seatback too low/ latch trouble |
Can anyone verify that this is the correct solution every time? I am having the same issues with the latch in my '69 on both counts. Latch on seat is too low, car mounted catch is too high. Can't stuff the seat bottom in all the way. Some of my older pics do show the car mounted catch being adjustable just like in the OP's pics above
(I DID realize that I had the catches mounted on the wrong side of the car, and fixed that )
but mine are thru my brand new rear quarter panels.
I removed the entire perforated region of the cardboard circle where the bolts go thru, but I'm not sure this would provide enough slop to get to where I need to be. Just like the OP, I have determined that the rear seat backrest IS mounted in the proper upper hole, above the seatbelt mount. There's nothing else that is adjustable, right?
Also, can't get the seat bottom to shove back far enough to drop behind the the bar...
This last pic is of the underside of the seat, toward the driver's side B pillar, showing the overhang of the front edge of the seat
Just push harder or what? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Sat May 27, 2023 11:58 am Post subject: Re: 71 standard rear seatback too low/ latch trouble |
Cjschriver wrote: |
Your technique is incorrect; seats fits in the bottom frame ridge, not above it.. But I'm not good at explaining this. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat May 27, 2023 12:51 pm Post subject: Re: 71 standard rear seatback too low/ latch trouble |
I probably did a poor job of explaining.
What I mean to ask is, do i just need to push harder in the blue direction to get the red corner of the seat behind the green corner of the rail? I'm happy to push harder, I just don't want to junk up the new upholstery. Probably overstuffed it with the dumb foam pad from JBugs. If it ever gets in there, it will be VERY tight.
Thanks Cusser |
