mnihrst Samba Member
Joined: January 10, 2009 Posts: 39 Location: Columbia, SC
Posted: Sun May 28, 2023 6:46 pm Post subject: FINALLY doing some work on the Mini Hearse/MNI HRST |
So, after many years of sitting and being lazy, I am finally starting on the Mini Hearse.
Today was spent on the rear brakes…got as far as I could, but now have to spend some money, so back on hold.
Today I removed all brake hardware and parts, installed new wheel cylinders. While I am in there, I figured I would go ahead and replace the bearings, also need to replace brake lines, I believe they are original. Thus the need for funds.
Hopefully the drums are turnable, as that will save $$$.
Replaced stoppers. |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3693 Location: San Jose, CA
Posted: Mon May 29, 2023 10:16 am Post subject: Re: FINALLY doing some work on the Mini Hearse/MNI HRST |
That little pop-out is cute. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue May 30, 2023 8:51 am Post subject: Re: FINALLY doing some work on the Mini Hearse/MNI HRST |
You don't have to replace Everything.
I only take One side of my brakes apart at a time.
Test drive it and then only replace what is Bad.
Get it running/driving as your first priority!
I only had to replace one soft rubber front brake hose on my 69.
New brake lines will be needed only If they are leaking.
Drive it while you restore it! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Tue May 30, 2023 3:09 pm Post subject: Re: FINALLY doing some work on the Mini Hearse/MNI HRST |
I have my local Car Quest cut the bare minimum on the drums. You don't want them to take any more than needed to get them round again, as they aren't very thick when new. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed May 31, 2023 2:43 pm Post subject: Re: FINALLY doing some work on the Mini Hearse/MNI HRST |
Currently, there is no brake fluid in the lines, so might as well replace what needs to be replaced. Rubber and metal lines are definitely showing their age.
I already have the rubber lines, so that is money already spent…
I still have plenty of other things to work on that don’t require $$$, so might as well do it right.
Still have the sunroof and wiring to do, and clean out the gas tank. |
tjmartin317 Samba Member
Joined: March 18, 2022 Posts: 246 Location: West Virginia
Posted: Sun Jun 04, 2023 8:49 am Post subject: Re: FINALLY doing some work on the Mini Hearse/MNI HRST |
I overhauled my rear end too with new bearings and brakes. Those parking brake adjusters caused me lots of grief, they were rusted to the backing plates and simply would not budge. For the bearings, ACDelco wheelbearing grease is what I used, and a FWD wheel hub press from Autozone. Worked well enough.
I love the look of this thing. Very gnarly. |
