HackAl Samba Member
Joined: March 12, 2016 Posts: 338 Location: Bergen County, NJ
Posted: Wed Apr 19, 2023 7:09 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
Does anybody have a contact number for Andrew Flint other than the main number? I had a conversation with him and he's willing to help but I need to coordinate the delivery.
There does not appear to be an answering machine hooked up. Maybe an email address? _________________ 91 Westy.
Ever consider temporarily trading your van? Join the list. |
jimf909 Samba Member
Posted: Wed Apr 19, 2023 8:45 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
He's a member here. Last visited...today. If I lived 140 miles away from him I'd put my van on the annual installment plan of preventative maintenance and make appointments 1-3 months in advance (or six if needed). It's good to see you post here, it seems like it's been awhile.
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=213605 _________________ - Jim
Abscate wrote: |
HackAl Samba Member
Posted: Wed Apr 19, 2023 9:17 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
Thanks Jim. I read more than I post. _________________ 91 Westy.
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Wed Apr 19, 2023 10:47 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
HackAl wrote: |
There does not appear to be an answering machine hooked up. Maybe an email address? |
I sent him a notice you are looking to contact him. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Wed Apr 19, 2023 11:48 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
Nobody has mentioned calling around to places that do transplants to ask about engines that have been running fine, but were removed to do the transplant. Those can go for as little as the cost of driving there to pick it up.
I read the part where you endeavored to replace your tent. This gives me complete confidence that you have the perseverance aplenty to drop an engine, and put another one in it's place (WBX). Seriously, the tent install is something I found to be very taxing on my skill set, I've often said that if I were asked to do somebody else's tent, I would have to quote them $1,000.00 minimum, and no guarantee on results. Engines are only a few bolts away from being on the floor.
My primary spare engine came from such a transplant, it came with all the bits and bobs still attached, and a fine exhaust too. To drop an engine like that is pretty simple, there are plenty of videos, and forum topics on it. The only trick is to support the transaxle while the engine is lowered, and that is almost not a trick at all, just a piece of 4X4 and a chain.
You can do this! I can tell
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Wed Apr 19, 2023 6:25 pm Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
bobbyblack wrote: |
Nobody has mentioned calling around to places that do transplants to ask about engines that have been running fine, but were removed to do the transplant. Those can go for as little as the cost of driving there to pick it up. |
I think in New England it’s literally FAS in Maine as the only place that does a lot of swaps. Maybe Bostig would have local customers that are a potential source. _________________ John - 86 Wolfsburg Westfalia "Weekender"
HackAl Samba Member
Posted: Wed Apr 19, 2023 6:46 pm Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
John, thanks for reaching out to Andrew. We connected today. His phone service was out.
Bobby, I really appreciate the vote of confidence. That tent nearly wrecked me. _________________ 91 Westy.
Love My Westy Samba Member
Posted: Wed Apr 19, 2023 6:53 pm Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
I am kind of in the same boat as HackAl. I have an 86 Weekender with 170,000 miles with the original 2.1. It is still running strong and I can just keep driving it, but my tranny has started leaking from the seal where the bellhousing attaches to the tranny. I talked to my mechanic about rebuilding the tranny and we called the rebuilder he uses. They wanted to know what engine I wanted to run with their tranny rebuild so they wouldn't have problems with it. I have been thinking about a FAS non turbo 2.0 but I haven't fully decided on that or just going with a GW2.2. I did my own head gaskets at 108K miles and they have not shown any signs of leakage.
So what I have is a tranny that needs work but is forcing me to make engine choices for the future. One thing I did find out is that the warranty on the tranny with a Subie engine is much shorter due to the dramatic increase is HP. |
ThinkingD Samba Member
Joined: January 21, 2020 Posts: 130 Location: Ottawa Ontario Canada
Posted: Fri Apr 21, 2023 9:31 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
May be a bit far but with the exchange rate Quebec might be a consideration. I had a VW 2.0 from a 2015 Jetta (132,000 km) installed turn-key for $7,500 + tax in fall 2022, (I think it is a bit more now). This guy is on his 75th conversion like this, mine was his 71st or 72nd.
https://mecaniquemartin.com/
_________________ 87 Titian Red Westfalia 2.0 VW I4 SOHC manual Ottawa, Ontario |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Sat Apr 22, 2023 8:49 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
Don’t drink the Kool Aid. If your van was running fine and blew a head gasket then put ahead gasket on it and keep going. It would be good to know oil pressure as a baseline.
If you we doing it yourself I’d re use the heads After some clean up and keep going. I think conversions are great as an enthusiast and compotet wrench turner.
I have both a WBX and a Subaru 2.2 in Ca and most days I prefer the WBX. What is the finished cost of a conversion now A days?
My
0.2 _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sat Apr 22, 2023 9:58 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
ThinkingD wrote: |
I had a VW 2.0 from a 2015 Jetta (132,000 km) installed turn-key for $7,500 + tax in fall 2022, (I think it is a bit more now) |
7500 CAD is 5,483.06 USD today
if that was your price, you either stole it or the guy works for free.
That said, Andrew (Flint automotive) and Jon at FAS are both great guys and I have had a number of dealings with them and no issues at all.
in terms of a swap, only you can decide which way to go. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Sat Apr 22, 2023 11:47 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
16CVs wrote: |
Don’t drink the Kool Aid. If your van was running fine and blew a head gasket then put ahead gasket on it and keep going. It would be good to know oil pressure as a baseline. |
Not a matter of drinking the Kool Aid, it's a matter of evaluating your own skills, your needs, and your desires.
The FAS conversion is on the high end dollar wise, but it's a brand new German crate engine, all new peripherals, ECU, wiring - everything. And with the quality of the conversion parts, it rivals the WBX for smoothness, and beats it for power and mileage big time. Any I-4 conversion will beat the WBX for power and mileage.
While I have the tools and the skills to make most any repair if needed, I went FAS way because I wanted all of their kit's qualities, and at my age, I want to hit the road whenever, to wherever, and never worry about ending up broken on the side of the road. The price was well worth it *for me* in my situation.
But as previously said, you have to decide if you're keeping this van long term or not. And what else you need to drop cash on for the rest of the van. There are plenty of other systems that could need a big $$$ infusion to be reliable. You're the only one that can do that math, and decide what's right for you.
Good Hunting! _________________ '86 Westy FAS GenV Turbo (Marvin) |
4Gears4Tires Samba Member
Posted: Mon Apr 24, 2023 7:38 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
ThinkingD wrote: |
https://mecaniquemartin.com/ |
Including the motor? Like you dropped it off, they installed a junkyard motor, you came back, paid $7500, and drove off?
That is a crazy deal. _________________ '87 Syncro
Sodo Samba Member
Joined: July 06, 2007 Posts: 9605 Location: Western WA
Posted: Mon Apr 24, 2023 8:56 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
$7500 would leave a few bucks for a gearbox rebuild. Wouldn't that be nice?
At 169,000 your gearbox might still have some good parts in it.
If it's been maintained.
If some serial-maintainer-owner changed the oil every 15-30k or something, the gears and R&P could last almost forever (with 90HP).
Then all you need is new hubs, synchronizers, bearings etc.
But almost nobody maintains a transaxle (at all), just the nutcases.
Many owners still have the original 35 year-old oil from the factory, grinding everything up to scrap metal.
The Owners manual states that the gearbox oil does not need to be changed, and most owners complied.
And as such, most gearboxes were 'used up' by the previous owners.
And many subsequent owners did the same in the 2nd 100,000 miles, so by now, they're all too far 'gone' for just new bearings, hubs, sychronizers.
Your gearbox is a little 'lucky' in that nobody has yet hung a big engine on it.
Especially during it's geriatric stage.
Anyway, the condition of your gearbox is worthwhile to know.
The 3rd/4th gear hub should be replaced somewhere around 150k miles or it can destroy the whole gearbox.
It's like a 'timing belt', in a way, a widely known maintenance item for about 20 years now.
And there's that danged front ground strap, beckoning amperes to pass internally across your bearings (very high-precision rolling elements).
All that said......I just talked to a guy who has 410,000 on his gearbox, about 250 of that with a Subaru 2.2. But it's noisy right now and he's taking it to Ken Porter in the SF Bay area.
You should never drive a gearbox on an antique vehicle 'until noisy'.
That's ruining stuff (geniune German OEM parts) that are irreplaceable.
Does the shifter move when you accel/decel going down a steep grade?
Put one finger on the gear lever and check this.
Note the distance of movement in BOTH 2nd gear and 3rd gear.
And for this test - your shifter bushings have to be in decent condition, easy-shifting, & well lubed.
Prob should squirt the shifter slider bushings with oil before the test.
A new gearbox should have zero gear lever movement. _________________
....KTMs, GasGas, SPOT mtb
Posted: Mon Apr 24, 2023 9:24 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
Yes dropped off the Van for a month and paid $7500 + tax on pickup and drove it home. New timing belt, water pump, and coil pack on motor. Fly by wire pedal and ODB2 port at dash. _________________ 87 Titian Red Westfalia 2.0 VW I4 SOHC manual Ottawa, Ontario |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Mon Apr 24, 2023 10:06 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
Love My Westy wrote: |
Gear oil dripping from the bell housing doesn’t indicate you need to rebuild the transmission. There is a lip type seal for the input shaft that can wear over time. There is also a needle bearing that supports the input shaft in the crankshaft that might wear. Probably $20 in parts and maybe 4 hours labor to R and R the transaxle. Not saying you don’t need an overhaul, but if a drip is the only issue, it might be something minor. _________________ ☮️ |
HackAl Samba Member
Posted: Tue May 09, 2023 10:35 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
Just a quick update: Andrew has it now. Preliminary reports looks good. Hopefully just a gasket replacement, but we'll also replace water pump, thermostat, hoses, etc. while we at it. Will also change transaxle fluid.
More to come. _________________ 91 Westy.
HackAl Samba Member
Posted: Wed May 31, 2023 6:37 pm Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
Just to close the loop on this thread, I retrieved the van this past weekend from Flint European Automotive. It is running tip-top now.
Andrew replaced the head gaskets and a bunch of other components that were beyond redemption. He installed an oil pressure gauge kit that I purchased from Van-Again.
I was very impressed with Andrew's guidance, execution and follow-through.
Thanks to everyone who provided help and suggestions here. Very much appreciated.
Al _________________ 91 Westy.
jlrftype7 Samba Member
Posted: Thu Jun 01, 2023 8:30 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? |
HackAl wrote: |
Al |
So glad to hear it's worked out for you. Congratulations... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2559 Location: Philly, mang
Posted: Thu Jun 01, 2023 10:05 am Post subject: Re: 91 Westy Camper: Time for rebuild? Swap? [Resolved] |
awesome Al, now it's time to camp! _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
