MTT3107 Samba Member
Posted: Thu Jun 01, 2023 1:39 pm Post subject: Question about running engine on stand. |
I plan to later this year pull the engine from my bug and switch out the camshaft, and maybe even go to 1776 or 1835 cc.
A have the adapter for the starter, so I can run the engine before reinstalling.
But my engine case came from a fuel injected engine, so there is no mechanical fuel pump, I have an electric pump in the car.
When I run the engine outside of the car, can I just gravity feed the gas ?
Carburators are dual 34 EPC's. |
Don Jones Samba Member
Joined: April 09, 2020 Posts: 199 Location: Makaha, Hawaii
Posted: Thu Jun 01, 2023 2:34 pm Post subject: Re: Question about running engine on stand. |
MTT3107 wrote: |
Just buy a cheap electric fuel pump, when done with it, carry as a spare for your car. Heres one for $10 on Amazon.
https://www.amazon.com/Electric-Universal-Pressure...mp;sr=8-21 |
oprn Samba Member
Joined: November 13, 2016 Posts: 12743 Location: Western Canada
Posted: Thu Jun 01, 2023 3:55 pm Post subject: Re: Question about running engine on stand. |
I see no reason that gravity feed won't work for a beak-in run. There is no load on the engine and no high rpm so gravity feed should keep up just fine. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Thu Jun 01, 2023 4:07 pm Post subject: Re: Question about running engine on stand. |
oprn wrote: |
I see no reason that gravity feed won't work for a beak-in run. There is no load on the engine and no high rpm so gravity feed should keep up just fine. |
You do want 3000rpm for cam breakin. _________________ Glenn
Member #1009
#BlueSquare |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1506 Location: Buford GA
Posted: Sun Jun 04, 2023 8:21 am Post subject: Re: Question about running engine on stand. |
It will run just fine with gravity feed. I use a riding mower fuel tank on my test stand. You DO want to use an inline fuel shutoff valve which are also used on mowers and a fuel filter would also be smart. |
oprn Samba Member
Posted: Sun Jun 04, 2023 2:30 pm Post subject: Re: Question about running engine on stand. |
Glenn wrote: |
oprn wrote: |
You do want 3000rpm for cam breakin. |
In this case RPM is nearly irrelevant. Engine load determines fuel volume requirements and there is virtually no load on the engine at break in on an engine stand. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Sun Jun 04, 2023 3:15 pm Post subject: Re: Question about running engine on stand. |
Don Jones wrote: |
MTT3107 wrote: |
Great point! 12v should be there for any run stand for gauges and starter anyhow. I would not mess with gravity feed on break in. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6032 Location: CONGERS, N.Y.
Posted: Sun Jun 04, 2023 3:26 pm Post subject: Re: Question about running engine on stand. |
Here is mine back in 1992 on a milk box and used gravity feed. Modok saw I changed my crank pulley from one I made from a T-1 pulley to one I got from Mike Sharp from Sharpbuilt in Australia on a trade. Same engine in my car today. Never removed. Ok I also painted my fan housing never buy a Chrome fan housing, they rust in days. It a 32 hp fanhousing with Doghouse.
_________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
