jehlan Samba Member
Posted: Thu Jun 08, 2023 7:09 pm Post subject: Compact Spare |
Redoing my Thing and want to free up some trunk space.....
Compact spare tire closer to trunk corner could do it...
Dont want spare on outside (PS I have 4 lug rims (frt disc and rr adaptors)
Internet search unsuccessful Any Ideas? |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Fri Jun 09, 2023 11:26 am Post subject: Re: Compact Spare |
hey Jehlan,
I too looked into this but at the time there were no compact wide 5 rims available that I could find but you
mentioned having 4 lug rims...
I guess you'd have to find a mini spare 4lug that fits that pattern, maybe a trip to a junk yard with a paper template so you could
size match and try one?
You wouldn't think 4 lug rims would be but so different in hub size but they could be.
maybe see if you can find what other car manufacturer rims can fit the 4lug pattern you have?
(Like Ford and Chevy 5 lug 50's to early 70's - close but not exact where Ford and Dodge had some interchangeability (or it was very close)
I don't know if VW had anything in common with another maker but I did a quick search and vw and mini cooper had some 4 lug stuff that was close but with some minor grinding it would work, mini to vw needed grinding, vw to mini the rim was a little loose.
Then I found this...don't' know if it will help..
https://free-info-pages.com/what-wheels-will-fit.htm
Hope this helps
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Fri Jun 09, 2023 8:33 pm Post subject: Re: Compact Spare |
How about using a 135? _________________ If you`re going to do something, do it right. |
oasis Samba Member
Posted: Sat Jun 10, 2023 7:20 pm Post subject: Re: Compact Spare |
Or how about a Mk3 GTI space saver spare (5x100) and an adapter in case you need it? _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
