Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3668 Location: Sarasota, in my adopted state of Florida
Posted: Sat Feb 18, 2023 1:56 pm Post subject: Re: Pertronix (all points replacements) vs Points |
Don Jones wrote: |
Buy a Winterburn CDI and run points. This CDI has a switch allowing you to run your ignition (Kettering) which is stock or CDI and also a Off switch to help keep the theives from driving away. This unit can also be used with Petronix I modules. Electronic modules seem to fail because of heat and vibration.
Running the Winterburn in CDI mode, your points receive very small voltage so the points don't pit and will last alot longer.
Read about it and decide:
http://capacitordischargeignition.com/ |
I agree, best CDI on the market for our application. The man behind it is voice of reason. The most copied says something. |
Wulfthang Samba Member
Posted: Sat Feb 18, 2023 2:58 pm Post subject: Re: Pertronix (all points replacements) vs Points |
I used a Crane Cans HI-6 with the points as the trigger. It's CDI and fires thru a Mallory Super Coil so the spark is impressive. Plus, it's multi spark and has a built in rev limiter. It does all of the heavy work so the points no longer have electrode wear. (Cam wear only)
When I installed it on my car, I added a couple of small cooling fans to keep it cool. I also wired it in with a switch so I can switch it out of the circuit and make the engine run as points only. Switching it out at an idle results in the rpms dropping several hundred rpm. |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1213 Location: Richmond, Va
Posted: Fri Jul 21, 2023 10:13 am Post subject: Re: Pertronix (all points replacements) vs Points |
hey guys,
Just wanted to ask about the pertronix ignitor II system as I'm curious.. and share what I've learned.
Having had this system installed for me on a 66' Mustang, years ago...and having it fail after about 3 years, I did finally discover why.
In the Mustangs case, the original installer used the "pink resistor wire" which did not give the Pertronix ignitor unit it's full 12 volts was more like 3.5 to 4v.
In this specific case, I went back to points for a while and ended up figuring out what happened and put a replacement Ignitor II module on the car along with the 12v relay kit.
their coil and wire set.
So the relay triggers with the pink resistor wire, then it pulls 12v straight from the battery for the module, which is what they report it needs to function correctly.
So far it's been at least 3-4+ years and this seems to have fixed the issue, the 289 runs great on that module (on points not so much).
The reason I bought this up is i've been mulling upgrading my 1600 engine in my 73 Thing for safer drivability, more power, what ever I can get.
After a recent road trip to Kubeltreffen East in Appomattox, Va, it defiantly needs a boost, I'm holding up traffic driving in certain conditions,
climbing hills it go up to 60+ downhill and drop to 40ish uphill. Running 55mph for long distances it seemed to act up i'm assuming from heat (plus it was hot as crap outside anyways).
Going electronic ignition has been on the list as a upgrade (I know there are multiple options out there, and it was suggested to go with the magnaspark if I upgrade the engine)
but I was just curious for all the failures reported on these pertronix modules that yall have also experienced,
>Was it the module or was it the way it was installed that caused the failure? meaning a lack of a full 12v to the module? or heat maybe?
After getting someone to do this install for me the first time and honestly the instructions were so straight forward they were confusing to me at the time,
Then, myself having to figure out what broke and fix it a 2nd time, and getting some help from a place I just asked for help out of desperation [Retro Rockets],
they helped me figure out the cause of the issue and gave me a bunch of troubleshooting notes on it and I didn't even buy from them. Great guys!
Well It made me wonder if that's the problem with these units, the instructions were at the time so easy they were difficult to comprehend.
They tell you that you can install it and be worry free (which it was until the engine was harder and harder to start).
The Mechanic I had install it for me the first time was a active drag racer and worked on police cars for a living he was a good tech, but this was his first pertronix install also.
I suppose in my case for the VW, if I did the pertronix upgrade I was going to use the 12v relay kit to keep my svda distributor and pict 34 carb for now, I've been mulling engine
upgrades and am a bit set back at some of the prices i'm seeing.
I got to drive a 2110cc THING at the show, love the power but am abit set back at some of the projected costs and modifications i'm learning it'd cost to do that.
But, I will add my 73 seems to run fine with points and i'm more knowledgeable now then I was back in 94' mucking with the Mustang, just wondered if it's truly worth upgrading
to electronic vs staying on points, cause if that's the case, if I were to upgrade the engine to a 1776 or 1910 or 2110 (or whatever) would you then keep points or go electronic?
Just to note, in the case of the Mustang there was a noticeable change in engine performance with electronic vs points, on the VW i'd assume the same?
I'm still in sticker shock reading up on engine upgrade and mod costs and it's making me want to do all I can to the 1600 to get what I can out of it.
so was just curious if for all the failures with the pertronix modules was it truly due to lack of 12v source voltage or something else if anyone knows?
Just curious.
Thanks yall,
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16549 Location: North Florida, USA
Posted: Fri Jul 21, 2023 2:12 pm Post subject: Re: Pertronix (all points replacements) vs Points |
doublecanister wrote: |
Just wanted to ask about the pertronix ignitor II system...
Going electronic ignition has been on the list as a upgrade ... but I was just curious for all the failures reported on these pertronix modules that yall have also experienced |
Pertronix makes 3 different Ignitor modules for VWs. The Ignitor (I) is probably the most commonly used and the one many complain of when it comes to failures.
I'm pretty certain some of the negative opinions are user/installation related as the Ignitor I did not have any reverse voltage protection. This means hook them up backwards (even once), turn ON the ignition switch and... you just set fire to $70 cause you will need a new ignition module.
The Ignitor II & III have reverse polarity circuit protection so this should not be possible... increasing the positive opinion of these even though they are much more expensive. They also have "smarter" internal logic and do much more than electronically trigger the ignition coil with a high dwell system.
In the Mustangs case, the original installer used the "pink resistor wire" which did not give the Pertronix ignitor unit it's full 12 volts was more like 3.5 to 4v. |
Many '50s and '60s cars used a resistor wire or a ballast resistor on the power wire to the ignition coil. This reduced the current that passed thru the points so they would last longer. VW did this in the early models (pre-'68 ) but for any '68-later VW Beetle this should not be a problem. The ballast resistor to reduce the current to the points is INTERNAL to the ignition coil. The ignition coil is powered from the 12v ignition switched circuit and tapping power for the ignition module from the #15 terminal of the coil should be fine.
Could there be higher than normal resistance because you are running 40yr old wires? Most definitely. But you should do some clean up of wire terminals and connections to reduce that resistance and increase the current/voltage that makes it to the end of the ignition circuit. This will go a long way to getting the most current to the ignition coil.
The idea of installing a relay to power the ignition coil has some problems... see below.
So the relay triggers with the pink resistor wire, then it pulls 12v straight from the battery for the module, which is what they report it needs to function correctly. |
The idea of maximizing the current and voltage that makes it to the ignition coil translates to more power out of the ignition coil secondary. But you need to be careful. See below.
Just to note, in the case of the Mustang there was a noticeable change in engine performance with electronic vs points, on the VW i'd assume the same? |
Adding an electronic ignition module (electronic points) is not a bad upgrade. It makes for a more reliable ignition with more power out of the ignition coil secondary circuit. Will it be a noticeable difference? Some say yes, some don't notice any difference.
The reason your Mustang saw a power increase was because the voltage driving the ignition coil primary circuit was increased when you removed the resistance coming from the pink wire which reduced the power thru the primary winding. Powering the coil directly from the battery meant more primary and secondary coil voltage.
To see such increased performance on your Beetle you will need to replace the ignition coil with a compatible one that matches the Ignitor II or III specs. Unlike the stock ignition coil which comes with 3.0ohms of internal resistance in the ignition coil, I read somewhere that the Ignitor II can work with an ignition coil rated to as low as 0.6ohms in the primary windings of the coil. This lower resistance is the equivalent of removing the "pink wire" in your Mustang. When paired with an ignition coil of the lowest rated resistance, an electronic ignition can produce the max secondary winding power output. Luckily, Pertronix makes compatible ignition coils and they are not terribly expensive.
I suppose in my case for the VW, if I did the pertronix upgrade I was going to use the 12v relay kit |
Why you don't want to install a relay on the ignition coil power circuit...
While the engine is running and the charging system is working....
The GEN lamp is OFF because there is 12v+ coming from the ignition switch/fuel vibrator as well as 12v+ coming from the VR #61 terminal (or the D+ terminal of the alternator). This 12v+ coming from both directions means no current flows thru the GEN lamp. No current flow thru the bulb filament make the GEN lamp appear to be OFF.
At the moment you turn the ignition key from ON/RUN to OFF to shutdown the engine...
Power coming from the ignition switch #15 terminal to the ignition switched circuit is cut. You would obviously expect that this would power down the entire circuit, right? Not really. The momentum of the engine will keep it rotating for a few seconds. As it rotates the charging system is still outputting power. While it is working there is 12v+ being pushed from the charging system over the #61 blue wire to the GEN lamp.
In these few seconds, with no current coming from the ignition switch the 12v+ from the VR/alternator now flows thru the GEN lamp and into the #15 ignition switch circuit looking for a path to ground. Even in normal operation you may see this as the GEN lamp turn ON for a split second before the engine stops rotating.
The 2W of power coming flowing thru the GEN lamp will look for the lowest resistance path to ground. One path will be thru the 85/86 circuit of the relay powering the ignition coil. The voltage at the relay trigger circuit will drop as the 2W bulb cannot power everything. It will probably drop to around 6v~7v. This 6v is too low to normally power the ignition coil. Normally, with such low voltage the ignition coil would stop firing sparks which would stop the engine.
But you have installed a Bosch style SPDT relay to power the ignition coil. It is actually the relay+battery powering the ignition coil and not the ignition switch. These small relays will remain energized with as little as 5v on the 86/86 circuit so the relay remains ON. This means the ignition coil will receive the full 12v+ coming straight from the battery! Turning off the ignition switch has reduced the voltage to the relay but NOT cut power to the ignition coil. As far as the ignition coil is concerned the ignition switch is still ON providing 12v+ and it will continue to fire all the cylinders. If the engine continues to rotate the charging system continues to send current thru the GEN lamp keeping the ignition coil relay powered.
FIX if you really want to install a relay: To fix this problem you need to prevent current flowing backwards thru the GEN lamp. The easy fix for this is to add a 1A diode into the #61 blue wire connected to the GEN lamp. This should be biased so it only allows positive current flow from the ignition switch thru the GEN lamp, towards the VR/alternator. You know it is oriented correctly when the GEN lamp turns ON before you start the engine. If it does not, you have the diode installed backwards. The diode will prevent current flow from the VR/alternator backwards thru the GEN lamp into the ignition switch circuit. Now when you turn the ignition switch OFF there will no longer be power coming from the VR/alternator feeding back into the ignition circuit to keep the relay energized.
I did this on my old '75 Beetle. It provided a strong 12v+ power source inside the engine compartment. I used the alternator B+ as the power source. It is directly connected to the battery positive terminal. _________________ AshMan40
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4020 Location: San Diego
Posted: Fri Jul 21, 2023 2:39 pm Post subject: Re: Pertronix (all points replacements) vs Points |
Im in the process of adding a relay to get full voltage to the CDI box, so this is good info
Is that a 1N4004 Diode?
Thx! |
Posted: Fri Jul 21, 2023 6:31 pm Post subject: Re: Pertronix (all points replacements) vs Points |
chrisflstf wrote: |
Is that a 1N4004 Diode? |
I believe any of the 1N4xxx diodes will work. The 2W GEN lamp will limit the current flow thru the diode so even a smaller diode should be fine.
The stock GEN lamp arrangement would light the GEN lamp when the charging system is weak (eg. lost fan belt) and when it overcharges (eg. failed VR). The one downside of installing a diode in the #61 circuit is the GEN lamp will no longer turn ON if the charging system overcharges. It will still light up the GEN lamp before starting the engine and will get the alternator to begin charging. _________________ AshMan40
Posted: Mon Jul 24, 2023 7:08 am Post subject: Re: Pertronix (all points replacements) vs Points |
Hey Ashman, thanks for the reply about using the diode if I were to go pertronix II with a relay kit.
Would the 'need' for this diode be due to running a generator vs a alternator?
Just curious. I know on Fords the alt's have a diode in them, i'd assume vw alt's do as well. (going to an alternator was also on the upgrade list)
Good info as trying to come up with a upgrade plan it seems everything
has another device or system to get affected from one change or another.
I'm still on the fence on doing a complete engine swap to something larger or rebuilding mine, so more things to chew on.
Thanks again!
1973 - Thing
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 832 Location: France
Posted: Mon Jul 24, 2023 7:17 am Post subject: Re: Pertronix (all points replacements) vs Points |
I prefer fitting a Mk1 Vw Golf Bosch electronic points distributor. 40 years without failing opposed to 2 to 3 years Petronix. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79420 Location: Sneaking up behind you
Posted: Mon Jul 24, 2023 8:00 am Post subject: Re: Pertronix (all points replacements) vs Points |
Nitramrebrab72 wrote: |
It doesn't fit an aircooled engine.  _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Mon Jul 24, 2023 1:02 pm Post subject: Re: Pertronix (all points replacements) vs Points |
Would the 'need' for this diode be due to running a generator vs a alternator? |
The generator turns OFF the GEN lamp in the same way the alternator does... by pushing 12v+ back along the GEN lamp circuit. The GEN lamp "sees" 12v+ from both directions so no current flows, and the GEN lamp turns OFF.
With a generator, try the relay with just the stock GEN lamp wiring in place (no diode). Add your relay to the engine compartment and see if the engine shuts OFF when you turn the ignition key OFF. If it works normally, you can do without the diode.
If it continues to run even with the ignition switch OFF... pull the GEN lamp out of the speedometer and see if this shuts off the engine. If it does, you need to add the diode. Until you can get your hands on a diode, remove the GEN lamp from the speedometer bulb holder. You won't have the GEN lamp but the generator will still charge (alternators won't) and the engine will not run-on. You can continue to drive this way until you can get a diode for the #61 circuit.
Just curious. I know on Fords the alt's have a diode in them, i'd assume vw alt's do as well. (going to an alternator was also on the upgrade list) |
All alternators have rectifier diodes (diode trio) to convert AC to DC. These are not the diodes I am talking about.
Installing a stand alone diode into the GEN lamp circuit is there to only allow current flow in one direction (from fuse box to VR/alternator) and to prevent current flow from the charging system backwards into the ignition circuit. This is to prevent the backflow of current into the ignition circuit from accidentally powering a relay connected to the ignition circuit.
The one place in the ignition circuit where you can add a relay and not worry about it being energized by the GEN lamp... between the ignition switch and the fuse box. Here the relay can ONLY be powered by the ignition switch and not something else dumping current into the #15 circuit. _________________ AshMan40
Posted: Mon Jul 24, 2023 1:47 pm Post subject: Re: Pertronix (all points replacements) vs Points |
Glenn wrote: |
It doesn't fit an aircooled engine.  |
You have to put her on a lathe , the golf dist. is a larger neck with plenty of material to do an aircooled distributor cut then swap the cog with the 2 prong from your point dist. The advance is very similar.  |
Posted: Mon Jul 24, 2023 1:52 pm Post subject: Re: Pertronix (all points replacements) vs Points |
The 8 valve mk2 golf distributor has a duel vacuum canister for those who want more precise advance control at tick over. |
59 dormi Samba Member
Joined: September 06, 2006 Posts: 621 Location: Ontario Canada
Posted: Mon Jul 29, 2024 2:19 pm Post subject: Pertronix installed won’t run???1300 -1600 sp |
Installed pertronix today I marked the distributor where I had the timing set with points prior to the pertronix install and I can’t get it to fire it just back fires
I have the blue coil with the red on positive and the black on negative I’m running a electric fuel pump off the coil as well
I’m running the stock vacuum advance 1300-1500 distributor the pertronix unit I bought is for this distributor
Where did I make a mistake or does this dizzy only work on points?
Prior to this on points it started first time every time it was just getting hard to find points cap and rotor so I thought I’d give this a shot _________________ 1959 Dormobile
Mini R53 bob the tomato
Range Rover L322 |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7461 Location: Houston, Texas
Posted: Mon Jul 29, 2024 2:22 pm Post subject: Re: Pertronix installed won’t run???1300 -1600 sp |
66 dormi wrote: |
Prior to this on points it started first time every time it was just getting hard to find points cap and rotor so I thought I’d give this a shot |
You should be able to change to points and back again without any issues. You will need to reset your timing using a timing gun. Most likely it slipped a little when you changed out to electronic.
I have points, cap, and rotor - all you need. _________________ www.vwnos.com [email protected]
Posted: Tue Jul 30, 2024 11:49 am Post subject: Re: Pertronix installed won’t run???1300 -1600 sp |
66 dormi wrote: |
Installed pertronix today I marked the distributor where I had the timing set with points prior to the pertronix install and I can’t get it to fire it just back fires |
Before you removed the points, did you manually rotate the crank until the rotor was pointing to the #1 post on the distributor cap and line up the crank pulley timing mark with the case split? By doing this you know the engine is oriented EXACTLY where a spark should be delivered from the distributor to the #1 spark plug.
When installing the electronic ignition module you leave the crank where it is and adjust the distributor body until the electronic points are just "opening" to trigger the ignition coil. This is normally checked using a 12v test lamp connected between the ignition coil #1 (-) terminal and ground. When the points open the test lamp will turn ON. This test may not work using electronic points like the Pertronx. Alternatively, here is a diagram showing how you can connected a voltmeter between the Pertronix module black wire and a 12v+ source to see when the electronic ignition OPENS the points (voltage drops to zero).
Connected as shown, rotate the distributor body CW until the meter reads 12v+ (points closed). Then rotate the distributor body CCW until the voltage drops to zero (points open). This is the point where the electronic ignition will spark the coil to send a spark to the #1 spark plug.
Once you have the distributor oriented to fire a spark when the crank pulley timing mark (TDC or 7.5BTDC) is lined up with the case split... button everything back up and confirm the #1 plug wire is installed over the rotor tip and the remaining plug wires are installed in the CW firing order of 1-4-3-2. Crank up the engine and warm it up. Once warmed up, set the final ignition timing according to your distributor model using a strobe timing light.
If you are no longer certain which position on the distributor is where #1 plug wire should be installed... rotate the crank until the TDC or timing mark (either will work) is lined up with the case split. Remove the #1 & #2 valve cover and confirm the two rocker arms for #1 cylinder have some play (indicating both valves are closed). If you have no play in either/both valves... rotate the crank 360deg and check again. When the crank pulley is near TDC and the #1 valves are closed... the engine is at the end of the #1 compression stroke and the distributor should deliver a spark to the #1 spark plug. The rotor MUST be pointing to the #1 plug wire on the distributor cap. Install the #1 plug wire over the rotor tip so this will happen. Install the remaining wires in the proper CW firing order. You are done.
66 dormi wrote: |
I have the blue coil with the red on positive and the black on negative I’m running a electric fuel pump off the coil as well |
Running the fuel pump off the ignition coil is a bad idea.
Depending how old your wiring is it likely has some resistance in the wiring due to old/dirty wire/connections. This wire resistance reduces the current that makes it to the end of the black wire from the ignition switch/fuse box. The end of this wire is the #15 terminal on the ignition coil. From here, different devices draw current from the wire...
ignition coil
reverse lights
idle cutoff solenoid
choke
Adding another devices takes away current from the other devices. If, for example, the fuel pump draws 2A to run, then that is 2A less available to the ignition coil to make a hot spark. If the wire and all connections were new and clean then there could be more
than enough current reaching the end of the wire for all the devices. But after decades there is less current available and you are likely stealing power away from the coil.
Run a dedicated power wire for your fuel pump.
Also, most electric fuel pumps are "pusher" pumps and should be placed near the fuel tank so they can PUSH the fuel thru the fuel line to reach the carb. They usually depend on gravity to feed fuel into the pump and don't do well "sucking" the fuel from a long distance away. This is why you typically see electric fuel pumps installed below (or inside) the fuel tank. _________________ AshMan40
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23095 Location: Oklahoma City
Posted: Tue Jul 30, 2024 12:03 pm Post subject: Re: Pertronix (all points replacements) vs Points |
I don't know about your engine, but I have found thatPertronix rarely matches up to eactly teh same initial timig point as you had with points.
What do I mean by that?
So if on your old points distributor.....lets say you set the points rubbing block on exactly TDC of the cam....and the centerline of the rotor pointsdirectly to the mark for #1 on the dristributor body. Yes....I know its not set up just like that. This is for understanding of the concept.
So lets say you set it up like that. You pull dirstributor out, remove the points and install the igniter 1 module and magnet ring and rotor.
You put the distributor back in with the centerline dead on the punch mark for #1 on the distributor body like it was.
Your timing will be off.
The peak of the magnetic force that causes the switching is NOT in the same place as where the points were.
I have found them to be an average of 5-7 degrees and as much as 10 degrees off from where the point rubbing block to cam centerline was.
I usually err towards advance. Advance about 5* and try to start it. Connect your timing light up before you start so that once you get it running you can time it. Ray |
Glenn  Mr. 010
Posted: Wed Feb 19, 2025 8:38 am Post subject: Re: Pertronix (all points replacements) vs Points |
I recently rebuilt a stock 1600DP that the customer supplied 95% of the parts. We installed the engine a few days ago and just couldn't get it to run right. Cheap aftermarket 34PICT-3 carb and Pertronix distributor.
After taking the carb apart, fixing the casting flash and setting the float height the engine ran better but still had a miss. Finally replace the Pertronix III distributor with a good used stock 034 and points...it now runs great.
Another Pertronix for the scrap pile.
Member #1009
#BlueSquare
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3301 Location: Hamble, Hampshire, UK
Posted: Wed Feb 19, 2025 9:55 am Post subject: Re: Pertronix (all points replacements) vs Points |
The Ignitor 1 is simple. It either works for years or dies the instant you swap the wires.
I have seen one where the magnet ring was faulty and the engine backfired badly then ran OK then backfired again . New magnet ring and it was perfect.
The Ignitor 2 is more complex. It also dies when you swap the wires. Most Chinese ignitors are similar. Once you get them hot, they can start randomly behaving exactly like a condenser failure or points closing up. Always carry a spare distributor pre- timed if you use an electronic module.
The ignitor III is likely to perform worse than points at low RPM because it only has two timing points per rotation of the engine. At high RPM it all averages out ..
At least all three allow you to use vacuum advance distributor bodies if you have a bus and not a Beetle or an industrial engine with an 009.. _________________ Ancient vehicles and vessels
tzepesh Samba Member
Posted: Tue May 06, 2025 10:30 pm Post subject: Re: Pertronix (all points replacements) vs Points |
Can you please help me identify the model of this Pertronix, is it I or II? I need to know what coil primary resistance we shall use, I have both >3 Ohm coils and <1Ohm coils, and would really like not to fry the module.
The only sticker on it says D57 2
I asked Pertronix but did not receive any answer.
_________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Sea Blue, under restoration |
Glenn  Mr. 010
Posted: Wed May 07, 2025 4:25 am Post subject: Re: Pertronix (all points replacements) vs Points |
It's a Pertronix I, the Pertronix II is red. _________________ Glenn
Member #1009
#BlueSquare
