vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5869 Location: Wamego, Kansas, USA
Posted: Tue Oct 17, 2023 9:01 pm Post subject: Fuel Gauge Reading in Reverse? |
I started a thread on this 25 months ago but it quickly devolved into a live update/trip report thread which ended with the engine in my Bus dying and me never figuring out the issue. (And eventually forgetting the issue until today!)
Anyway, I actually got the Bus running again today, well over 2 years later! When I got it going, I noticed that the fuel gauge was reading quite low-a little under R. So I got to the fuel station and topped the tank off. I was surprised that it was reading even lower! Then remembered that I was having the issue before and dug up the old thread.
In short, for no reason that I could figure out and without (that I recall) doing any sort of wiring stuff, my fuel gauge suddenly started reading backwards.
When the tank is full, it reads all the way to the left. As I drove on that ill-fated trip, the needle would rise as fuel was consumed. And go right back to reading all the way to the left when the tank was nearing empty!
So, now that the engine is running again, it might be nice to know where I'm at with the fuel levels.
I'd love to hear any ideas on what might be going on or what I could check. _________________ Dave Cook
1973 Wild Westerner
My Thing |
timvw7476 Samba Member
Posted: Tue Oct 17, 2023 10:21 pm Post subject: Re: Fuel Gauge Reading in Reverse? |
If you've got the gauge/vibrator/wiring untouched since you can remember it is probably some nonsense going on with the float & sender in tank. Hope you already have the handy access hole already cut......most buses do.
Yes you can pull the tank without pulling engine, but most induction stuff must be removed to get the slide-out space, & the two final screws for the cover plate are usually well-hidden & upside down to boot. : l |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53181 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Oct 18, 2023 8:34 am Post subject: Re: Fuel Gauge Reading in Reverse? |
I'd rig up another sender outside the tank and see what the guage says about it, or you could simulate a sender with a cheap potentiometer from Amazon, 0 ohms empty, ~70 ohms full. The sender wire is just inboard of the RR shock absorber coming out the bottom of the tank compartment. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Oct 18, 2023 9:23 am Post subject: Re: Fuel Gauge Reading in Reverse? |
The problem is definitely the sender.
Had to drain the tank anyway (fuel leak under the Bus was making everything smell of diesel!) so I decided I might as well pop the cover and investigate further.
The sender is reading in reverse! Float is attached and floating. The resistance changes throughout the motion. It is just somehow backwards. First test was to connect the signal wire directly to ground from back. Gauge went to Full.
Next, I ran a jumper wire from the signal wire at the back all the way up front, and hooked up a ground wire up front, and attached the sender up front so I could easily observe the gauge. It consistently read in reverse of what it should! Float up: Reading drops. Float down, reading raises to Full.
Finally, multimeter proof (had to get creative trying to hold everything together):
For reference, this is how it should read. Almost exactly the opposite of what I'm suddenly getting.
I guess I simply just need to get a new sending unit. But am absolutely befuddled as to what could have caused this to happen (and would love to hear any theories!)
I installed this sender a few years ago, and it worked great for a long time. Then somehow switched it's readings.
And this shouldn't be surprising, but since the gauge is simply reading resistance between two points, reversing how the wires were hooked up didn't change anything. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Wed Oct 18, 2023 9:39 am Post subject: Re: Fuel Gauge Reading in Reverse? |
Don't know if it helps much in figuring out what could be making the sender seemingly reverse itself, but here's a pic of its insides.
I'll probably just have to put things together for now to prep for this camping trip and deal with it later. But if you spot anything or have any ideas on WTF is happening, I'm all ears!
1973 Wild Westerner
My Thing |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3425 Location: Hamble, Hampshire, UK
Posted: Wed Oct 18, 2023 10:07 am Post subject: Re: Fuel Gauge Reading in Reverse? |
I think the sender is a unique badly made example with the arm assembled 180 degrees out. You could fix it by reversing the 90 degree bend just under the pivot.. _________________ Ancient vehicles and vessels
Posted: Wed Oct 18, 2023 10:09 am Post subject: Re: Fuel Gauge Reading in Reverse? |
I was just going to suggest the same thing, bend the arm over to the other side. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24371 Location: NYC/Upstate/ROW
Posted: Wed Oct 18, 2023 10:39 am Post subject: Re: Fuel Gauge Reading in Reverse? |
Has the Bus been to Australia lately ? _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42928 Location: at the beach in Northern Wokistan
Posted: Wed Oct 18, 2023 3:40 pm Post subject: Re: Fuel Gauge Reading in Reverse? |
I wonder if somehow the tank has voltage on it. Meaning that it is not at a true chassis ground. The wire to the gauge is assuming that the float knows the difference between ground and resistance. But if voltage gets into that circuit then the tank is no longer at ground. The same would be true if somehow voltage was leaking into the wire going to the gauge.
I think that the 73 and 78 systems are different and I don't know which bus you are working on.
This is my 1977 but I have the electronic regulator and not the bimetal kind like you have.
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Wed Oct 18, 2023 9:33 pm Post subject: Re: Fuel Gauge Reading in Reverse? |
I figured it out!
I don't know how it happened, but apparently the float arm somehow rotated 180 degrees on the pivot that the wiper arm is attached to.
It was mikedjames and busdaddy's comments about the arm being bent incorrectly that caused me to investigate this further. As stated before, this sender did work correctly for several years; it wasn't as if I had just purchased the sender and the gauge wasn't working after.
So I knew it wasn't exactly the arm being bent wrong, but started looking for other options. I took the cover plate off and it still initially looked ok, but I finally noticed that the arm seemed loose in the pivot, and I was able to fairly easily swivel it 180 degrees.
And with that information, I decided to use a little solder to "glue" the pivot to the arm in the correct orientation.
And now the gauge seems to read correctly!
Here's a pic of the pivot soldered to the arm.
1973 Wild Westerner
My Thing |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7846 Location: Santa Cruz
Posted: Wed Oct 18, 2023 10:01 pm Post subject: Re: Fuel Gauge Reading in Reverse? |
Damn! Nice work!!
Way to sleuth it out my man..
 _________________ Bus Motor Build
It does not exist! |
Posted: Thu Oct 19, 2023 5:06 am Post subject: Re: Fuel Gauge Reading in Reverse? |
| Clatter wrote: |
Damn! Nice work!!
Thanks! I didn't think to get a pic, but the pivot was held on to the arm by peening it in a couple spots. I guess it got loose over time and I happened to hit a bump or make a turn or something to get the fuel to slosh just right to make the arm swing the other direction when the level was such that the sides of the tank wouldn't prevent it from swinging!
Crazy _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Thu Oct 19, 2023 1:43 pm Post subject: Re: Fuel Gauge Reading in Reverse? |
well this takes all the fun out of my 'glitch in the Matrix' guess. : (
Damn problem solvers finding the true issue. Nice workx2 |
