Low down Hillbilly
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8
OCD Garage
OCD Garage is offline
PostPosted: Sun Mar 03, 2024 7:53 pm    Post subject: Re: Low down Hillbilly Reply with quote
Managed to get the lower hoop done for the rear section of the cage this weekend before running out of material.
OCD Garage
PostPosted: Mon Mar 04, 2024 5:22 pm    Post subject: Re: Low down Hillbilly Reply with quote
Added four 3.5" extension tubes to act as bridges to the final hoop, the cross tube was in place to hold the pieces in alignment for welding. Only the last hoop, a lower left connector bar, a few braces and this part of the build will be mostly complete.
OCD Garage
PostPosted: Fri Mar 08, 2024 10:06 pm    Post subject: Re: Low down Hillbilly Reply with quote
Braces added to side bars on both sides.
OCD Garage
PostPosted: Sat Mar 09, 2024 6:45 pm    Post subject: Re: Low down Hillbilly Reply with quote
Nearly finished the fab work for the cage. Left to do: an X brace for the main hoop, tie-ins for the rear floor and possibly a pair of 45* braces under the corners of the windshield. I'll need to remove the cage to complete the final welding and clean-up.
OCD Garage
PostPosted: Thu Mar 14, 2024 6:53 pm    Post subject: Re: Low down Hillbilly Reply with quote
I decided to fill in the open area above the last installed braces by adding a 90* bend each side to balance the overal visual.
OCD Garage
PostPosted: Fri Mar 15, 2024 5:49 pm    Post subject: Re: Low down Hillbilly Reply with quote
Nearly there. Budget old school hot rodding all the way! X brace added to main hoop and 45* braces to both corners under winshield.
OCD Garage
PostPosted: Sat Mar 23, 2024 4:27 pm    Post subject: Re: Low down Hillbilly Reply with quote
Just added the last four supports to the rear of the cage, which is now complete. There are still a few welds to do that I can get without removing the cage, but it will eventually need to come out to be finished. The rear supports bolt through the body to an angle iron frame and will be tied into the rear bumper mounts.
OCD Garage
PostPosted: Sun Mar 24, 2024 11:41 am    Post subject: Re: Low down Hillbilly Reply with quote
Everything fits as it should. I have materials to do a second fire extinguisher mount for the driver's side. Once I grab an air manifold and a few fittings, I'll connect the air ride switches and use the shop compressor to run the system for now.
NJ John
NJ John is offline
PostPosted: Sun Mar 24, 2024 1:54 pm    Post subject: Re: Low down Hillbilly Reply with quote
The Rigid Midget! Is that politically correct?
1973 standard, yellow, lowered, 3Ē narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Letís go Oís! Letís go Oís!
OCD Garage
PostPosted: Sun Mar 24, 2024 6:26 pm    Post subject: Re: Low down Hillbilly Reply with quote
Lol. There are a couple of race tracks about an hour in either direction from me, I'd be interested to see how it does, should corner well.
NJ John
NJ John is offline
PostPosted: Sun Mar 24, 2024 8:35 pm    Post subject: Re: Low down Hillbilly Reply with quote
Maybe they have timed attack days. Thatís for street cars.
OCD Garage
PostPosted: Mon Mar 25, 2024 8:06 am    Post subject: Re: Low down Hillbilly Reply with quote
They have open lapping at the Vancouver Island Motorsport Circuit for beginners, experienced and racer classes with instruction, tech inspections, etc. Once the car's roadworthy, maybe I'll treat myself on my birthday. lol.
https://islandmotorsportcircuit.com/driving-experiences/open-lapping/
OCD Garage
PostPosted: Sun Mar 31, 2024 12:13 pm    Post subject: Re: Low down Hillbilly Reply with quote
Today's addition of two lower tubes for the cage up front. Parts are on order to build a distribution system for the air ride switches in the console so I can finally ditch the four schrader valves.
OCD Garage
PostPosted: Mon Apr 01, 2024 9:33 pm    Post subject: Re: Low down Hillbilly Reply with quote
Last week. I built a support under the overhang of my garage roof and today brought home a chain hoist to help with the 'heavier' jobs. First up was lifting the roll cage out of the buggy so that I could remove the body and bolt the cage back down to finish the welding without it twisting or distorting.
Page 8 of 8
