hawkhunter Samba Member
Posted: Sat Jul 30, 2005 3:24 pm Post subject: Tilt Steering, anyone? |
Has anyone ever added tilt steering to their beetle? I have a VW based Sterling and tilt is almost a necessity. Is there an adapter kit available or do you need to replace the entire column? Any help would be most appreciated. |
bajaherbie Samba Sooner
Joined: November 27, 2003 Posts: 2985 Location: altus, oklahoma
Posted: Sat Jul 30, 2005 4:50 pm Post subject: |
i've never seen a tilt adapter thingy, sounds like its time to swap the entire steering column...........
take some basic measurements with you when you go to the junkyard. might me a bitch to hook up the signals, wipers, and cruise control, though. _________________ blank |
Kubel Nick Samba Member
Joined: August 12, 2003 Posts: 1369 Location: Fort Worth, TX
Posted: Sat Jul 30, 2005 5:40 pm Post subject: |
I have an old GM tilt steering column in my Sebring, pretty much the same kit as yours. I don't have any picts of the linkage handy, but it shouldn't be hard, just attached the donor tilt column and mate it to the steering box. Search eBay for "tilt column", "tilt steering" or the like. Early (70-80s) GM coumns are popular for street rods and kit cars. |
Tim10 Samba Member
Joined: April 06, 2004 Posts: 1433 Location: Minneapolis
Posted: Mon Aug 01, 2005 7:02 am Post subject: |
One of the mags ran a series in the 80s on retrofitting GM parts to your bug.
The common easier method is to get a removeable steering wheel adaptor for about $20... it also serves as a theft system.... just don't knock your nuggets with the splined shaft.
T. _________________ Dub Infested- PART WI$H LI$T-CLICK |
jspbtown Samba Member
Posted: Mon Aug 01, 2005 8:07 am Post subject: |
I used a tilt unit from a Chevy Chevette in my Sterling. Used a Borgeson vibration dampening joint to mate the two (http://www.borgeson.com/VibrationDamp.htm). Worked like a dream, and eliminated the need to rotate the box (bump steer). It is a little tough to find the steering columns from those Chevettes, so maybe one from www.ididit.com or www.flamingriver.com would be an easier albeit more expensive, option. |
Posted: Sun Aug 07, 2005 12:50 pm Post subject: |
I think you're right. Ugh! |
Posted: Sun Aug 07, 2005 12:58 pm Post subject: Best Bet is Chevette |
jspbtown wrote: |
I think you're exactly right. The best bet is the GM (chevette) tilt column. I didn't realize my 500K replica also uses GM tilt column, Really thought someone would manufacture a bolt on tilt adapter, guess not. Thanks for your help. |
Posted: Sun Aug 07, 2005 1:02 pm Post subject: |
Tim10 wrote: |
T. |
Those are nice, but I can get in and out okay, it driving the car that creates the problem. The steering wheel touches my thighs (and not in a good way!) when driving. Need to tilt the wheel up, or let my legs atrophy for clearance! |
Tim10 Samba Member
Posted: Sun Aug 07, 2005 8:03 pm Post subject: |
Smaller diameter wheel?
Our MiniT has a 10" wheel...
Dumb question... wouldn't tilt only make your "hitting the legs" issue worse?
t. _________________ Dub Infested- PART WI$H LI$T-CLICK |
Posted: Sun Aug 07, 2005 8:16 pm Post subject: |
Well... umm... they usually tilt up to add knee room |
Nova Samba Member
Posted: Sat Sep 10, 2005 5:55 am Post subject: Sterling, Sebring, Bremmen Cimbria etc |
Hi Guys
If anyone has a Sterling, Sebring, Bremmen Cimbria etc and would like more information or ideas come on down to
www.nova-international.net
Register on the Forum and discuss your car with other guys from the USA, UK and Australia.
Also if anyone has any pictures of these cars, wether your own or someone elses then send them on to me at
steve at nova-international.net
( change 'at' for @ )
for inclusion in the galleries.
Thanks |
Posted: Sat Sep 10, 2005 6:25 am Post subject: |
I've been to your site plenty of times, good stuff. I just tried the forum but says unavailable. I just started on my sebring currently being customized, here's my project webpage:
http://www.runtrod.com/project-sebring.html |
dezertduner Samba Member
Posted: Sun Sep 11, 2005 3:36 am Post subject: |
take a look at this it will give you an idea may not be pretty but its a good strong design as they use it in alot of off road race cars.
http://kregerfab.com/othrprod.htm |
