paulsvwbug Samba Member
Posted: Wed Apr 03, 2024 5:35 pm Post subject: 113 905 205M tear down-how to |
So I need to replace the small ground beneath the points plate, it came apart.Does anyone know how to do this? I can’t find any info on it.
Does the pin need to come out at the base? |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80357 Location: Sneaking up behind you
Posted: Wed Apr 03, 2024 5:50 pm Post subject: Re: 113 905 205M tear down-how to |
Yes, you need to remove the pin. Not the offset of the drive so you reinstall it correctly. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Apr 04, 2024 3:45 am Post subject: Re: 113 905 205M tear down-how to |
| Glenn wrote: |
| Yes, you need to remove the pin. Not the offset of the drive so you reinstall it correctly. |
Take a picture so you can get the offset correct when going back together, otherwise you have a 50/50 chance of being wrong. |
Posted: Thu Apr 04, 2024 10:42 am Post subject: Re: 113 905 205M tear down-how to |
| Thanks for the replies. Should there be much movement when moving the points plate up and down? |
Glenn  Mr. 010
Posted: Thu Apr 04, 2024 10:57 am Post subject: Re: 113 905 205M tear down-how to |
| paulsvwbug wrote: |
No, the fiber washer might of crumbled and is missing. _________________ Glenn
Member #1009
#BlueSquare
Angus II Samba Member
Joined: June 01, 2016 Posts: 724 Location: Mammoth Lakes Ca. 93546
Posted: Thu Apr 04, 2024 11:25 am Post subject: Re: 113 905 205M tear down-how to |
Hello,
There are post in the Sticky(s) "Tech Tips" under the engine section, on how to rebuild Distributors... That may help you out. |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 532 Location: Shoreline, WA
Posted: Thu Apr 04, 2024 11:51 am Post subject: Re: 113 905 205M tear down-how to |
Bill did a fantastic write up on rebuilding the 113 905 205T distributor.
Cheers!
Mike _________________ 1964 Sedan 6 volt |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13621 Location: West Coast, USA
Posted: Thu Apr 04, 2024 12:11 pm Post subject: Re: 113 905 205M tear down-how to |
I'm all for removing the stop, but I drove for years before learning about the ground wire, which is a solder-on part IMO, not something to rebuild the distributor for.
Eliminating slop is definitely worth the time and effort. As is cleaning the pivot plate mechanism, and giving the cam a thorough cleaning/lubricating.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7566 Location: Houston, Texas
Posted: Fri Apr 05, 2024 3:42 pm Post subject: Re: 113 905 205M tear down-how to |
That ground wire breaks off a lot. You can just run your own ground wire. You do not need to solder it back onto the unit. You can run the ground from the points screw to the condenser screw.
As for rebuilding the distributor, there are other topics that say to sand the bushing on top before you reinstall the plate. Do not do this. You should never need to sand a bushing that is already there. All that sanding does it create more wear. All you need to do is apply a little oil and the plate goes on nice and smooth.
If there is a slop where you can push and pull the plate up and down there is likely a fiber washer and/or shim missing. Make sure to use OE fiber washers with dimples in them. Lots of people out there selling and using aftermarket washers without the dimples. The dimples are there for a reason and that is to hold oil.
I have the units for sale outright:
https://www.thesamba.com/vw/classifieds/detail.php?id=2294373
_________________ www.vwnos.com [email protected]
