Pop Out screw questions
BRANDEN HOY
BRANDEN HOY is offline
PostPosted: Thu Nov 10, 2016 3:33 pm    Post subject: Pop Out screw questions Reply with quote
1. Are the 5 pop out to hinge screws to be painted frame color or are they zinc?
2. Are the 3 pop out latch to body screws to be 4mm oval head slotted screws or phillips?
PostPosted: Thu Nov 10, 2016 9:22 pm    Post subject: Re: Pop Out screw questions Reply with quote
I'm going to say:
1. Plated
2. Phillips
BarryL Premium Member
BarryL is offline
PostPosted: Fri Nov 11, 2016 9:57 am    Post subject: Re: Pop Out screw questions Reply with quote
This doesn't prove anything about other years' but these are original '65 and '67 examples. These are bare steel. Part #28 here doesn't say. http://oacdp.org/5867part/455.png
joshbuchan
joshbuchan is offline
PostPosted: Fri Nov 11, 2016 1:44 pm    Post subject: Re: Pop Out screw questions Reply with quote
Aren't they the same as the frame screws? M3.5 NOT M4???
BarryL is offline
PostPosted: Fri Nov 11, 2016 7:18 pm    Post subject: Re: Pop Out screw questions Reply with quote
Part #26 and #28 say 3.5. http://oacdp.org/5867part/455.png
Who said 4?
PostPosted: Fri Nov 11, 2016 9:41 pm    Post subject: Re: Pop Out screw questions Reply with quote
M4 are the pop out latch to body screws - 3 per latch.
#24 in that same parts book page - it says 4x12
Stocknazi
Stocknazi is offline
PostPosted: Sat Nov 12, 2016 6:39 am    Post subject: Re: Pop Out screw questions Reply with quote
Who said 4?
I think he is thinking of the oversize screw size (M4x.70).
The original pop out frame to hinge screw size is: M3.5x.60
WANTED:
Thomas Jefferson
thom
thom is offline
PostPosted: Mon Sep 23, 2024 5:07 pm    Post subject: Re: Pop Out screw questions Reply with quote
I'm going through this right now. I got my screws at https://www.mcmaster.com/92010A798/ - $3.38 for a box of 100
I prefer philips screws, but they also have slotted.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
mdege
mdege is offline
PostPosted: Tue Sep 24, 2024 2:14 am    Post subject: Re: Pop Out screw questions Reply with quote
Those screws are 1mm too long, but probably as close as you will get. I ground mine down to the right length.
Drilled a hole and taped it with M3.5 treads into a flat bar with the right thickness. Screwed the screws into it and the ground down what was sticking out.
- Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
thom
thom is offline
PostPosted: Tue Sep 24, 2024 7:02 am    Post subject: Re: Pop Out screw questions Reply with quote
Yeah, that's the shortest they have.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Thu Jul 17, 2025 9:06 am    Post subject: Re: Pop Out screw questions Reply with quote
The weird-looking one is a cheap Chinese tap that snapped off in the hole.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
