aerosilver Samba Member
Posted: Sun Mar 10, 2024 7:33 am Post subject: Re: Official Oval Convertibles thread and Registry |
Nice vintage slide of an Amazon cabriolet, same as 58-59 Ghia cabriolet.
(Apologies if a repost, I did a quick search and couldn't see it) |
56TIMOTEO Samba Member
Posted: Sun Mar 10, 2024 8:51 am Post subject: Re: Official Oval Convertibles thread and Registry |
Beautiful Kab, wonder if it still exists?!! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4687 Location: St Charles, MO
2Dokas Samba Member
Joined: October 09, 2004 Posts: 757 Location: Santa Cruz, CA
Posted: Tue Mar 26, 2024 7:14 pm Post subject: Re: Official Oval Convertibles thread and Registry |
Hi All,
I am almost done with my top mechanism and wanted to ask if the rear metal bow was solid or a tube. It looks solid from the images I have seen.
I made a jig using a 59 bow but they used a round tube, the attachment point is higher up the other bar so its shorter in height.
The jig worked great, along with a forge
I could also use another image:
This same bow from the rear, showing the funny curve inward, I have the curve from the side pretty well drawn out.
thanks
Peter
thanks
Peter _________________ 87 Doka 2WD Ej22,
56 Convertible |
Posted: Sat Mar 30, 2024 9:15 am Post subject: Re: Official Oval Convertibles thread and Registry |
I have two Oval Beetle Kabriolett roof frames deep in storage for an upcoming project, not sure whether these photos from a few years back will help...
The fully restored and black powder-coated frame I bought from Chuck's Convertibles way back in 1995 or so when I originally purchased the project Kabriolett. I'm no so sure that the black frame is "correct" for my 1957 Kabriolett?
I bought the OG paint used frame at the Seattle Vintage VW meet around 1998 or so because it was too good of a deal to pass up. It appears to be correct.
Hopefully these shots might help?
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
2Dokas Samba Member
Posted: Sun Mar 31, 2024 7:38 am Post subject: Re: Official Oval Convertibles thread and Registry |
Thanks Bill,
Does the bow appear to be a solid bar or round tube? If its easy to access tap it with a hammer unless its finished the correct color
These are helpful, thanks
I am looking for a close up of the junction of the round to the flat looking from behind the car towards the front windshield.
I am going to bend a solid one using a forge next Saturday in my ornamental welding class, just in case or just for fun.
thanks
56 Convertible |
2Dokas Samba Member
Posted: Tue Apr 09, 2024 6:33 am Post subject: Re: Official Oval Convertibles thread and Registry |
Okay, so the bow is tubular and I have a decent one ready to go. _________________ 87 Doka 2WD Ej22,
56 Convertible |
kaieric Samba Member
Joined: August 15, 2022 Posts: 110 Location: saarbruecken/germany
Posted: Mon Jul 01, 2024 2:37 am Post subject: Re: Official Oval Convertibles thread and Registry |
56Cabrio wrote: |
soldeli wrote: |
1) on a 56' vert, am i supposed to have a switch for the dome light when the top is open like on this pic :
.. My car does not have this switch and i think it's right but want to be sure.
Christophe. |
The switch is so when your top is down the light does not go on.
More pics of my switch.
Top open
top down
Bracket & switch.
it's exactly how mine is looking like. unfortunally wires are loose and i would like to know how they are linked to the dome light.
in this picture, two wires for the bracket are coming from the main harness,two from the rear to be linked to the dome light.
now, bracket wiring isn't mentioned in the wiring diagramm. how does it work? suggestions warmly appreciated! _________________ 7/58 Beetle Cabrio RHD |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1995 Location: San Fernando Valley, CA
Busstom Samba Member
Joined: November 23, 2014 Posts: 4569 Location: San Jose, CA
Posted: Mon Jul 01, 2024 7:45 pm Post subject: Re: Official Oval Convertibles thread and Registry |
So early verts actually had a "dome" light in the top? Or is this the light that's integrated into the mirror assy? (Or did early verts not have that type of mirror/light? ) _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
cory464 wrote: |
if you aren't perfectly centered in the hole you will have issues when you tap it. |
Posted: Mon Jul 01, 2024 9:32 pm Post subject: Re: Official Oval Convertibles thread and Registry |
Split and Oval Beetle Kabrioletts indeed had their interior dome light assembly attached to the inner surface of the headliner/convertible frame above the rear seat passengers and did not have it built into the mirror assembly. That happened much later n the 1960's square rear window eras.
Posted: Mon Jul 01, 2024 10:53 pm Post subject: Re: Official Oval Convertibles thread and Registry |
Ahh, very interesting, thanks. It didn't make sense to me that a switch would disable a mirror-mounted light, since we still need illumination at night when the top is down. The mirror-mounted light in my '68 convertible was quite ineffective. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
cory464 wrote: |
Posted: Tue Jul 02, 2024 12:30 am Post subject: Re: Official Oval Convertibles thread and Registry |
@56cabrio - tks for clarification! now i must see if red wire to the cutoff bracket is connected to the frontal fuse box and all wires are undamaged. _________________ 7/58 Beetle Cabrio RHD |
Posted: Sun Aug 04, 2024 8:25 am Post subject: Re: Official Oval Convertibles thread and Registry |
I did a little light searching thru many of these pages as well as the FAQ and so far I didn't find an answer. I'm wondering if the "elbows" for relocating air cleaners for Okrasa engines that Ricardo or W.W. sell will work to relocate the air cleaners when used in the engine compartment of an Oval Beetle Kabriolett with a stock Kabriolett engine decklid with its rain catcher/drains intact. Ricardo mentions that his elbows are correct for a K. Ghia, but there was no mention in the ad as to whether they work on a Okrasa engine and clear the rain catchers in an Oval Beetle Kabriolett. W.W. says in their ad: "these elbows allow installation of the dual port 36hp engine kit for VW truck models, Karmann models, Ghias, and Coachbuilt models." Do you think that "Karmann models" mean Oval Beetle Kabrioletts? Has anyone tried the elbows successfully? Any photos and reviews?
Thanks for any info and guidance!
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 935 Location: Las Vegas, NV
Posted: Tue Aug 06, 2024 6:05 am Post subject: Re: Official Oval Convertibles thread and Registry |
BulliBill wrote: |
I did a little light searching thru many of these pages as well as the FAQ and so I far didn't find an answer. I'm wondering if the "elbows" for relocating air cleaners for Okrasa engines that Ricardo or W.W. sell will work to relocate the air cleaners when used in the engine compartment of a Oval Beetle Kabriolett with a stock engine decklid with its rain catcher/drains intact. Ricardo mentions that his elbows are correct for a K. Ghia, but there was no mention in the ad as to whether they work on a Okrasa engine and clear the rain catchers in an Oval Beetle Kabriolett. W.W. says in their ad: "these elbows allow installation of the dual port 36hp engine kit for VW truck models, Karmann models, Ghias, and Coachbuilt models." Do you think that "Karmann models" mean Oval Beetle Kabrioletts? Has anyone tried the elbows successfully? Any photos and reviews?
Bill |
Hi Bill,
There is a 1956 Oval convertible in the September 2024 Hot VW's magazine and it has a Wolfsburg West Okrasa kit. The decklid has the rain catchers and he is using the elbows like what is used on a Karmann Ghia. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Wed Aug 14, 2024 10:39 am Post subject: Re: Official Oval Convertibles thread and Registry |
Thanks "RonJon" for the tip on the air cleaner "elbows" used on the feature Kabriolett in the Sept 2024 issue of Hot VWs magazine. I see that he is using a pair of those "mushroom" type air cleaners. I am hoping that these elbows might be a solution to running an Okrasa carb kit on an Oval Kabrio with the metal rain catchers on the decklid. It sounds like CSP in Europe, Wolfsburg West and Ricardo down in Argentina make versions of these elbows. But so far I don't think that any of those providers has mentioned that their elbows will fit and work well in an Oval Kabriolett engine compartment using a stock Oval Kabrio decklid with stock metal rain catchers.
It was great to see the one photo showing the engine compartment and someone's elbow products. The owner is Mauricio Vargas of SoCal. He's a GFK member. I'd sure love to chat with him briefly about his experience with these elbows. Did they need any alteration to work well in the Kabrio? Whose version of the elbows did he choose to purchase? Does he have any advice, etc.? Mauricio, if by chance you are on here, please pm me, or if anyone knows him, please hook us up for a few simple questions. I suspect that the elbows will be a solution for me also, but I don't want to spend about $400 to find out that it might or might not work.
Thanks everyone!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
splitpartsunlimited Samba Member
Joined: January 18, 2006 Posts: 1302 Location: Good Ol`Buenos Aires, Argentina
Posted: Thu Aug 15, 2024 4:06 pm Post subject: Re: Official Oval Convertibles thread and Registry |
what years those interior light top switches were used ?? _________________ in my Garage:
1951 crotch cooler split
1958 convertible
1971 1302 convertible
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring |
Posted: Sun Oct 06, 2024 10:20 am Post subject: Re: Official Oval Convertibles thread and Registry |
Who else on here tried to reach out to the owner after this ad was posted for a 1954 convertible beetle for $18k. I was one. I guess Kevin Zagar was the lucky one who was able to purchase it. He posted these pictures on Facebook yesterday. Keven said the seller was overwhelmed and had over 100 people reply back to the ad within the first 24 hours. Here is a link to the ad with no pictures.
https://www.thesamba.com/vw/classifieds/detail.php?id=2706115
Here are the pictures Kevin posted online.
Bugfan-MR Samba Member
Joined: November 12, 2022 Posts: 11 Location: Germany
Posted: Tue Oct 15, 2024 5:40 am Post subject: Re: Official Oval Convertibles thread and Registry |
BulliBill wrote: |
Bill |
Hey Bill,
which book is that page taken from - the one with the break-up of convertible top?
Best,
Marc |
Posted: Tue Oct 15, 2024 6:14 am Post subject: Re: Official Oval Convertibles thread and Registry |
Hi Marc,
It is from the VW Service Workshop manual (edition 1952/57) issued to VW dealerships for the Oval era Beetles, in the "Body" section, chapter 11, page 2.
