Engine issue has me stumped
Page: Previous  1, 2
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Thu Oct 24, 2024 8:43 am    Post subject: Re: Engine issue has me stumped Reply with quote
Heiferman wrote:
Glad you got it going. It can be a confusing battle at times. I am in the middle of advance v rich v retard v advance right now on a big engine I know nothing about.. congrats
Sometimes it's easier to just use the advance side of the distributor instead of both the advance and retard. Plugs the retard side and try to use just the advance. See if that works for you. You will need to time the engine differently when using advance or advance with retard.
Heiferman
Heiferman is offline
PostPosted: Sun Oct 27, 2024 5:42 pm    Post subject: Re: Engine issue has me stumped Reply with quote
Sorry, my post was cryptic. It's a 009. But it will not start at 7.5 BTDC and wants far more advance to start or begin to run smoothly (like 10-12 and like 40 at 3000rpm) so it has been frustrating me.
- 1973 Thing, some LandCruisers and an old Ambulance
VWNOS.com
heimlich is offline
PostPosted: Sun Oct 27, 2024 5:49 pm    Post subject: Re: Engine issue has me stumped Reply with quote
40 is too much. Sounds like it is advancing too much. A 009 usually advances 22 degrees. You are saying there is 28 or 30 degrees. Do you have a Bosch 009? I can tell you how to limit the advance but there might be something else wrong with your distributor. You should open it up and check it out.
Page: Previous  1, 2
Page 2 of 2
