trim piece query
rhubarbray
rhubarbray is offline
PostPosted: Fri Oct 18, 2024 5:12 pm    Post subject: trim piece query Reply with quote
Does anyone know what/where I can get the small piece of trim that goes at the top of the pillar in between the doors? It kinda looks like neoprene foam tubing, not the rubber trim strip that presses on the sheet metal pinch weld edges. Ours is split and I want to replace it. I have the German Motor Works parts manual but I don't see it. Is it glued on?
Heiferman
Heiferman is offline
PostPosted: Fri Oct 18, 2024 8:50 pm    Post subject: Re: trim piece query Reply with quote
A picture would be helpful.
But I bet Thingparts.com could help you.
- 1973 Thing, some LandCruisers and an old Ambulance
rhubarbray
PostPosted: Sat Oct 19, 2024 10:43 am    Post subject: Re: trim piece query Reply with quote
rhubarbray
PostPosted: Sat Oct 19, 2024 10:44 am    Post subject: Re: trim piece query Reply with quote
Hey! That worked!
blsthng
blsthng is offline
PostPosted: Sat Oct 19, 2024 2:41 pm    Post subject: Re: trim piece query Reply with quote
I think that the part you are looking for is
https://thethingshop.net/product/beading-body-front-to-rear/
When I did mine I seem to recall a long piece of trim from the "A" pillar to the back door
Good luck
Bill
rhubarbray
PostPosted: Sat Oct 19, 2024 3:46 pm    Post subject: Re: trim piece query Reply with quote
Ah! You know what. I had seen that seal but dismissed it as it looked like the body edging I didn't need. But now that I look at it, I can see the neoprene pieces are part of the assembly! I guess you can't buy it separately?
obus Premium Member
obus is offline
PostPosted: Wed Oct 23, 2024 7:00 pm    Post subject: Re: trim piece query Reply with quote
That isnt the same piece. it is a neoprene-ish u shaped rubber piece and im not sure anyone is remaking it. I bought one used from Mike Basso here at www.thingparts.com
if you look closely here you will see it. https://www.thingparts.com/seat-belt-hook-ss-set/
https://www.thingparts.com/productimage.php?product_id=1804
germansupplyscott
germansupplyscott is offline
PostPosted: Sat Oct 26, 2024 6:29 pm    Post subject: Re: trim piece query Reply with quote
The foam seal is part of the pinch welt, glued to it. It's not a separate part.
SL
obus Premium Member
obus is offline
PostPosted: Sun Oct 27, 2024 6:48 pm    Post subject: Re: trim piece query Reply with quote
i stand corrected. crazy thats the only way it comes though. I did buy one little piece used from him though and it serves its purpose.
